Hi everyone.
Have been trying to run the deepstream-app with the following config for some time and without success (DeepStream 4.0.2, r32.2.1):
[source1]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=4
uri=rtsp://[address]/user=user_password=password_channel=1_stream=1.sdp
#drop-frame-interval=2
gpu-id=0
(0): memtype_device - Memory type Device
(1): memtype_pinned - Memory type Host Pinned
(2): memtype_unified - Memory type Unified
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4: Encode+RTSP streaming 5: Overlay (Jetson only) 6:Message #converter + Message broker
type=2
sync=0
source-id=0
gpu-id=0
qos=0
nvbuf-memory-type=0
overlay-id=1
the result being:
Using winsys: x11
Creating LL OSD context new
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
** INFO: <bus_callback:189>: Pipeline ready
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
The following Gstreamer pipe runs without problems:
gst-launch-1.0 rtspsrc location=rtsp://[address]/user=user_password=passwd_channel=1_stream=1.sdp ! rtph264depay ! h264parse ! avdec_h264 ! nvvideoconvert ! nvdsosd ! nvegltransform ! nveglglessink
It also runs with omxh264dec instead of avdec_h264,
but with the nvv4l2decoder the result is:
gst-launch-1.0 rtspsrc location=rtsp://[address]/user=user_password=password_channel=1_stream=1.sdp ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvideoconvert ! nvdsosd ! nvegltransform ! nveglglessink
Setting pipeline to PAUSED …
Using winsys: x11
Pipeline is live and does not need PREROLL …
Got context from element ‘eglglessink0’: gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://[address]/user=user_password=password_channel=1_stream=1.sdp
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
Progress: (request) SETUP stream 1
Progress: (open) Opened Stream
Setting pipeline to PLAYING …
New clock: GstSystemClock
Progress: (request) Sending PLAY request
Progress: (request) Sent PLAY request
(gst-launch-1.0:4491): GStreamer-CRITICAL **: 19:54:28.052: gst_mini_object_unref: assertion ‘mini_object != NULL’ failed
and here it hangs forever.
The deepstream-app also uses nvv4l2decoder
So the question is - what can be done to make the deepstream-app work with the camera I have?
I am ready to share the RTSP stream if need be.
