Nosiy image generated after vpiSubmitRescale
I created a small program where I use VPI to resize the cropped frames that are obtained from an IMX 219 camera (Raspberry Pi Camera V2) using GStreamer in Jetson Nano, and visualizing the stream in my laptop using UDP pipeline also with GStreamer. It works well with an output frame size of 1280 x 720, but if I change the resized output width to something else (modify macro OUTPUT_W), I obtain a noisy image as the one attached to this topic. However, I don’t see this issue if I only modify the height.
I have tried with a clean install of JetPack 4.5 and 4.5.1 to include VPI Production Release 1.0, and with a USB camera, but the results are the same. Also, if I replace VPI’s resizing with resize in OpenCV (CPU version), the issue doesn’t appear there.
Perhaps I missed something from VPI’s documentation, please let me know.
Any help is very well appreciated.
Please see my code below (update the HOST macro to match your IP):
#include <opencv2/imgcodecs.hpp>
#include <opencv2/imgproc.hpp>
#include <opencv2/videoio.hpp>
#include <opencv2/highgui.hpp>
#include <vpi/OpenCVInterop.hpp>
#include <vpi/Image.h>
#include <vpi/Status.h>
#include <vpi/Stream.h>
#include <vpi/CUDAInterop.h>
#include <vpi/algo/ConvertImageFormat.h>
#include <vpi/algo/Rescale.h>
#include <cstring>
#include <iostream>
#include <sstream>
#include <thread>
#define HOST_IP  "XXX.XXX.X.XX"
#define GST_SRC_PIPELINE_USB \
    "v4l2src device=/dev/video1 " \
    "! image/jpeg, width=1280, height=720, framerate=30/1 " \
    "! jpegdec ! videoconvert ! video/x-raw, format=(string)BGR ! appsink"
#define GST_SRC_PIPELINE_IMX \
    "nvarguscamerasrc " \
    "! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, " \
    "format=(string)NV12, framerate=(fraction)60/1 " \
    "! nvvidconv flip-method=0 " \
    "! video/x-raw, width=(int)1280, height=(int)720, format=(string)BGRx " \
    "! videoconvert ! video/x-raw, format=(string)BGR ! appsink"
#define GST_SINK_PIPELINE \
    "appsrc ! videoconvert ! x264enc speed-preset=superfast tune=zerolatency " \
    "! rtph264pay ! udpsink port=3445 host=" HOST_IP
#define OUTVID_FPS  30.0
#define NUM_WINDOWS  4
#define OUTPUT_W  700
#define OUTPUT_H  400
#define CHECK_STATUS(STMT)                                    \
    do                                                        \
    VPIStatus status = (STMT);                            \
    if (status != VPI_SUCCESS)                            \
        char buffer[VPI_MAX_STATUS_MESSAGE_LENGTH];       \
        vpiGetLastStatusMessage(buffer, sizeof(buffer));  \
        std::ostringstream ss;                            \
        ss << vpiStatusGetName(status) << ": " << buffer; \
        throw std::runtime_error(ss.str());               \
} while (0);
static bool keep_running = true;
static VPIImage
ToVPIImage(VPIImage image, const cv::Mat &frame)
    if (image == nullptr)
        // Ceate a VPIImage that wraps the frame
        CHECK_STATUS(vpiImageCreateOpenCVMatWrapper(frame, 0, &image));
    else
        // reuse existing VPIImage wrapper to wrap the new frame.
        CHECK_STATUS(vpiImageSetWrappedOpenCVMat(image, frame));
    return image;
static void
userInput_thread(void)
    while(keep_running) {
        if (std::cin.get() == '\n')
            keep_running = false;
int
main(int argc, char *argv[])
    int retval = 0;
    bool bypass_windows = false;
    bool use_usb = false;
    cv::VideoCapture invid;
    cv::VideoWriter outvid;
    cv::Mat srcimg;
    cv::Mat crpimg;
    cv::Mat sinkimg;
    cv::Rect windows[NUM_WINDOWS];
    VPIBackend backend = VPI_BACKEND_CUDA;
    VPIStream stream;
    VPIImage vpi_in_img = NULL;
    VPIImage vpi_in_nv12_img = NULL;
    VPIImage vpi_rsz_img = NULL;
    VPIImage vpi_out_img = NULL;
    VPIImageData vpi_out_data;
    int w;
    int h;
    int fourcc;
    int wincnt = 0;
    int framecnt = 0;
    std::thread inthread(&userInput_thread);
    std::vector<std::string> args(argv, argv+argc);
    for (size_t i = 1; i < args.size(); ++i) {
        if ((args[i] == "-b") || (args[i] == "--bypass")) {
            bypass_windows = true;
        } else if ((args[i] == "-u") || (args[i] == "--usb")) {
            use_usb = true;
    if(use_usb)
        invid.open(GST_SRC_PIPELINE_USB, cv::CAP_GSTREAMER);
    else
        invid.open(GST_SRC_PIPELINE_IMX, cv::CAP_GSTREAMER);
    w = invid.get(cv::CAP_PROP_FRAME_WIDTH);
    h = invid.get(cv::CAP_PROP_FRAME_HEIGHT);
   fourcc = cv::VideoWriter::fourcc('H','2','6','4');
    outvid.open(GST_SINK_PIPELINE, cv::CAP_GSTREAMER, fourcc, OUTVID_FPS,
                cv::Size(OUTPUT_W, OUTPUT_H));
    windows[0] = cv::Rect(0, 0, w / 2, h / 2);
    windows[1] = cv::Rect((w / 2) - 1, 0, w / 2, h / 2);
    windows[2] = cv::Rect(0, (h / 2) - 1, w / 2, h / 2);
    windows[3] = cv::Rect((w / 2) - 1, (h / 2) - 1, w / 2, h / 2);
    try
        if(!bypass_windows)
            CHECK_STATUS(vpiStreamCreate(backend, &stream));
            // Create a temporary image to hold the input converted to NV12.
