I try to composite 8 h264 30fps fullHD streams from ethernet port to 1 frame and render it.
When input data transfer rate is high(more than 280Mbits), stream’s image become fuzzy.
I think the problem is receiving ability of h264 decoder. My question is blew.
1,What is max data transfer rate h264 decoder can receive?
2,Is there any way to drop frame rate before h264 decoder to reduce data transfer.
3,Is there any way to increase decoder receiving bandwidth. I tried using 2 ethernet ports, but it has no effect.
If it is an issue in decoder bandwidth, you should see slow decoding, not fuzzy images. Every decoded image shall be correct, although it cannot achieve desire frame rate. Per your description, it looks to be an issue that hardware decoder cannot decode the stream correctly. Please share a h264 stream that we can reproduce fuzzy images by running 00_video_decode.
To reproduce the problem, please use a pc conected to jetson-nano to send udp data.
execute the flowing shell script and programme
PC(ip adress 192.168.2.1)
1, run “/test/problem_str_release/chport_all.sh” create 8 port udp streaming data
2, run “/test/problem_str_release/runall.sh [ethernet interface name]” send udp streaming data to jetson-nano
jetson-nano (ip adress 192.168.2.10)
3, run “/test/rspstream_display/rspstream” receive streaming data from pc and render it
Please try to configure the following properties:
skip-frames : Type of frames to skip during decoding
flags: readable, writable, changeable in NULL, READY, PAUSED or PLAYING state
Enum "SkipFrame" Default: 0, "decode_all"
(0): decode_all - Decode all frames
(1): decode_non_ref - Decode non-ref frames
(2): decode_key - decode key frames
drop-frame-interval : Interval to drop the frames,ex: value of 5 means every 5th frame will be given by decoder, rest all dropped
flags: readable, writable, changeable only in NULL or READY state
Unsigned Integer. Range: 0 - 30 Default: 0
dpkg -l | grep gstreamer
ii gir1.2-gstreamer-1.0:arm64 1.14.4-1~ubuntu18.04.1 arm64 GObject introspection data for the GStreamer library
ii gstreamer1.0-alsa:arm64 1.14.1-1ubuntu1~ubuntu18.04.2 arm64 GStreamer plugin for ALSA
ii gstreamer1.0-clutter-3.0:arm64 3.0.26-1 arm64 Clutter PLugin for GStreamer 1.0
ii gstreamer1.0-gl:arm64 1.14.1-1ubuntu1~ubuntu18.04.2 arm64 GStreamer plugins for GL
ii gstreamer1.0-libav:arm64 1.14.1-1~ubuntu18.04.1 arm64 libav plugin for GStreamer
ii gstreamer1.0-packagekit 1.1.9-1ubuntu2.18.04.4 arm64 GStreamer plugin to install codecs using PackageKit
ii gstreamer1.0-plugins-bad:arm64 1.14.1-1ubuntu1~ubuntu18.04.1 arm64 GStreamer plugins from the "bad" set
ii gstreamer1.0-plugins-base:arm64 1.14.1-1ubuntu1~ubuntu18.04.2 arm64 GStreamer plugins from the "base" set
ii gstreamer1.0-plugins-base-apps 1.14.1-1ubuntu1~ubuntu18.04.2 arm64 GStreamer helper programs from the "base" set
ii gstreamer1.0-plugins-good:arm64 1.14.1-1ubuntu1~ubuntu18.04.1 arm64 GStreamer plugins from the "good" set
ii gstreamer1.0-plugins-ugly:arm64 1.14.1-1~ubuntu18.04.1 arm64 GStreamer plugins from the "ugly" set
ii gstreamer1.0-pulseaudio:arm64 1.14.1-1ubuntu1~ubuntu18.04.1 arm64 GStreamer plugin for PulseAudio
ii gstreamer1.0-tools 1.14.1-1~ubuntu18.04.2 arm64 Tools for use with GStreamer
ii gstreamer1.0-x:arm64 1.14.1-1ubuntu1~ubuntu18.04.2 arm64 GStreamer plugins for X11 and Pango
ii libgstreamer-gl1.0-0:arm64 1.14.4-1ubuntu1.1~ubuntu18.04.1 arm64 GStreamer GL libraries
