VPI on dGPU and Jetson
• Jetson & dGPU
• Deepstream 6.4
• JetPack Version 6.2
• 561.17
**• How do I get VPI to work with **
**• How to reproduce the issue? We have based a Deepstream GStreamer plugin off of the gstexample(/opt/nvidia/deepstream/deepstream-6.4/sources/gst-plugins/gst-dsexample) and instead of using OpenCV we would like to use VPI to keep the image in GPU/iGPU memory to do operations. **
**• Requirement details - Trying to get rid of OpenCV in favor of VPI to do operations on images in GPU memory instead of bringing down to the CPU. **
Currently we use the following method to convert NvBufSurface into a cv::Mat which brings the image down from GPU memory to CPU:
static GstFlowReturn get_converted_mat(GstPip *pip, NvBufSurface *input_buf, gint idx,
                                       NvOSD_RectParams *crop_rect_params, gdouble &ratio, gint input_width,
                                       gint input_height) {
    NvBufSurfTransform_Error err;
    NvBufSurfTransformConfigParams transform_config_params;
    NvBufSurfTransformParams transform_params;
    NvBufSurfTransformRect src_rect;
    NvBufSurfTransformRect dst_rect;
    NvBufSurface ip_surf;
    cv::Mat in_mat;
    ip_surf = *input_buf;
    ip_surf.numFilled = ip_surf.batchSize = 1;
    ip_surf.surfaceList = &(input_buf->surfaceList[idx]);
    gint src_left = GST_ROUND_UP_2((unsigned int)crop_rect_params->left);
    gint src_top = GST_ROUND_UP_2((unsigned int)crop_rect_params->top);
    gint src_width = GST_ROUND_DOWN_2((unsigned int)crop_rect_params->width);
    gint src_height = GST_ROUND_DOWN_2((unsigned int)crop_rect_params->height);
    // Calculate the extra padding for the object (12.5% of width and height)
    gint padding_width = src_width * 0.25;
    gint padding_height = src_height * 0.25;
    // Adjust left, top, width, and height while ensuring they remain within the
    // frame bounds
    src_left = std::max(0, src_left - padding_width);
    src_top = std::max(0, src_top - padding_height);
    src_width = std::min(input_width - src_left, src_width + 2 * padding_width);
    src_height = std::min(input_height - src_top, src_height + 2 * padding_height);
    /* Maintain aspect ratio */
    double hdest = pip->processing_width * src_height / (double)src_width;
    double wdest = pip->processing_height * src_width / (double)src_height;
    guint dest_width, dest_height;
    if (hdest <= pip->processing_height) {
        dest_width = pip->processing_width;
        dest_height = hdest;
    } else {
        dest_width = wdest;
        dest_height = pip->processing_height;
    /* Configure transform session parameters for the transformation */
    transform_config_params.compute_mode = NvBufSurfTransformCompute_Default;
    transform_config_params.gpu_id = pip->gpu_id;
    transform_config_params.cuda_stream = pip->cuda_stream;
    /* Set the transform session parameters for the conversions executed in this
     * thread. */
    err = NvBufSurfTransformSetSessionParams(&transform_config_params);
    if (err != NvBufSurfTransformError_Success) {
        NVGSTDS_ERR_MSG_V("NvBufSurfTransformSetSessionParams failed with error %d", err);
        goto error;
    /* Calculate scaling ratio while maintaining aspect ratio */
    ratio = MIN(1.0 * dest_width / src_width, 1.0 * dest_height / src_height);
    if ((crop_rect_params->width == 0) || (crop_rect_params->height == 0)) {
        NVGSTDS_ERR_MSG_V("Crop rect params dimensions are zero");
        goto error;
#ifdef __aarch64__
    if (ratio <= 1.0 / 16 || ratio >= 16.0) {
        /* Currently cannot scale by ratio > 16 or < 1/16 for Jetson */
        NVGSTDS_ERR_MSG_V("Cannot scale by ratio > 16 or < 1/16 for Jetson.");
        goto error;
#endif
    /* Set the transform ROIs for source and destination */
    src_rect = {(guint)src_top, (guint)src_left, (guint)src_width, (guint)src_height};
    dst_rect = {0, 0, (guint)dest_width, (guint)dest_height};
    /* Set the transform parameters */
    transform_params.src_rect = &src_rect;
    transform_params.dst_rect = &dst_rect;
