How to display multiple cameras?
I have tested single camera on display using the below command:
gst-launch-1.0 v4l2src device=/dev/video0 ! ‘video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)30/1’ ! nvvidconv ! ‘video/x-raw(memory:NVMM), format=(string)NV12’ ! nvoverlaysink -ev
gst-launch-1.0 v4l2src device=/dev/video1 ! ‘video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)30/1’ ! nvvidconv ! ‘video/x-raw(memory:NVMM), format=(string)NV12’ ! nvoverlaysink -ev
gst-launch-1.0 v4l2src device=/dev/video2 ! ‘video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)30/1’ ! nvvidconv ! ‘video/x-raw(memory:NVMM), format=(string)NV12’ ! nvoverlaysink -ev
gst-launch-1.0 v4l2src device=/dev/video3 ! ‘video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)30/1’ ! nvvidconv ! ‘video/x-raw(memory:NVMM), format=(string)NV12’ ! nvoverlaysink -ev
Now i want to display the four cameras at the same time, Could you tell me which command i should use?
Hello @zhaocuiqin ,
There is related subject in the below link.I didnt try whether it is working or not. It might be helpful for you.
Regards.
You may use nvcompositor.
Be sure the final resolution doesn’t exceed your monitor resolution.
Try :
gst-launch-1.0 -v \
nvcompositor name=mix \
sink_0::xpos=0    sink_0::ypos=0   sink_0::width=1280 sink_0::height=720 \
sink_1::xpos=1280 sink_1::ypos=0   sink_1::width=1280 sink_1::height=720 \
sink_2::xpos=0    sink_2::ypos=720 sink_2::width=1280 sink_2::height=720 \
sink_3::xpos=1280 sink_3::ypos=720 sink_3::width=1280 sink_3::height=720 \
! 'video/x-raw(memory:NVMM),format=RGBA,width=2560,height=1440,framerate=30/1' ! nvvidconv ! nvoverlaysink \
videotestsrc ! video/x-raw,width=320,height=240,framerate=30/1 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12,width=1280,height=720,pixel-aspect-ratio=1/1' ! queue ! mix.sink_0 \
videotestsrc ! video/x-raw,width=320,height=240,framerate=30/1 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12,width=1280,height=720,pixel-aspect-ratio=1/1' ! queue ! mix.sink_1 \
videotestsrc ! video/x-raw,width=320,height=240,framerate=30/1 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12,width=1280,height=720,pixel-aspect-ratio=1/1' ! queue ! mix.sink_2 \
videotestsrc ! video/x-raw,width=320,height=240,framerate=30/1 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12,width=1280,height=720,pixel-aspect-ratio=1/1' ! queue ! mix.sink_3
and when it works, just change the sources to your cams instead of videotestsrc.
Since you’re using UYVY sensors, you may use nvv4l2camerasrc:
gst-launch-1.0 nvv4l2camerasrc device=/dev/video0 ! 'video/x-raw(memory:NVMM), format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)30/1' ! ...
