I use a Jetson Nano circuit board and I would need your help to draw dynamic lines through Deepstream for example, through this example already available after having installed Deepstream :
/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_nano.txt
This example than can be run by deepstream-app -c source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_nano.txt when you are in the folder of the file, shows the detection of cars and pedestrians with rectangle boxes.
I would like to display other shapes instead of rectangles and lines as a function of coordinates given by another script. Could you explain to me which files I should modify so as to draw those shapes overlaying the video ?
Thanks in advance for your reply.