    transform_params.transform_flag =
        NVBUFSURF_TRANSFORM_FILTER | NVBUFSURF_TRANSFORM_CROP_SRC | NVBUFSURF_TRANSFORM_CROP_DST;
    transform_params.transform_filter = NvBufSurfTransformInter_Default;
    /* Memset the memory */
    NvBufSurfaceMemSet(pip->inter_buf, 0, 0, 0);
    /* Transformation scaling+format conversion if any. */
    err = NvBufSurfTransform(&ip_surf, pip->inter_buf, &transform_params);
        NVGSTDS_ERR_MSG_V("NvBufSurfTransform failed with error %d while converting buffer", err);
        goto error;
    /* Map the buffer so that it can be accessed by CPU */
    if (NvBufSurfaceMap(pip->inter_buf, 0, 0, NVBUF_MAP_READ) != 0) {
        goto error;
    if (pip->inter_buf->memType == NVBUF_MEM_SURFACE_ARRAY) {
        /* Cache the mapped data for CPU access */
        NvBufSurfaceSyncForCpu(pip->inter_buf, 0, 0);
    /* Use openCV to remove padding and convert RGBA to BGR. Can be skipped if
     * algorithm can handle padded RGBA data. */
    in_mat = cv::Mat(pip->processing_height, pip->processing_width, CV_8UC4,
                     pip->inter_buf->surfaceList[0].mappedAddr.addr[0], pip->inter_buf->surfaceList[0].pitch);
#if (CV_MAJOR_VERSION >= 4)
    cv::cvtColor(in_mat, *pip->cvmat, cv::COLOR_RGBA2BGR);
#else
    cv::cvtColor(in_mat, *pip->cvmat, CV_RGBA2BGR);
#endif
    if (NvBufSurfaceUnMap(pip->inter_buf, 0, 0)) {
        goto error;
    if (pip->is_integrated) {
#ifdef __aarch64__
        /* To use the converted buffer in CUDA, create an EGLImage and then use
         * CUDA-EGL interop APIs */
        if (USE_EGLIMAGE) {
            if (NvBufSurfaceMapEglImage(pip->inter_buf, 0) != 0) {
                goto error;
            /* pip->inter_buf->surfaceList[0].mappedAddr.eglImage
             * Use interop APIs cuGraphicsEGLRegisterImage and
             * cuGraphicsResourceGetMappedEglFrame to access the buffer in CUDA
            /* Destroy the EGLImage */
            NvBufSurfaceUnMapEglImage(pip->inter_buf, 0);
#endif
    /* We will first convert only the Region of Interest (the entire frame or
     * the object bounding box) to RGB and then scale the converted RGB frame to
     * processing resolution. */
    return GST_FLOW_OK;
error:
    return GST_FLOW_ERROR;
This is called in our gst_pip_transform_ip method:
static GstFlowReturn gst_pip_transform_ip(GstBaseTransform *btrans, GstBuffer *inbuf) {
    GstPip *pip = GST_PIP(btrans);
    NvDsBatchMeta *batch_meta = NULL;
    NvDsObjectMeta *obj_meta = NULL;
    batch_meta = gst_buffer_get_nvds_batch_meta(inbuf);
    if (batch_meta == NULL) {
        NVGSTDS_ERR_MSG_V("NvDsBatchMeta not found for input buffer");
    GstMapInfo in_map_info;
    GstFlowReturn flow_ret = GST_FLOW_ERROR;
    gdouble scale_ratio = 1.0;
    PipOutput *output;
    NvBufSurface *surface = NULL;
    NvDsFrameMeta *frame_meta = NULL;
    NvDsMetaList *l_frame = NULL;
    guint i = 0;
    cv::Mat in_mat;
    NvDsMetaList *l_obj = NULL;
    CHECK_CUDA_STATUS(cudaSetDevice(pip->gpu_id), "Unable to set cuda device");
    memset(&in_map_info, 0, sizeof(in_map_info));
    if (!gst_buffer_map(inbuf, &in_map_info, GST_MAP_READ)) {
        NVGSTDS_ERR_MSG_V("Failed to map gst buffer.");
        goto error;
    nvds_set_input_system_timestamp(inbuf, GST_ELEMENT_NAME(pip));
    surface = (NvBufSurface *)in_map_info.data;
    if (CHECK_NVDS_MEMORY_AND_GPUID(pip, surface))
        goto error;
    if (!pip->is_integrated) {
        if (!(surface->memType == NVBUF_MEM_CUDA_UNIFIED || surface->memType == NVBUF_MEM_CUDA_PINNED)) {
            GST_ELEMENT_ERROR(pip, STREAM, FAILED,
                              ("%s:need NVBUF_MEM_CUDA_UNIFIED or "
                               "NVBUF_MEM_CUDA_PINNED memory for "
                               "opencv digital enhancement",
                               __func__),
                              (NULL));
    for (l_frame = batch_meta->frame_meta_list; l_frame != NULL; l_frame = l_frame->next) {
        frame_meta = (NvDsFrameMeta *)(l_frame->data);
        if (surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[0] == NULL) {
