Hello I ran deepstream-test3-app with the 20 sources and it crashed with this message.
gst_buffer_get_sizes_range: assertion ‘GST_IS_BUFFER (buffer)’ failed
knowing that my code for reading multiple sources is the same as the code in the deepstream-test3-app
but I am wrapping the pipeline making and starting in a class called visionPipeline this class have one public method called start() and a private method called make_pipeline()
this is the code for the make_pipeline():
GstElement * visionPipeline::make_pipeline()
GstElement *pipeline = NULL,
*sink = NULL, *pgie = NULL, *nvtracker = NULL,
*nvdsanalytics = NULL, *tiler = NULL, *nvvidconv = NULL,
*nvosd = NULL, *nvstreammux = NULL;
GstElement *queue = NULL, *queue2 = NULL, *queue3 = NULL, *queue4 = NULL,
*queue5 = NULL, *queue6 = NULL, *queue7 = NULL;
guint tiler_rows, tiler_columns;
bool live_source = false;
long width = 1280;
long height = 720;
std::cout<<"Display off status: "<<_display_off<<std::endl;
pipeline = gst_pipeline_new("dstest4-pipeline");
nvstreammux = gst_element_factory_make("nvstreammux", "nvstreammux");
gst_bin_add(GST_BIN(pipeline), nvstreammux);
if (!pipeline || !nvstreammux)
g_printerr("(Line=%d) One element could not be created. Exiting.\n", __LINE__);
exit(-1);
for(size_t i = 0; i < _num_sources; i++)
std::size_t found = std::string(_streams[i]).find("rtsp");
if(found!=std::string::npos)
std::cout << ">> found live source" << std::endl;
live_source = true;
break;
GstPad *sinkpad, *srcpad;
gchar pad_name[16] = {};
GstElement *source_bin = _create_source_bin(i , _streams[i]);
if (!source_bin)
g_printerr("Failed to create source bin. Exiting.\n");
exit(-1);
gst_bin_add(GST_BIN(pipeline), source_bin);
g_snprintf(pad_name, 15, "sink_%u", (unsigned int)i);
sinkpad = gst_element_get_request_pad(nvstreammux, pad_name);
if (!sinkpad)
g_printerr("nvStreammux request sink pad failed. Exiting.\n");
exit(-1);
srcpad = gst_element_get_static_pad(source_bin, "src");
if (!srcpad)
g_printerr("Failed to get src pad of source bin. Exiting.\n");
exit(-1);
if (gst_pad_link(srcpad, sinkpad) != GST_PAD_LINK_OK)
g_printerr("Failed to link source bin to stream muxer. Exiting.\n");
exit(-1);
gst_object_unref(srcpad);
gst_object_unref(sinkpad);
/* Use nvinfer to run inferencing on decoder's output,
* behaviour of inferencing is set through config file */
pgie = gst_element_factory_make("nvinfer", "primary-nvinference-engine");
if (!pgie)
g_printerr("nvinfer could not be created. Exiting.\n");
exit(-1);
nvtracker = gst_element_factory_make("nvtracker", "tracker");
if (!nvtracker)
g_printerr("nvtracker could not be created. Exiting.\n");
exit(-1);
nvdsanalytics = gst_element_factory_make("nvdsanalytics", "nvdsanalytics");
if (!nvdsanalytics)
g_printerr("nvdsanalytics could not be created. Exiting.\n");
exit(-1);
tiler = gst_element_factory_make("nvmultistreamtiler", "nvtiler");
if (!tiler)
g_printerr("nvmultistreamtiler could not be created. Exiting.\n");
exit(-1);
std::cout<<"Tiler made\n";
/* Use convertor to convert from NV12 to RGBA as required by nvosd */
nvvidconv = gst_element_factory_make("nvvideoconvert", "nvvideo-converter");
if (!nvvidconv)
g_printerr("nvvideoconvert could not be created. Exiting.\n");
exit(-1);
nvosd = gst_element_factory_make("nvdsosd", "nv-onscreendisplay");
if (!nvosd)
g_printerr("nvosd could not be created. Exiting.\n");
exit(-1);
std::cout<<"osd made\n";
/* Create queues */
queue = gst_element_factory_make("queue", "nvtee-que1");
queue2 = gst_element_factory_make("queue", "nvtee-que2");
queue3 = gst_element_factory_make("queue", "nvtee-que3");
queue4 = gst_element_factory_make("queue", "nvtee-que4");
