Recently, I want to enable CABAC on TX2 omxh264enc element, but I don’t know how to do it. Does anyone know if omxh264enc supports CABAC? and how to enable it
BTW, I found some people said omxh264enc default enable CABAC on TK1 omxh264enc high profile. I try it on Tx2, and parse H264 stream PPS by wireshark, I found entropy_coding_mode_flag is 0 (1 mean CABAC).
Thanks for you help I can successful enable CABAC, in r32.2
Now in r32.2, I found a problem I want to use omxh264enc enable B frame, when I set omxh264enc profile=(main or high) number-B-Frames=2 , pipeline can’t work, but when I set omxh264enc profile=baseline number-B-Frames=2, it can work. if I change jetpack version to R28, omxh264enc profile=main/high number-B-Frames=2 can work
There is error information
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 100, Level = 40
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Caught SIGSEGV
#0 0x0000007f7bf01048 in __GI___poll (fds=0x558ed3efa0, nfds=547541283248, timeout=<optimized out>) at ../sysdeps/unix/sysv/linux/poll.c:41
#1 0x0000007f7c00ed80 in () at /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0
#2 0x000000558ecaf2d0 in ()
Spinning. Please run 'gdb gst-launch-1.0 8057' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
I see the wiki, high and main profile can support B frame
Can you tell me why I can not use number-B-Frames on Main and high profile?
