GPU
• DeepStream Version
6.1
• TensorRT Version
8.2.5
510.73.05
questions, new requirements
• How to reproduce the issue ?
• Requirement details
Here is the situation:
I have a pipeline with mutiple rtsp streams linked to one nvstreammux node, continued with one detection PGIE, and several SGIEs. The SGIE nodes sometimes have quite a large inference latency, causing framerate of the whole pipeline decreases. And to avoid corrupted frame (also described as mosaic / broken frames), I set drop-on-latency=0 for rtspsrc.
Pipeline depicted as follows:
rtspsrc0 ----> nvv4l2decoder → queue → |
rtspsrc1 ----> nvv4l2decoder → queue → | => nvstreammux → pgie → sgie1 → sgie2 → … → some sink …
rtspsrcN ----> nvv4l2decoder → queue → |
My question is, how do I drop frames with a queue (or something else) after nvv4l2decoder. That is, set leaky = 2 and max-size-buffers for queue, so as to when queue is full, old frames would be dropped.
Actually, as I tested, if downstream elements have a large latency, nvv4l2decoder would also push buffer at a low frequency. This should be the effect of LATENCY query or LATENCY event, but I don’t know for sure, and cannot figure it out.
The result is, the queue after nvv4l2decoder will never get full and thus will never drop buffers / frames. I tried to add videorate element and framerate caps after queue, but result is the same. I also tested dropping Latency Query or Latency Event with a probe, but not succeeded.
Another thing to mention, when replacing nvv4l2decoder with avdec_h264, the queue got full soon after start and overrun callback is called.
I tested by setting GST_DEBUG to 6, greping logs of video decoder with keywords “Created new frame” or “pushing buffer”, and adding a callback to check queue size. The sgie latency is simulated with a fixed time sleep in custom plugin.
btw, I do know other ways like, setting drop-frame-interval of nvv4l2decoder, setting interval of nvinfer, setting sync=false of all sinks, reducing inference time of SGIES, but they are not “dynamic”.
My question is exactly the same with nvstreammux not getting the latest frame.