            if (NvBufSurfaceMap(surface, frame_meta->batch_id, 0, NVBUF_MAP_READ_WRITE) != 0) {
                NVGSTDS_ERR_MSG_V("Buffer map to be accessed by CPU failed");
            NvBufSurfaceSyncForCpu(surface, frame_meta->batch_id, 0);
        in_mat = cv::Mat(surface->surfaceList[frame_meta->batch_id].planeParams.height[0],
                            surface->surfaceList[frame_meta->batch_id].planeParams.width[0], CV_8UC4,
                            surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[0],
                            surface->surfaceList[frame_meta->batch_id].planeParams.pitch[0]);
        obj_meta = find_central_object_with_highest_confidence(pip, batch_meta);
        if (obj_meta != NULL) {
            /* Crop and scale the object */
            if (get_converted_mat(pip, surface, frame_meta->batch_id, &obj_meta->rect_params, scale_ratio,
                                  pip->video_info.width, pip->video_info.height) != GST_FLOW_OK) {
                /* Error in conversion, skip processing on object. */
                continue;
            if (digitally_enhance_object(pip, surface, frame_meta, in_mat) != GST_FLOW_OK) {
                NVGSTDS_ERR_MSG_V("Unable to digitally enhance object");
        else if (!pip->cached_frames[frame_meta->source_id].empty()) {
            auto now = std::chrono::steady_clock::now();
            auto last_update = pip->cached_timestamps[frame_meta->source_id];
            auto duration = std::chrono::duration_cast<std::chrono::milliseconds>(now - last_update).count();
            if (duration < pip->cached_duration) {
                int pipWidth, pipHeight, pipPosX, pipPosY;
                if (calculate_object_region(surface, frame_meta, pipWidth, pipHeight, pipPosX, pipPosY) != GST_FLOW_OK) {
                    NVGSTDS_ERR_MSG_V("Unable to display cached object");
                cv::Rect pipRect(pipPosX, pipPosY, pipWidth, pipHeight);
                pip->cached_frames[frame_meta->source_id].copyTo(in_mat(pipRect));
        /* Cache the mapped data for device access */
            NvBufSurfaceSyncForDevice(surface, frame_meta->batch_id, 0);
    } // For loop end
    flow_ret = GST_FLOW_OK;
error:
    nvds_set_output_system_timestamp(inbuf, GST_ELEMENT_NAME(pip));
    gst_buffer_unmap(inbuf, &in_map_info);
    return flow_ret;
VPI seems to be straight forward for the Jetson, looks like you can wrap the NvBufSurface directly like so:
NvBufSurfaceMapParams buffer_params;
NvBufSurfaceGetMapParams(surface, 0, &buffer_params);
VPIImageData img_data;
img_data.bufferType = VPI_IMAGE_BUFFER_NVBUFFER;
img_data.buffer.fd = buffer_params.fd;
VPIStatus err_vpi = vpiImageCreateWrapper(&img_data, nullptr, VPI_BACKEND_CUDA, &img_vpi);
As stated here, looks like this is only valid on the Jetson but not for dGPU:
How can this be done with the dGPU?
How can you use JetPack 6.2 with DeepStream 6.4? It is not compatible. Installation — DeepStream documentation
DeepStream does not support NvBuffer, neither on Jetson nor on dGPU. So you need to map the DeepStream NvBufSurface to VPI NvBuffer on Jetson by yourself.
For dGPU case, you need to map DeepStream NvBufSurface CUDA buffers to VPI dGPU VPIImageData first.
Please consult on VPI forum for how to use the VPI interfaces on both Jetson and dGPU. Latest AI & Data Science/Computer Vision & Image Processing topics - NVIDIA Developer Forums
Is this duplicated with Deepstream VPI 3.0 Wrapper Compatibility dGPU - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums?
I am using the Docker image of Deepstream 6.4 actually with the latest Jetpack OS on my Jetson. Can you move this over to the VPI forum then? I have searched the forums and have even posted once before about this topic and haven’t gotten a clear answer or example shown. Thanks
No. It is not compatible. DeepStream version should be compatible to the correspondent JetPack version, even with container.
You may raise new topic to VPI forum for the DeepStream part has nothing to do with your question.