            CHECK_STATUS(vpiImageCreate(w / 2, h / 2, VPI_IMAGE_FORMAT_NV12_ER,
                                        0, &vpi_in_nv12_img));
            // Now create the resized image.
            CHECK_STATUS(vpiImageCreate(OUTPUT_W, OUTPUT_H,
                                        VPI_IMAGE_FORMAT_NV12_ER, 0,
                                        &vpi_rsz_img));
            // And the resized image converted back to BGR8
                                        VPI_IMAGE_FORMAT_BGR8, 0,
                                        &vpi_out_img));
        while(keep_running)
            if(!invid.read(srcimg))
                break;
            if(!bypass_windows)
                crpimg = srcimg(windows[wincnt]);
                // We now wrap the loaded image into a VPIImage object to be
                // used by VPI. VPI won't make a copy of it, so the original
                // image must be in scope at all times.
                vpi_in_img = ToVPIImage(vpi_in_img, crpimg);
                // Convert input from BGR8 to NV12
                CHECK_STATUS(vpiSubmitConvertImageFormat(stream, backend,
                                                         vpi_in_img,
                                                         vpi_in_nv12_img,
                                                         NULL));
                // Now we downsample
                CHECK_STATUS(vpiSubmitRescale(stream, backend, vpi_in_nv12_img,
                                              vpi_rsz_img, VPI_INTERP_LINEAR,
                                              VPI_BORDER_CLAMP, 0));
                // Finally, convert the result back to BGR8
                                                         vpi_rsz_img,
                                                         vpi_out_img, NULL));
                CHECK_STATUS(vpiStreamSync(stream));
                CHECK_STATUS(vpiImageLock(vpi_out_img, VPI_LOCK_READ,
                                          &vpi_out_data));
                CHECK_STATUS(vpiImageDataExportOpenCVMat(vpi_out_data,
                                                         &sinkimg));
                outvid.write(sinkimg);
                CHECK_STATUS(vpiImageUnlock(vpi_out_img));
                framecnt++;
                if(framecnt == OUTVID_FPS)
                    framecnt = 0;
                    wincnt++;
                    wincnt %= NUM_WINDOWS;
            else
                outvid.write(srcimg);
    catch (std::exception &e)
        std::cerr << "Exception found: " << e.what() << std::endl;
        retval = 1;
    inthread.join();
    if(!bypass_windows)
        if (stream != NULL)
            vpiStreamSync(stream);
        vpiImageDestroy(vpi_in_img);
        vpiImageDestroy(vpi_in_nv12_img);
        vpiImageDestroy(vpi_rsz_img);
        vpiImageDestroy(vpi_out_img);
        vpiStreamDestroy(stream);
    return retval;
The CMakeList.txt to compile the code:
cmake_minimum_required(VERSION 3.5)
project(resize_windows_vpi)
find_package(vpi 1.0 REQUIRED)
find_package(OpenCV REQUIRED)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -pthread")
add_executable(${PROJECT_NAME} main.cpp)
include_directories(/usr/local/cuda-10.2/targets/aarch64-linux/include)
target_link_libraries(${PROJECT_NAME} vpi)
target_link_libraries(${PROJECT_NAME} opencv_core)
target_link_libraries(${PROJECT_NAME} opencv_videoio)
The pipeline that I use to see the stream in my laptop (if you change the output width or height in main.cpp, don’t forget to do the same here to match the same values):
gst-launch-1.0 udpsrc port=3445 ! application/x-rtp ! rtph264depay ! queue \
  ! avdec_h264 ! videoconvert \
  ! "video/x-raw, width=1280, height=720, framerate=(fraction)30/1" ! ximagesink
Please convert NV12 to RGBA and then read the buffer in OpenCV. In VPI, the buffers are DMA buffers and there is data alignment. For example, for 640x480, pitch, width, height of the buffer is 768,640,480. OpenCV may expect it to be continuous data in 640x480 bytes so you will see bad image.
Thank you @DaneLLL, that did the trick. I also had to add an extra conversion from RGBA to BGR so the gstreamer pipeline described in GST_SINK_PIPELINE works as is.
I wasn’t aware of the pitch bytes and DMA being used in the VPI buffers, but it’s still not clear to me why the NV12 to BGR conversion doesn’t work directly. Are the bytes in the alpha channel aligning the data so the image is processed correctly when passed to OpenCV?
Could you please explain further about this?
Thanks in advance.
You may have a look to this post.