queue5 = gst_element_factory_make("queue", "nvtee-que5");
queue6 = gst_element_factory_make("queue", "nvtee-que6");
queue7 = gst_element_factory_make("queue", "nvtee-que7");
if (!queue || !queue2 || !queue3 || !queue4 || !queue5 || !queue6 || !queue7)
g_printerr("queue could not be created. Exiting.\n");
exit(-1);
std::cout<<"Creating nveglglessink\n";
sink = gst_element_factory_make("nveglglessink", "nvvideo-renderer");
if(!sink)
g_printerr("sink could not be created. Exiting.\n");
exit(-1);
std::cout<<"eglsing made\n";
g_object_set(G_OBJECT(nvstreammux), "batch-size", _num_sources, NULL);
g_object_set(G_OBJECT(nvstreammux), "width", _muxer_width, "height",
_muxer_height,
"batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, "live-source", live_source, NULL);
/* Set all the necessary properties of the nvinfer element,
* the necessary ones are : */
g_object_set(G_OBJECT(pgie),
"config-file-path", strdup(_pgie_config_path.c_str()), NULL);
g_object_set(G_OBJECT(pgie), "batch-size", _num_sources, NULL);
if (!_set_tracker_properties(nvtracker))
g_printerr("Failed to set tracker properties. Exiting.\n");
exit(-1);
g_object_set(G_OBJECT(nvtracker), "display-tracking-id", TRUE, NULL);
/* Configure the nvdsanalytics element for using the particular analytics config file*/
g_object_set(G_OBJECT(nvdsanalytics),
"config-file", strdup(_analytics_config_path.c_str()),
NULL);
tiler_rows = (guint)sqrt(_num_sources);
tiler_columns = (guint)ceil(1.0 * _num_sources / tiler_rows);
/* we set the tiler properties here */
g_object_set(G_OBJECT(tiler), "rows", tiler_rows, "columns", tiler_columns,
"width", width, "height", height, NULL);
g_object_set(G_OBJECT(nvosd), "display-text", TRUE, NULL);
g_object_set(G_OBJECT(nvosd), "process-mode", 1, NULL);
g_object_set(G_OBJECT(sink), "qos", 0, NULL);
g_object_set(G_OBJECT(sink), "sync", false, NULL);
gst_bin_add_many(GST_BIN(pipeline), queue,
pgie, queue2, nvtracker, queue3, nvdsanalytics,
queue4 , nvvidconv, queue5, tiler, queue6, nvosd, queue7, sink, NULL);
std::cout<<"Render elements added to pipeline\n";
if (!gst_element_link_many(nvstreammux, queue, pgie, queue2, nvtracker,
queue3, nvdsanalytics, queue4, nvvidconv,
queue5, tiler, queue6, nvosd, queue7, sink, NULL))
g_printerr("Elements could not be linked. Exiting.\n");
exit(-1);
return pipeline;
and this is the code for the start()method:
void visionPipeline::start()
GMainLoop *loop = NULL;
GstElement *pipeline = NULL;
GstBus *bus = NULL;
guint bus_watch_id;
GstMessage *msg;
loop = g_main_loop_new (NULL, FALSE);
pipeline = _make_pipeline();
bus = gst_pipeline_get_bus(GST_PIPELINE(pipeline));
bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
gst_object_unref (bus);
std::cout<<"Now Playing: "<<std::endl;
for(size_t i = 0; i < _streams.size(); i++)
std::cout<<_streams[i]<<std::endl;
gst_element_set_state(pipeline, GST_STATE_PLAYING);
g_print("Running...\n");
g_main_loop_run (loop);
gst_element_set_state(pipeline, GST_STATE_NULL);
g_print("Deleting pipeline\n");
gst_object_unref(GST_OBJECT(pipeline));
g_source_remove (bus_watch_id);
g_main_loop_unref (loop);
exit(0);
the _streams is a std::vector<char*> that holds the uris and the _num_sources is the size of _streams vector
This piece of code keeps crashing giving me the error that I posted:
GStreamer-CRITICAL **: 22:04:01.099: gst_memory_get_sizes: assertion 'mem != NULL' failed
[2:59 PM] deepstream_cpp exited with code 139
and my driver version is 470.57.02
Do I have a problem with this piece of code? and is this error message related to this issue Deepstream-app crash with nvbufsurface: NvBufSurfaceSysToHWCopy error - #24 by marmikshah ?
