Bugged frames using Gstreamer and vpiPerspectiveWarp
I’m sending a video stream with gstreamer in h264, it is working fine, but if I translate (move the image on the x axis) it displays fine on the NX (with the translation). The application that receive the stream contains bugged frames, this behaviour is totally random. Here is a the kind of frame that we receive that alternates with the correct ones.
After much investigation on this issue, we think that it comes from the vpiPerspectiveWarp function. It may create frames that don’t suit our gstreamer pipeline. we are using VPI_INTERP_LINEAR and VPI_BORDER_ZERO on the vpiSubmitPerspectiveWarp function.
We tried to resize the frame to match the size defined in our Gstreamer pipeline, we also adjusted the nvvidconv gstreamer plugins with left=0, right=960, top=0, bottom=540. Both of these methods didn’t succeed.
Here is our pipeline :
std::string gst_out = "appsrc is-live=1 ! video/x-raw, width=960, height=540 ! videoconvert ! videoscale ! nvvidconv left=0 right = 960 top = 0 bottom=540 ! video/x-raw(memory:NVMM), width=960, height=540 ! nvv4l2h264enc insert-sps-pps=1 idrinterval=15 maxperf-enable=1 control-rate=1 peak-bitrate=4100000 ratecontrol-enable=1 preset-level=1 ! queue leaky=0 ! h264parse ! rtph264pay ! udpsink host=IP port=PORT sync=0 async=0"
Jetpack 4.5 + Opencv 4.1.1.
Thank you
One possibility may be the socket kernel buffer max size being a bit short. Does the following improve ?
std::string gst_out = "appsrc is-live=1 ! video/x-raw, width=960, height=540 ! queue ! videoconvert ! videoscale ! nvvidconv left=0 right = 960 top = 0 bottom=540 ! video/x-raw(memory:NVMM), width=960, height=540 ! nvv4l2h264enc insert-sps-pps=1 idrinterval=15 maxperf-enable=1 control-rate=1 peak-bitrate=4100000 ratecontrol-enable=1 preset-level=1 ! queue leaky=0 ! h264parse ! rtph264pay ! udpsink host=IP port=PORT buffer-size=33554432 sync=0 async=0"
If not working, you may tell what format your app is sending and try specifying this in appsrc SRC caps.
You may not need the videoscale and full crop. You may tell if this gives additional errors:
std::string gst_out = "appsrc is-live=1 ! video/x-raw, width=960, height=540 ! queue ! videoconvert ! nvvidconv ! nvv4l2h264enc insert-sps-pps=1 idrinterval=15 maxperf-enable=1 control-rate=1 peak-bitrate=4100000 ratecontrol-enable=1 preset-level=1 ! queue leaky=0 ! h264parse ! rtph264pay ! udpsink host=IP port=PORT buffer-size=33554432 sync=0 async=0"
Hi Honey_Patouceul,
Thank you for your fast reply,
I tried both pipelines and it didn’t improve my issue.
I am not sure about how to do this, do i have to specify the format parameter ? Arguments seems weird to me.
$ gst-inspect-1.0 appsrc
Factory Details:
Rank none (0)
Long-name AppSrc
Klass Generic/Source
Description Allow the application to feed buffers to a pipeline
Author David Schleef ds@schleef.org, Wim Taymans wim.taymans@gmail.com
Plugin Details:
Name app
Description Elements used to communicate with applications
Filename /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstapp.so
Version 1.14.5
License LGPL
Source module gst-plugins-base
Source release date 2019-05-29
Binary package GStreamer Base Plugins (Ubuntu)
Origin URL gst-plugins-base1.0 package : Ubuntu
GObject
±—GInitiallyUnowned
±—GstObject
±—GstElement
±—GstBaseSrc
±—GstAppSrc
Implemented Interfaces:
GstURIHandler
Pad Templates:
SRC template: ‘src’
Availability: Always
Capabilities:
ANY
Element has no clocking capabilities.
URI handling capabilities:
Element can act as source.
