I try to use properties of omxh264enc such as low-latency and quality-level in a gstreamer pipeline but they fail. During troubleshooting I have found that the version of gstomx seems to be ages behind gstreamer. I suspect this might be the reason for the missing properties.
I run a TX2 with R28 (release), REVISION: 2.1. gstreamer is version 1.2.3 and so I would expect gstomx to be newer than 1.0.0.1. The inspect outputs for gstreamer and omxh264enc are given below.
This issue might relate to another issue (https://devtalk.nvidia.com/default/topic/918531/jetson-tk1/gstomx-plugin-version-mismatch/) although I would expect that to be fixed by now.
Any pointers to fixing the version mismatch preferably by upgrading to gstomx 1.8 are highly appreciated.
nvidia@tegra-ubuntu:~$ gst-inspect-1.0 --version
gst-inspect-1.0 version 1.8.3
GStreamer 1.8.3
https://launchpad.net/distros/ubuntu/+source/gstreamer1.0
nvidia@tegra-ubuntu:~$ gst-inspect-1.0 omxh264enc
Factory Details:
Rank primary + 10 (266)
Long-name OpenMAX H.264 Video Encoder
Klass Codec/Encoder/Video
Description Encode H.264 video streams
Author Sebastian Dröge <sebastian.droege@collabora.co.uk>
Plugin Details:
Name omx
Description GStreamer OpenMAX Plug-ins
Filename /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstomx.so
Version 1.0.0.1
License LGPL
Source module gst-omx
Source release date 2014-02-08
Binary package GStreamer source release
Origin URL Unknown package origin
GObject
+----GInitiallyUnowned
+----GstObject
+----GstElement
+----GstVideoEncoder
+----GstOMXVideoEnc
+----GstOMXH264Enc
+----GstOMXH264Enc-omxh264enc
Implemented Interfaces:
GstPreset
Pad Templates:
SINK template: 'sink'
Availability: Always
Capabilities:
video/x-raw(memory:NVMM)
format: { I420, NV12 }
width: [ 1, 2147483647 ]
height: [ 1, 2147483647 ]
framerate: [ 0/1, 2147483647/1 ]
video/x-raw
SRC template: 'src'
Capabilities:
video/x-h264
width: [ 16, 4096 ]
height: [ 16, 4096 ]
stream-format: { byte-stream, avc }
alignment: au
Element Flags:
no flags set
Element Implementation:
Has change_state() function: gst_omx_video_enc_change_state
Element has no clocking capabilities.
Element has no URI handling capabilities.
Pads:
SINK: 'sink'
Pad Template: 'sink'
SRC: 'src'
Pad Template: 'src'
Element Properties:
name : The name of the object
flags: readable, writable
String. Default: "omxh264enc-omxh264enc0"
parent : The parent of the object
Object of type "GstObject"
control-rate : Bitrate control method
flags: readable, writable, changeable only in NULL or READY state
Enum "GstOMXVideoEncControlRate" Default: 1, "variable"
(0): disable - Disable
(1): variable - Variable
(2): constant - Constant
(3): variable-skip-frames - Variable Skip Frames
(4): constant-skip-frames - Constant Skip Frames
bitrate : Target bitrate
flags: readable, writable, changeable in NULL, READY, PAUSED or PLAYING state
Unsigned Integer. Range: 0 - 4294967295 Default: 4000000
peak-bitrate : Peak bitrate in variable control-rate
The value must be >= bitrate
(1.2*bitrate) is set by default(Default: 0)
Unsigned Integer. Range: 0 - 4294967295 Default: 0
quant-i-frames : Quantization parameter for I-frames (0xffffffff=component default)
Unsigned Integer. Range: 0 - 4294967295 Default: 4294967295
quant-p-frames : Quantization parameter for P-frames (0xffffffff=component default)
quant-b-frames : Quantization parameter for B-frames (0xffffffff=component default)
iframeinterval : Encoding Intra Frame occurance frequency
SliceIntraRefreshEnable: Enable Slice Intra Refresh while encoding
Boolean. Default: false
SliceIntraRefreshInterval: Set SliceIntraRefreshInterval
Unsigned Integer. Range: 0 - 4294967295 Default: 60
bit-packetization : Whether or not Packet size is based upon Number Of bits
vbv-size : virtual buffer size = vbv-size * (bitrate/fps)
Unsigned Integer. Range: 0 - 30 Default: 10
temporal-tradeoff : Temporal Tradeoff value for encoder
Enum "GstOmxVideoEncTemporalTradeoffType" Default: 0, "Do not drop frames"
(0): Do not drop frames - GST_OMX_VIDENC_DROP_NO_FRAMES
(1): Drop 1 in 5 frames - GST_OMX_VIDENC_DROP_1_IN_5_FRAMES
(2): Drop 1 in 3 frames - GST_OMX_VIDENC_DROP_1_IN_3_FRAMES
(3): Drop 1 in 2 frames - GST_OMX_VIDENC_DROP_1_IN_2_FRAMES
(4): Drop 2 in 3 frames - GST_OMX_VIDENC_DROP_2_IN_3_FRAMES
EnableMVBufferMeta : Enable Motion Vector Meta data for encoding
qp-range : Qunatization range for P and I frame,
Use string with values of Qunatization Range
in MinQpP-MaxQpP:MinQpI-MaxQpP:MinQpB-MaxQpB order, to set the property.
String. Default: "-1,-1:-1,-1:-1,-1"
MeasureEncoderLatency: Enable Measure Encoder latency Per Frame
EnableTwopassCBR : Enable two pass CBR while encoding
preset-level : HW preset level for encoder
Enum "GstOMXVideoEncHwPreset" Default: 0, "UltraFastPreset"
(0): UltraFastPreset - UltraFastPreset for high perf
(1): FastPreset - FastPreset
(2): MediumPreset - MediumPreset
(3): SlowPreset - SlowPreset
EnableStringentBitrate: Enable Stringent Bitrate Mode
insert-sps-pps : Insert H.264 SPS, PPS at every IDR frame
num-B-Frames : Number of B Frames between two reference frames (not recommended)
Unsigned Integer. Range: 0 - 2 Default: 0
slice-header-spacing: Slice Header Spacing number of macroblocks/bits in one packet
Unsigned Long. Range: 0 - 18446744073709551615 Default: 0
profile : Set profile for encode
Enum "GstOmxVideoEncProfileType" Default: 1, "baseline"
(1): baseline - GST_OMX_VIDENC_BASELINE_PROFILE
(2): main - GST_OMX_VIDENC_MAIN_PROFILE
(8): high - GST_OMX_VIDENC_HIGH_PROFILE
insert-aud : Insert H.264 Access Unit Delimiter(AUD)
insert-vui : Insert H.264 VUI(Video Usability Information) in SPS
Element Actions:
"force-IDR" : void user_function (GstElement* object);
