Here is a video of the Jetson Nano using gstreamer commands to run DeepStream using the Live,Infrared and Depth streams from the Kinect V2:
Here is a link to the github repo so you can try it out if you want:
Hi adventuredaisy,
It’s very cool! Thanks for your sharing!
Please also post about your Jetson based projects to Jetson Projects Forum: https://devtalk.nvidia.com/default/board/372/jetson-projects/
Tested with Deepstream5 + Transfer Learning Toolkit - Face Detect IR model ( https://ngc.nvidia.com/catalog/models/nvidia:tlt_facedetectir )- works great
Are you using the IR stream? That’s cool
Yes , Totally :)
