Hello all,
Here is my setup
• Hardware Platform GPU
• Docker image: nvcr.io/nvidia/deepstream:6.0-devel
**• DeepStream 6.0 **
• TensorRT 8.0.1-1
• NVIDIA GPU Driver Version 11.3
I have been running some tests using the docker container for Deepstream 6.0, I am mainly using the example models that come with Deepstream, however when I was using an input image of 1713x1221 I got the following message:
gst-launch-1.0 filesrc location= raw_test_images/test_jpeg/ped_sj.jpeg ! jpegdec ! videoconvert ! nvvideoconvert nvbuf-memory-type=3 ! ‘video/x-raw(memory:NVMM), width=1713, height=1221’ ! m.sink_0 nvstreammux name=m batch-size=2 width=1713 height=1221 ! nvinfer config-file-path= /opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_primary_nano.txt ! fakesink
(gst-plugin-scanner:13): GStreamer-WARNING **: 08:23:19.153: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:13): GStreamer-WARNING **: 08:23:19.182: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.0: cannot open shared object file: No such file or directory
Setting pipeline to PAUSED …
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1484 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/…/…/models/Primary_Detector_Nano/resnet10.caffemodel_b8_gpu0_fp16.engine open error
0:00:00.761627849 12 0x556227c8dd90 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1889> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/…/…/models/Primary_Detector_Nano/resnet10.caffemodel_b8_gpu0_fp16.engine failed
0:00:00.761665229 12 0x556227c8dd90 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1996> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/…/…/models/Primary_Detector_Nano/resnet10.caffemodel_b8_gpu0_fp16.engine failed, try rebuild
0:00:00.761673913 12 0x556227c8dd90 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
WARNING: …/nvdsinfer/nvdsinfer_model_builder.cpp:1224 FP16 not supported by platform. Using FP32 mode.
WARNING: [TRT]: Detected invalid timing cache, setup a local cache instead
0:00:06.916392885 12 0x556227c8dd90 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1947> [UID = 1]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector_Nano/resnet10.caffemodel_b8_gpu0_fp32.engine successfully
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x272x480
1 OUTPUT kFLOAT conv2d_bbox 16x17x30
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x17x300:00:06.920323919 12 0x556227c8dd90 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_primary_nano.txt sucessfully
Pipeline is PREROLLING …
WARNING: from element /GstPipeline:pipeline0/GstNvStreamMux:m: Rounding muxer output width to the next multiple of 8: 1720
Additional debug info:
gstnvstreammux.c(2795): gst_nvstreammux_change_state (): /GstPipeline:pipeline0/GstNvStreamMux:m
WARNING: from element /GstPipeline:pipeline0/GstNvStreamMux:m: Rounding muxer output height to the next multiple of 4: 1224
gstnvstreammux.c(2803): gst_nvstreammux_change_state (): /GstPipeline:pipeline0/GstNvStreamMux:m
Cuda failure: status=700
Error(-1) in buffer allocation** (gst-launch-1.0:12): CRITICAL **: 08:23:25.720: gst_nvds_buffer_pool_alloc_buffer: assertion ‘mem’ failed
ERROR: from element /GstPipeline:pipeline0/GstNvStreamMux:m: Failed to allocate the buffers inside the Nvstreammux output pool
gstnvstreammux.c(791): gst_nvstreammux_alloc_output_buffers (): /GstPipeline:pipeline0/GstNvStreamMux:m
ERROR: pipeline doesn’t want to preroll.
Setting pipeline to NULL …
ERROR: [TRT]: 1: [hardwareContext.cpp::terminateCommonContext::141] Error Code 1: Cuda Runtime (an illegal memory access was encountered)
ERROR: [TRT]: [defaultAllocator.cpp::free::85] Error Code 1: Cuda Runtime (an illegal memory access was encountered)
WARNING: [TRT]: Unable to determine GPU memory usage
ERROR: [TRT]: [resources.cpp::~ScopedCudaStream::455] Error Code 1: Cuda Runtime (an illegal memory access was encountered)
ERROR: [TRT]: [resources.cpp::~ScopedCudaEvent::438] Error Code 1: Cuda Runtime (an illegal memory access was encountered)
terminate called after throwing an instance of ‘nvinfer1::CudaRuntimeError’
what(): an illegal memory access was encountered
Aborted (core dumped)
This means that the input images/videos to Deepstream should have dimensions multiple of 8 (when I test with an image of 664x448 I don’t see this issue) ?
I didn’t found any reference to this in the Documentation.
I did an additional test with the pipeline reaching nvvideoconvert:
gst-launch-1.0 filesrc location= raw_test_images/test_jpeg/ped_sj.jpeg ! jpegdec ! videoconvert ! nvvideoconvert nvbuf-memory-type=3 ! ‘video/x-raw(memory:NVMM), width=1713, height=1221’ ! fakesink
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.000097610
Setting pipeline to READY …
nvbufsurface: Error(-1) in releasing cuda memory
Freeing pipeline …
I am not sure if this is related to the problem with nvstreammux.
