How to Display confidence with label in deepstream ? like (person 0.81)
Hii @NVES_R @rpaliwal_nvidia @Amycao ,
Can u guide me How to print confidence score beside detection label on bounding box ? In python Deepstream application .
Hi @NVES ,
Can u help me for the same ?
• DeepStream Version
• TensorRT Version
Hello @kesong @NVES @rpaliwal_nvidia @Amycao
Environment Setup
• Hardware Platform - Jetson nvidia nx
• DeepStream Version - 6.0
• JetPack Version - 4.6
• TensorRT Version - 1.8.0
I am using deepstream python app test-1. deepstream_python_apps/apps at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
Whold like to print confidence score with label like (person 0.85) in output .
Below is the sample to access object meta. Can you refer it and change the object meta?
Hi @kesong @NVES_R @NVES_R @rpaliwal_nvidia @Amycao
This is not working for my question.
My issue like, I would like to only display detection confidence with label like …
I got confidence with label in logs like -
Current Output -
guide me …
Do you want to implement something like below?
Hi @kesong
Yes, I would like same but in python application. I set probe in NVOSD src. Guide me
Can you have a try with object_meta->text_params.display_text?
no, where put this in code ? my code in python. can you guide me ? I would
like to add confidence score with labels only .
Hello @kesong
Thanks for your reply
But my question is not solved yet. my code in python. please guide me .
Below is the sample for getting object meta data:
deepstream_python_apps/deepstream_test_1.py at master · NVIDIA-AI-IOT/deepstream_python_apps (github.com)