ii libgstreamer-plugins-bad1.0-0:arm64 1.14.1-1ubuntu1~ubuntu18.04.1 arm64 GStreamer libraries from the "bad" set
ii libgstreamer-plugins-base1.0-0:arm64 1.14.4-1ubuntu1.1~ubuntu18.04.1 arm64 GStreamer libraries from the "base" set
ii libgstreamer-plugins-base1.0-dev:arm64 1.14.4-1ubuntu1.1~ubuntu18.04.1 arm64 GStreamer development files for libraries from the "base" set
ii libgstreamer-plugins-good1.0-0:arm64 1.14.1-1ubuntu1~ubuntu18.04.1 arm64 GStreamer development files for libraries from the "good" set
ii libgstreamer1.0-0:arm64 1.14.4-1~ubuntu18.04.1 arm64 Core GStreamer libraries and elements
ii libgstreamer1.0-dev:arm64 1.14.4-1~ubuntu18.04.1 arm64 GStreamer core development files
ii libreoffice-avmedia-backend-gstreamer 1:6.0.7-0ubuntu0.18.04.5 arm64 GStreamer backend for LibreOffice
head -n 1 /etc/nv_tegra_release
# R32 (release), REVISION: 1.0, GCID: 14531094, BOARD: t210ref, EABI: aarch64, DATE: Wed Mar 13 07:46:13 UTC 2019
gst-inspect-1.0 omxh264dec
Factory Details:
Rank primary + 10 (266)
Long-name OpenMAX H.264 Video Decoder
Klass Codec/Decoder/Video
Description Decode H.264 video streams
Author Sebastian Dröge <sebastian.droege@collabora.co.uk>
Plugin Details:
Name omx
Description GStreamer OpenMAX Plug-ins
Filename /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstomx.so
Version 1.0.0.1
License LGPL
Source module gst-omx
Source release date 2014-02-08
Binary package GStreamer source release
Origin URL Unknown package origin
GObject
+----GInitiallyUnowned
+----GstObject
+----GstElement
+----GstVideoDecoder
+----GstOMXVideoDec
+----GstOMXH264Dec
+----GstOMXH264Dec-omxh264dec
Pad Templates:
SINK template: 'sink'
Availability: Always
Capabilities:
video/x-h264
parsed: true
alignment: au
stream-format: byte-stream
width: [ 1, 2147483647 ]
height: [ 1, 2147483647 ]
SRC template: 'src'
Capabilities:
video/x-raw(memory:NVMM)
framerate: [ 0/1, 2147483647/1 ]
video/x-raw
Element has no clocking capabilities.
Element has no URI handling capabilities.
Pads:
SINK: 'sink'
Pad Template: 'sink'
SRC: 'src'
Pad Template: 'src'
Element Properties:
name : The name of the object
String. Default: "omxh264dec-omxh264dec0"
parent : The parent of the object
Object of type "GstObject"
use-omxdec-res : Omx decoder resolution to be used(for debugging purpose)
Boolean. Default: false
full-frame : Whether or not the data is full framed
disable-dpb : Set to disable H.264 DPB buffer for low latency
skip-frames : Which type of frames to skip during decoding
Enum "H264SkipFrame" Default: 0, "DECODE_ALL_Frames"
(0): DECODE_ALL_Frames - GST_OMX_DECODE_ALL_FRAMES
(1): SKIP_NON_REF_FRAMES - GST_OMX_DECODE_SKIP_NON_REF_FRAMES
(2): DECODE_KEY_FRAMES - GST_OMX_DECODE_KEY_FRAMES
output-buffers : The number of OMX decoder output buffers (0 = auto)
Unsigned Integer. Range: 0 - 16 Default: 0
enable-error-check : Set to enable on the fly decode error check
enable-low-outbuffer: Set to enable low output hardware buffer allocation
disable-dvfs : Set to disable dvfs
enable-frame-type-reporting: Set to enable frame type reporting
In my case, input h264 streaming data includes I-frame only.
I think skip-frames does not work.
I have tried skip-frames and drop-frame-interva properties.
The properties are not effective on reducing bit rate before H264decoder.
Is there any way I can try?
Spec is 120Mbps, and 280Mbps is way above the limitations. It may not be able to overcome it in software solutions. Suggest you consider to lower the total data rate.
