Gstreamer recording video not working
• Hardware Platform (Jetson / GPU) Jetson Nano 4GB custom board
• DeepStream Version 6.0
• JetPack Version (valid for Jetson only) 4.6
• TensorRT Version 8.0.1.6
• Issue Type( questions, new requirements, bugs) Bug
• How to reproduce the issue ?
I have modified deepstream-test1 app by adding nvtracker in the pipeline.
nvtracker = gst_element_factory_make ("nvtracker", "tracker");
The app runs ok and I can see the bounding boxes along with the object ID.
Then I tried to change the sink in order to save to a file instead of rendering on the screen. So I followed instructions from this post.
This is how I construct the pipeline:
gst_bin_add_many (GST_BIN (pipeline),
      source, h264parser, decoder, streammux, pgie, nvtracker,
      filter1, nvvidconv, filter2, nvosd, nvvidconv1, filter3,
      videoconvert, filter4, x264enc, qtmux, sink, NULL);
Saving to file fails and I am getting below error:
gst_nvvconv_transform: NvBufferGetParams Failed
nvbuf_utils: nvbuffer Payload Type not supported
For nvvidconv you use plugin nvvidconv or nvvideoconvert?
This is how the pipeline is constructed:
/* Create gstreamer elements */
  /* Create Pipeline element that will form a connection of other elements */
  pipeline = gst_pipeline_new ("dstest1-pipeline");
  /* Source element for reading from the file */
  source = gst_element_factory_make ("filesrc", "file-source");
  /* Since the data format in the input file is elementary h264 stream,
   * we need a h264parser */
  h264parser = gst_element_factory_make ("h264parse", "h264-parser");
  /* Use nvdec_h264 for hardware accelerated decode on GPU */
  decoder = gst_element_factory_make ("nvv4l2decoder", "nvv4l2-decoder");
  /* Create nvstreammux instance to form batches from one or more sources. */
  streammux = gst_element_factory_make ("nvstreammux", "stream-muxer");
 /* Use nvinfer to run inferencing on decoder's output,
   * behaviour of inferencing is set through config file */
  pgie = gst_element_factory_make ("nvinfer", "primary-nvinference-engine");
  /* We need to have a tracker to track the identified objects */
  /* Use convertor to convert from NV12 to RGBA as required by nvosd */
  nvvidconv = gst_element_factory_make ("nvvideoconvert", "nvvideo-converter");
  /* Create OSD to draw on the converted RGBA buffer */
  nvosd = gst_element_factory_make ("nvdsosd", "nv-onscreendisplay");
  nvvidconv1 = gst_element_factory_make ("nvvidconv", "nvvideo-converter1");
  videoconvert = gst_element_factory_make ("videoconvert", "converter");
  x264enc = gst_element_factory_make ("x264enc", "h264 encoder");
  qtmux = gst_element_factory_make ("qtmux", "muxer");
  /* sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer"); */
  sink = gst_element_factory_make ("filesink", "filesink");
 /* caps filter for nvvidconv to convert NV12 to RGBA as nvosd expects input
    * in RGBA format */
   filter1 = gst_element_factory_make ("capsfilter", "filter1");
   filter2 = gst_element_factory_make ("capsfilter", "filter2");
   filter3 = gst_element_factory_make ("capsfilter", "filter3");
   filter4 = gst_element_factory_make ("capsfilter", "filter4");
  /* we set the input filename to the source element */
  g_object_set (G_OBJECT (source), "location", argv[1], NULL);
  /* ADD WRITE */
  g_object_set (G_OBJECT (sink), "location", "out.mp4", NULL);
  g_object_set (G_OBJECT (streammux), "batch-size", 1, NULL);
  g_object_set (G_OBJECT (streammux), "width", MUXER_OUTPUT_WIDTH, "height",
      MUXER_OUTPUT_HEIGHT,
      "batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
  /* Set all the necessary properties of the nvinfer element,
   * the necessary ones are : */
  g_object_set (G_OBJECT (pgie),
      "config-file-path", "dstest1_pgie_config.txt", NULL);
  caps1 = gst_caps_from_string ("video/x-raw(memory:NVMM), format=NV12");
  g_object_set (G_OBJECT (filter1), "caps", caps1, NULL);
  gst_caps_unref (caps1);
  caps2 = gst_caps_from_string ("video/x-raw(memory:NVMM), format=RGBA");
  g_object_set (G_OBJECT (filter2), "caps", caps2, NULL);
  gst_caps_unref (caps2);
  caps3 = gst_caps_from_string ("video/x-raw, format=RGBA");
  g_object_set (G_OBJECT (filter3), "caps", caps3, NULL);
  gst_caps_unref (caps3);
  caps4 = gst_caps_from_string ("video/x-raw, format=NV12");
  g_object_set (G_OBJECT (filter4), "caps", caps4, NULL);
  gst_caps_unref (caps4);
  if (!gst_element_link_many (source, h264parser, decoder, NULL)) {
    g_printerr ("Elements could not be linked: 1. Exiting.\n");
    return -1;
   if (!gst_element_link_many (streammux, pgie, nvtracker,
      x264enc, qtmux, sink, NULL)) {
        /*nvvidconv, nvosd, transform, sink, NULL)) { */
      g_printerr ("Elements could not be linked: 2. Exiting.\n");
      return -1;
I am using the following 3 elements:
You can also see my complete code as to how the pipeline is constructed.
I finally managed to get it work by using the following elements:
nvvidconv_osd = gst_element_factory_make ("nvvideoconvert", "nvvidconv_osd");
queue_sink = gst_element_factory_make ("queue", "queue_sink");
nvvidconv_sink = gst_element_factory_make ("nvvideoconvert", "nvvidconv_sink");
So, essentially I used nvvideoconvert twice and didn’t use nvvidconv at all.
Glad to know.