Supported URI protocols:
appsrc
Pads:
SRC: ‘src’
Pad Template: ‘src’
Element Properties:
name : The name of the object
flags: readable, writable
String. Default: “appsrc0”
parent : The parent of the object
Object of type “GstObject”
blocksize : Size in bytes to read per buffer (-1 = default)
Unsigned Integer. Range: 0 - 4294967295 Default: 4096
num-buffers : Number of buffers to output before sending EOS (-1 = unlimited)
Integer. Range: -1 - 2147483647 Default: -1
typefind : Run typefind before negotiating (deprecated, non-functional)
flags: readable, writable, deprecated
Boolean. Default: false
do-timestamp : Apply current stream time to buffers
caps : The allowed caps for the src pad
Caps (NULL)
size : The size of the data stream in bytes (-1 if unknown)
Integer64. Range: -1 - 9223372036854775807 Default: -1
stream-type : the type of the stream
Enum “GstAppStreamType” Default: 0, “stream”
(0): stream - GST_APP_STREAM_TYPE_STREAM
(1): seekable - GST_APP_STREAM_TYPE_SEEKABLE
(2): random-access - GST_APP_STREAM_TYPE_RANDOM_ACCESS
max-bytes : The maximum number of bytes to queue internally (0 = unlimited)
Unsigned Integer64. Range: 0 - 18446744073709551615 Default: 200000
format : The format of the segment events and seek
Enum “GstFormat” Default: 2, “bytes”
(0): undefined - GST_FORMAT_UNDEFINED
(1): default - GST_FORMAT_DEFAULT
(2): bytes - GST_FORMAT_BYTES
(3): time - GST_FORMAT_TIME
(4): buffers - GST_FORMAT_BUFFERS
(5): percent - GST_FORMAT_PERCENT
block : Block push-buffer when max-bytes are queued
is-live : Whether to act as a live source
min-latency : The minimum latency (-1 = default)
max-latency : The maximum latency (-1 = unlimited)
emit-signals : Emit need-data, enough-data and seek-data signals
Boolean. Default: true
min-percent : Emit need-data when queued bytes drops below this percent of max-bytes
Unsigned Integer. Range: 0 - 100 Default: 0
current-level-bytes : The number of currently queued bytes
flags: readable
Unsigned Integer64. Range: 0 - 18446744073709551615 Default: 0
duration : The duration of the data stream in nanoseconds (GST_CLOCK_TIME_NONE if unknown)
Unsigned Integer64. Range: 0 - 18446744073709551615 Default: 18446744073709551615
Element Signals:
“need-data” : void user_function (GstElement* object,
guint arg0,
gpointer user_data);
“enough-data” : void user_function (GstElement* object,
“seek-data” : gboolean user_function (GstElement* object,
guint64 arg0,
Element Actions:
“push-buffer” : GstFlowReturn user_function (GstElement* object,
GstBuffer* arg0);
“push-buffer-list” : GstFlowReturn user_function (GstElement* object,
GstBufferList* arg0);
“push-sample” : GstFlowReturn user_function (GstElement* object,
GstSample* arg0);
“end-of-stream” : GstFlowReturn user_function (GstElement* object);
Camera info :
v4l2-ctl --list-formats-ext -d /dev/video0 :
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘YUYV’
Size: Discrete 1920x1080
Interval: Discrete 0.017s (60.000 fps)
Not sure how you use VPI functions. Do you call the functions in appsrc? If possible, please share a test sample so that we can reproduce it and do investigation.
And please share the release version for reference
$ head -1 /etc/nv_tegra_release
Hi DaneLLL,
Sorry for late reply as I wasn’t in the office.
Here is what you requested :
head: cannot open ‘1’ for reading: No such file or directory
==> /etc/nv_tegra_release <==
#R32 (release), REVISION: 5.0, GCID: 25531747, BOARD: t186ref, EABI: aarch64, DATE: Fri Jan 15 23:21:05 UTC 2021
For more precision, i’m working on a production module with a Quark board from Connecttech. My Jetpack version is 4.5 and I can’t upgrade it, since the BSP can’t support superior version.
For further investigation we would need to reproduce the issue. There are existing samples in
/opt/nvidia/vpi1/
Please check if you can share a patch to either sample so that we can give it a try.
Hi DaneLLL,
I reproduced my usage of perspective warp from the vpi_sample_perspective_warp, with minimal variables and it is working as expected.
So the issue doesn’t come from the function or my usage with it. I am thinking about threads conflict, or lack of performance from the receiver.
Thank you
