Deepstream pipeline for MJPG usb camera
• Hardware Platform (Jetson / GPU) Jetson Orin NX
• DeepStream Version 6.3
• JetPack Version (valid for Jetson only) 5.1.2
• TensorRT Version 8.5.2
• Issue Type( questions, new requirements, bugs) fail to run deepstream-test1-usbcam.py on MJPG support camera
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) Deepstream USB Python Example GST Pipeline Fails
I’m trying to stream a MJPG format camera. The output of v4l2-ctl -d /dev/video0 --list-formats-ext :
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
    [0]: 'MJPG' (Motion-JPEG, compressed)
                    Interval: Discrete 0.033s (30.000 fps)
                    Interval: Discrete 0.040s (25.000 fps)
These pipelines without nvinfer access to the camera:
gst-launch-1.0 v4l2src device=/dev/video0 ! ‘image/jpeg,width=640,height=360,framerate=30/1,format=MJPG’ ! jpegdec ! nvvideoconvert ! ‘video/x-raw,format=NV12’ ! nveglglessink
gst-launch-1.0 -v v4l2src device=/dev/video0 ! ‘image/jpeg,width=640,height=360,framerate=30/1,format=MJPG’ ! nvv4l2decoder mjpeg=1 ! nvvideoconvert ! ‘video/x-raw,format=NV12’ ! nveglglessink
The pipeline below works when the camera supports YUYV format, but when the camera only supports MJPG,
gst-launch-1.0 v4l2src device=/dev/video0 io-mode=2 ! ‘image/jpeg,width=1920,height=1080,framerate=30/1’ ! jpegparse ! jpegdec ! videoconvert ! nvvideoconvert ! ‘video/x-raw(memory:NVMM),format=NV12’ ! mux.sink_0 nvstreammux live-source=1 name=mux batch-size=1 width=1280 height=720 ! nvinfer config-file-path=/workspace/ds-test/config_pgie_yolo_v4.txt batch-size=1 ! nvmultistreamtiler rows=1 columns=1 width=1920 height=1080 ! nvvideoconvert ! nvegltransform ! nveglglessink
there is the error:
Setting pipeline to PAUSED …
Using winsys: x11
Opening in BLOCKING MODE
WARNING: [TRT]: Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
0:00:04.065469626 364 0xaaaae6520ca0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend()
<nvdsinfer_context_impl.cpp:1988> [UID = 1]: deserialized trt engine from :/workspace/ds-test/models/yolov4_binary_e30_fp16.engine
WARNING: [TRT]: The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1.
INFO: [Implicit Engine Info]: layers num: 5
0 INPUT kFLOAT Input 3x544x960
1 OUTPUT kINT32 BatchedNMS 1
2 OUTPUT kFLOAT BatchedNMS_1 200x4
3 OUTPUT kFLOAT BatchedNMS_2 200
4 OUTPUT kFLOAT BatchedNMS_3 200
0:00:04.255938402 364 0xaaaae6520ca0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() [UID = 1]: Use deserialized engine model: /workspace/ds-test/models/yolov4_binary_e30_fp16.engine
0:00:04.289599010 364 0xaaaae6520ca0 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus: [UID 1]: Load new model:/workspace/ds-test/config_pgie_yolo_v4.txt sucessfully
Pipeline is live and does not need PREROLL …
Got context from element ‘eglglessink0’: gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Setting pipeline to PLAYING …
New clock: GstSystemClock
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = image/jpeg, width=(int)640, height=(int)360, framerate=(fraction)30/1, format=(string)MJPG, parsed=(boolean)true, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:5:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = image/jpeg, width=(int)640, height=(int)360, framerate=(fraction)30/1, format=(string)MJPG, parsed=(boolean)true, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:5:1, interlace-mode=(string)progressive
NvMMLiteOpen : Block : BlockType = 277
NvMMLiteBlockCreate : Block : BlockType = 277
/GstPipeline:pipeline0/nvv4l2decoder:nvv4l2decoder0.GstPad:sink: caps = image/jpeg, width=(int)640, height=(int)360, framerate=(fraction)30/1, format=(string)MJPG, parsed=(boolean)true, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:5:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = image/jpeg, width=(int)640, height=(int)360, framerate=(fraction)30/1, format=(string)MJPG, parsed=(boolean)true, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:5:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/nvv4l2decoder:nvv4l2decoder0.GstPad:src: caps = video/x-raw(memory:NVMM), format=(string)I420, width=(int)640, height=(int)360, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)jpeg, colorimetry=(string)2:4:5:1, framerate=(fraction)30/1, nvbuf-memory-type=(string)nvbuf-mem-surface-array, gpu-id=(int)0
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
> Additional debug info:
> gstbasesrc.c(3072): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
> streaming stopped, reason not-negotiated (-4)
Execution ended after 0:00:00.933210934
Setting pipeline to NULL …
nvstreammux: Successfully handled EOS for source_id=0
Freeing pipeline …
Please give me advice.
Thank you
Could you try to add the format=MJPG in your last pipeline?
This pipeline works. Thank you!!
gst-launch-1.0 v4l2src device=/dev/video0 io-mode=2 ! ‘image/jpeg,width=1280,height=720,framerate=30/1,format=MJPG’ ! jpegdec ! nvvideoconvert ! ‘video/x-raw(memory:NVMM),format=NV12’ ! mux.sink_0 nvstreammux live-source=1 name=mux batch-size=1 width=1280 height=720 ! nvinfer config-file-path=/workspace/ds-test/config_pgie_yolo_v4.txt batch-size=1 ! nvmultistreamtiler rows=1 columns=1 width=1920 height=1080 ! nvvideoconvert ! nvegltransform ! nveglglessink
