I am trying to convert an NvBufSurface frame to a VPIImage so that I can do cropped bounding box enhancements to create a PIP(Picture-in-Picture) in the bottom right hand of the output RTSP Video Stream. Currently, I am doing this today using OpenCV operations but I have to take the NvBufSurface from GPU->CPU->GPU which adds a lot of overhead.
Is there a way to convert the NvBufSurface to a VPIImage properly while keeping it in GPU memory to do the image operations(EqualizaeHistogram and Median Filter)?
Today I do this with the following 3 methods using OpenCV for the digital image enhancement and adding of the Picture-in-Picture(PIP) to the original frame:
static GstFlowReturn get_converted_mat(GstPip *pip, NvBufSurface *input_buf, gint idx,
NvOSD_RectParams *crop_rect_params, gdouble &ratio, gint input_width,
gint input_height) {
NvBufSurfTransform_Error err;
NvBufSurfTransformConfigParams transform_config_params;
NvBufSurfTransformParams transform_params;
NvBufSurfTransformRect src_rect;
NvBufSurfTransformRect dst_rect;
NvBufSurface ip_surf;
cv::Mat in_mat;
ip_surf = *input_buf;
ip_surf.numFilled = ip_surf.batchSize = 1;
ip_surf.surfaceList = &(input_buf->surfaceList[idx]);
gint src_left = GST_ROUND_UP_2((unsigned int)crop_rect_params->left);
gint src_top = GST_ROUND_UP_2((unsigned int)crop_rect_params->top);
gint src_width = GST_ROUND_DOWN_2((unsigned int)crop_rect_params->width);
gint src_height = GST_ROUND_DOWN_2((unsigned int)crop_rect_params->height);
// Calculate the extra padding for the object (12.5% of width and height)
gint padding_width = src_width * 0.25;
gint padding_height = src_height * 0.25;
// Adjust left, top, width, and height while ensuring they remain within the
// frame bounds
src_left = std::max(0, src_left - padding_width);
src_top = std::max(0, src_top - padding_height);
src_width = std::min(input_width - src_left, src_width + 2 * padding_width);
src_height = std::min(input_height - src_top, src_height + 2 * padding_height);
/* Maintain aspect ratio */
double hdest = pip->processing_width * src_height / (double)src_width;
double wdest = pip->processing_height * src_width / (double)src_height;
guint dest_width, dest_height;
if (hdest <= pip->processing_height) {
dest_width = pip->processing_width;
dest_height = hdest;
} else {
dest_width = wdest;
dest_height = pip->processing_height;
/* Configure transform session parameters for the transformation */
transform_config_params.compute_mode = NvBufSurfTransformCompute_Default;
transform_config_params.gpu_id = pip->gpu_id;
transform_config_params.cuda_stream = pip->cuda_stream;
/* Set the transform session parameters for the conversions executed in this
* thread. */
err = NvBufSurfTransformSetSessionParams(&transform_config_params);
if (err != NvBufSurfTransformError_Success) {
NVGSTDS_ERR_MSG_V("NvBufSurfTransformSetSessionParams failed with error %d", err);
goto error;
/* Calculate scaling ratio while maintaining aspect ratio */
ratio = MIN(1.0 * dest_width / src_width, 1.0 * dest_height / src_height);
if ((crop_rect_params->width == 0) || (crop_rect_params->height == 0)) {
NVGSTDS_ERR_MSG_V("Crop rect params dimensions are zero");
goto error;
#ifdef __aarch64__
if (ratio <= 1.0 / 16 || ratio >= 16.0) {
/* Currently cannot scale by ratio > 16 or < 1/16 for Jetson */
NVGSTDS_ERR_MSG_V("Cannot scale by ratio > 16 or < 1/16 for Jetson.");
goto error;
#endif
/* Set the transform ROIs for source and destination */
src_rect = {(guint)src_top, (guint)src_left, (guint)src_width, (guint)src_height};
dst_rect = {0, 0, (guint)dest_width, (guint)dest_height};
/* Set the transform parameters */
transform_params.src_rect = &src_rect;
transform_params.dst_rect = &dst_rect;
transform_params.transform_flag =
NVBUFSURF_TRANSFORM_FILTER | NVBUFSURF_TRANSFORM_CROP_SRC | NVBUFSURF_TRANSFORM_CROP_DST;