Well it works just fine. In my current code, I am using OpenCV to create a PIP(Picture-in-Picture) in the bottom right 20% of the screen that looks like so:
However, this code requires that the NvBufSurface frame go from GPU->CPU->GPU which adds additional overhead. I do this with the following 3 methods:
    cv::Mat in_mat;
    // frame bounds
    } else {
        dest_width = wdest;
     * thread. */
        goto error;
        goto error;
#ifdef __aarch64__
        goto error;
#endif
        goto error;
        goto error;
#else
#endif
        goto error;
    return GST_FLOW_OK;
error:
 * Calculates an objects cropped region
static GstFlowReturn calculate_object_region(NvBufSurface *surface, NvDsFrameMeta *frame_meta, int &pipWidth,
                                             int &pipHeight, int &pipPosX, int &pipPosY) {
    pipWidth = static_cast<int>(surface->surfaceList[frame_meta->batch_id].planeParams.width[0] * 0.2);
    pipHeight = static_cast<int>(surface->surfaceList[frame_meta->batch_id].planeParams.height[0] * 0.2);
    pipPosX = surface->surfaceList[frame_meta->batch_id].planeParams.width[0] - pipWidth;
    pipPosY = surface->surfaceList[frame_meta->batch_id].planeParams.height[0] - pipHeight;
    if ((pipWidth == 0) || (pipHeight == 0)) {
        NVGSTDS_ERR_MSG_V("PIP dimensions are zero");
    return GST_FLOW_OK;
 * Digitially enhances an object and inserts this into a PIP into the frame
static GstFlowReturn digitally_enhance_object(GstPip *pip, NvBufSurface *surface, NvDsFrameMeta *frame_meta,
                                              cv::Mat &in_mat) {
    // Enhance the PIP using OpenCV
    cv::Mat enhancedPIP;
    // Increase brightness and contrast
    pip->cvmat->convertTo(enhancedPIP, -1, 1.2, 25);
    // Calculate PIP size and position
    // Resize the enhanced PIP
    cv::resize(enhancedPIP, enhancedPIP, cv::Size(pipWidth, pipHeight));
    // Noise Reduction using Median Blur
    cv::medianBlur(enhancedPIP, enhancedPIP, 3); // Add Noise Reduction
    // Bilateral Filter to reduce noise
    cv::Mat bilateralFilteredPIP;
    cv::bilateralFilter(enhancedPIP, bilateralFilteredPIP, 9, 75, 75);
    // Sharpening
    cv::Mat kernel = (cv::Mat_<float>(3, 3) << -1, -1, -1, -1, 9, -1, -1, -1, -1);
    cv::Mat sharpenedPIP;
    cv::filter2D(bilateralFilteredPIP, sharpenedPIP, -1, kernel);
    // Adaptive Histogram Equalization (CLAHE)
    cv::Mat grayPIP, clahePIP;
    cv::cvtColor(sharpenedPIP, grayPIP, cv::COLOR_BGR2GRAY);
    clahe->setClipLimit(2.0);
    clahe->apply(grayPIP, clahePIP);
    cv::cvtColor(clahePIP, sharpenedPIP, cv::COLOR_GRAY2BGR);
    // Define the PIP region on the main frame
    cv::Mat enhancedPIPWithAlpha;
    cv::cvtColor(sharpenedPIP, enhancedPIPWithAlpha, cv::COLOR_BGR2BGRA);
    enhancedPIPWithAlpha.copyTo(in_mat(pipRect));
    // Cache the enhanced PIP frame
    pip->cached_frames[frame_meta->source_id] = enhancedPIPWithAlpha.clone();
    pip->cached_timestamps[frame_meta->source_id] = std::chrono::steady_clock::now();
    return GST_FLOW_OK;
Is there a way to do the above but keep the frame in GPU memory instead of bringing it down to CPU? I see this new CV-CUDA library(GitHub - CVCUDA/CV-CUDA: CV-CUDA™ is an open-source, GPU accelerated library for cloud-scale image processing and computer vision.) but it looks to be in BETA release right now.
The DeepStream is designed based on NvBufSurface, NvBufSurface support different NvBufSurfaceMemType and NvBufSurfaceLayout for different types of device buffers on dGPU and Jetson.
The VPI VPIImageBufferType and VPIImageBuffer interfaces shows that it supports different types of memory type and layout too.
To map the NvBufSurface to VPIImageBuffer needs to match the NvBufSurfaceMemType and NvBufSurfaceLayout to the corresponding VPIImageBufferType and VPIImageBuffer. Theoretically it is possible.
We don’t have sample for this.