transform_params.transform_filter = NvBufSurfTransformInter_Default;
/* Memset the memory */
NvBufSurfaceMemSet(pip->inter_buf, 0, 0, 0);
/* Transformation scaling+format conversion if any. */
err = NvBufSurfTransform(&ip_surf, pip->inter_buf, &transform_params);
NVGSTDS_ERR_MSG_V("NvBufSurfTransform failed with error %d while converting buffer", err);
goto error;
/* Map the buffer so that it can be accessed by CPU */
if (NvBufSurfaceMap(pip->inter_buf, 0, 0, NVBUF_MAP_READ) != 0) {
goto error;
if (pip->inter_buf->memType == NVBUF_MEM_SURFACE_ARRAY) {
/* Cache the mapped data for CPU access */
NvBufSurfaceSyncForCpu(pip->inter_buf, 0, 0);
/* Use openCV to remove padding and convert RGBA to BGR. Can be skipped if
* algorithm can handle padded RGBA data. */
in_mat = cv::Mat(pip->processing_height, pip->processing_width, CV_8UC4,
pip->inter_buf->surfaceList[0].mappedAddr.addr[0], pip->inter_buf->surfaceList[0].pitch);
#if (CV_MAJOR_VERSION >= 4)
cv::cvtColor(in_mat, *pip->cvmat, cv::COLOR_RGBA2BGR);
#else
cv::cvtColor(in_mat, *pip->cvmat, CV_RGBA2BGR);
#endif
if (NvBufSurfaceUnMap(pip->inter_buf, 0, 0)) {
goto error;
/* We will first convert only the Region of Interest (the entire frame or
* the object bounding box) to RGB and then scale the converted RGB frame to
* processing resolution. */
return GST_FLOW_OK;
error:
return GST_FLOW_ERROR;
* Calculates an objects cropped region
static GstFlowReturn calculate_object_region(NvBufSurface *surface, NvDsFrameMeta *frame_meta, int &pipWidth,
int &pipHeight, int &pipPosX, int &pipPosY) {
pipWidth = static_cast<int>(surface->surfaceList[frame_meta->batch_id].planeParams.width[0] * 0.2);
pipHeight = static_cast<int>(surface->surfaceList[frame_meta->batch_id].planeParams.height[0] * 0.2);
pipPosX = surface->surfaceList[frame_meta->batch_id].planeParams.width[0] - pipWidth;
pipPosY = surface->surfaceList[frame_meta->batch_id].planeParams.height[0] - pipHeight;
if ((pipWidth == 0) || (pipHeight == 0)) {
NVGSTDS_ERR_MSG_V("PIP dimensions are zero");
return GST_FLOW_OK;
* Digitially enhances an object and inserts this into a PIP into the frame
static GstFlowReturn digitally_enhance_object(GstPip *pip, NvBufSurface *surface, NvDsFrameMeta *frame_meta,
cv::Mat &in_mat) {
// Enhance the PIP using OpenCV
cv::Mat enhancedPIP;
// Increase brightness and contrast
pip->cvmat->convertTo(enhancedPIP, -1, 1.2, 25);
// Calculate PIP size and position
int pipWidth, pipHeight, pipPosX, pipPosY;
if (calculate_object_region(surface, frame_meta, pipWidth, pipHeight, pipPosX, pipPosY) != GST_FLOW_OK) {
// Resize the enhanced PIP
cv::resize(enhancedPIP, enhancedPIP, cv::Size(pipWidth, pipHeight));
// Noise Reduction using Median Blur
cv::medianBlur(enhancedPIP, enhancedPIP, 3); // Add Noise Reduction
// Bilateral Filter to reduce noise
cv::Mat bilateralFilteredPIP;
cv::bilateralFilter(enhancedPIP, bilateralFilteredPIP, 9, 75, 75);
// Sharpening
cv::Mat kernel = (cv::Mat_<float>(3, 3) << -1, -1, -1, -1, 9, -1, -1, -1, -1);
cv::Mat sharpenedPIP;
cv::filter2D(bilateralFilteredPIP, sharpenedPIP, -1, kernel);
// Adaptive Histogram Equalization (CLAHE)
cv::Mat grayPIP, clahePIP;
cv::cvtColor(sharpenedPIP, grayPIP, cv::COLOR_BGR2GRAY);
clahe->setClipLimit(2.0);
clahe->apply(grayPIP, clahePIP);
cv::cvtColor(clahePIP, sharpenedPIP, cv::COLOR_GRAY2BGR);
// Define the PIP region on the main frame
cv::Rect pipRect(pipPosX, pipPosY, pipWidth, pipHeight);
cv::Mat enhancedPIPWithAlpha;
cv::cvtColor(sharpenedPIP, enhancedPIPWithAlpha, cv::COLOR_BGR2BGRA);
enhancedPIPWithAlpha.copyTo(in_mat(pipRect));
// Cache the enhanced PIP frame
pip->cached_frames[frame_meta->source_id] = enhancedPIPWithAlpha.clone();
pip->cached_timestamps[frame_meta->source_id] = std::chrono::steady_clock::now();
return GST_FLOW_OK;
The output looks like so:
