• Hardware Platform (Jetson Orin NX)
• DeepStream Version: 7.0
I am currently working with a code that performs various operations like cropping, resizing, denoising, and sharpening on video frames. While the code itself is functioning correctly and processing the frames as expected, the output render does not appear as visually appealing as I had hoped.
Could you kindly help me identify the potential cause of this issue , Your assistance in resolving this would be greatly appreciated. Here I attaching my code and output.
#include <gst/gst.h>
#include <opencv2/opencv.hpp>
#include <cuda_runtime.h>
#include "gstnvdsmeta.h"
#include "nvdsmeta.h"
static GstPadProbeReturn nvvidconv_src_pad_buffer_probe(GstPad *pad, GstPadProbeInfo *info, gpointer u_data) {
GstBuffer *buf = GST_PAD_PROBE_INFO_BUFFER(info);
if (!buf) {
g_print("No buffer found.\n");
return GST_PAD_PROBE_OK;
GstMapInfo inmap = GST_MAP_INFO_INIT;
if (!gst_buffer_map(buf, &inmap, GST_MAP_READWRITE)) {
g_print("Failed to map buffer.\n");
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta(buf);
if (!batch_meta) {
g_print("No batch meta found.\n");
gst_buffer_unmap(buf, &inmap);
for (NvDsMetaList *l_frame = batch_meta->frame_meta_list; l_frame != NULL; l_frame = l_frame->next) {
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *)l_frame->data;
guint width = frame_meta->source_frame_width;
guint height = frame_meta->source_frame_height;
if (width == 0 || height == 0) {
g_print("Invalid frame dimensions: %d x %d\n", width, height);
continue;
// Convert NV12 to BGR
cv::Mat nv12_mat(height * 3 / 2, width, CV_8UC1, inmap.data);
cv::Mat bgr_frame;
cv::cvtColor(nv12_mat, bgr_frame, cv::COLOR_YUV2BGR_NV12);
// Define cropping parameters
int x = 300, y = 300;
int crop_width = 60, crop_height = 60;
int x_start = std::max(0, x - crop_width / 2);
int y_start = std::max(0, y - crop_height / 2);
guint x_end = std::min((guint)width, (guint)(x + crop_width / 2));
guint y_end = std::min((guint)height, (guint)(y + crop_height / 2));
int crop_width_actual = x_end - x_start;
int crop_height_actual = y_end - y_start;
crop_width_actual = std::min(crop_width_actual, crop_width);
crop_height_actual = std::min(crop_height_actual, crop_height);
// Perform the cropping operation
cv::Rect crop_roi(x_start, y_start, crop_width_actual, crop_height_actual);
cv::Mat cropped_frame = bgr_frame(crop_roi);
// Resize the cropped frame
cv::Mat resized_frame;
cv::resize(cropped_frame, resized_frame, cv::Size(cropped_frame.cols * 2, cropped_frame.rows * 2), 0, 0, cv::INTER_CUBIC);
// Denoise the resized frame
//cv::fastNlMeansDenoising(resized_frame, resized_frame, 7, 7, 21);
// Apply sharpening kernel
cv::Mat sharpening_kernel = (cv::Mat_<float>(3, 3) <<
0, -1, 0,
-1, 5, -1,
0, -1, 0);
cv::filter2D(resized_frame, resized_frame, -1, sharpening_kernel);
// Draw a red boundary around the resized frame
cv::rectangle(resized_frame, cv::Point(0, 0), cv::Point(resized_frame.cols, resized_frame.rows), cv::Scalar(0, 0, 255), 4);
// Overlay the resized frame back onto the original frame
int overlay_x = std::max(0, x_start); // Ensure overlay starts within frame
int overlay_y = std::max(0, y_start);
int overlay_width = std::min(resized_frame.cols, bgr_frame.cols - overlay_x);
int overlay_height = std::min(resized_frame.rows, bgr_frame.rows - overlay_y);
if (overlay_width > 0 && overlay_height > 0) {
resized_frame(cv::Rect(0, 0, overlay_width, overlay_height))
.copyTo(bgr_frame(cv::Rect(overlay_x, overlay_y, overlay_width, overlay_height)));
// Convert the final frame back to NV12
cv::Mat nv12_converted;
cv::cvtColor(bgr_frame, nv12_converted, cv::COLOR_BGR2YUV_YV12);
memcpy(inmap.data, nv12_converted.data, nv12_converted.total());
static gboolean
bus_call (GstBus * bus, GstMessage * msg, gpointer data)
GMainLoop *loop = (GMainLoop *) data;
switch (GST_MESSAGE_TYPE (msg)) {
case GST_MESSAGE_EOS:
g_print ("End of stream\n");
g_main_loop_quit (loop);
break;
case GST_MESSAGE_ERROR:{
gchar *debug;
GError *error;
gst_message_parse_error (msg, &error, &debug);
g_printerr ("ERROR from element %s: %s\n",
GST_OBJECT_NAME (msg->src), error->message);
if (debug)
g_printerr ("Error details: %s\n", debug);
g_free (debug);
g_error_free (error);
break;
default:
break;
return TRUE;
int main(int argc, char *argv[]) {
GMainLoop *loop = NULL;
GstElement *pipeline = NULL, *source = NULL, *h264parser = NULL, *decoder = NULL,
*streammux = NULL, *sink = NULL, *nvvidconv = NULL, *nvosd = NULL, *capsfilter = NULL;
GstBus *bus = NULL;
guint bus_watch_id;
GstPad *nvvidconv_sink_pad = NULL;
gboolean yaml_config = FALSE;
//NvDsGieType pgie_type = NVDS_GIE_PLUGIN_INFER;
int current_device = -1;
cudaGetDevice(¤t_device);
struct cudaDeviceProp prop;
cudaGetDeviceProperties(&prop, current_device);
if (argc != 2) {
g_printerr("Usage: %s <yml file>\n", argv[0]);
g_printerr("OR: %s <H264 filename>\n", argv[0]);
return -1;
gst_init(&argc, &argv);
loop = g_main_loop_new(NULL, FALSE);
yaml_config = (g_str_has_suffix(argv[1], ".yml") ||
g_str_has_suffix(argv[1], ".yaml"));
pipeline = gst_pipeline_new("dstest1-pipeline");
source = gst_element_factory_make("filesrc", "file-source");
h264parser = gst_element_factory_make("h264parse", "h264-parser");
decoder = gst_element_factory_make("nvv4l2decoder", "nvv4l2-decoder");
streammux = gst_element_factory_make("nvstreammux", "stream-muxer");
nvvidconv = gst_element_factory_make("nvvideoconvert", "nvvideo-converter");
nvosd = gst_element_factory_make("nvdsosd", "nv-onscreendisplay");
capsfilter = gst_element_factory_make("capsfilter", "filter");
g_object_set(G_OBJECT(capsfilter), "caps", gst_caps_from_string("video/x-raw"), NULL);
if (prop.integrated) {
sink = gst_element_factory_make("nv3dsink", "nv3d-sink");
} else {
sink = gst_element_factory_make("nv3dsink", "nvvideo-renderer");
if (!source || !h264parser || !decoder || !nvvidconv || !sink || !capsfilter) {
g_printerr("One element could not be created. Exiting.\n");
return -1;
g_object_set(G_OBJECT(source), "location", argv[1], NULL);
g_object_set(G_OBJECT(streammux), "batch-size", 1, NULL);
g_object_set(G_OBJECT(streammux), "width", 1280, "height", 720, "batched-push-timeout", 4000000, NULL);
bus = gst_pipeline_get_bus(GST_PIPELINE(pipeline));
bus_watch_id = gst_bus_add_watch(bus, bus_call, loop);
gst_object_unref(bus);
gst_bin_add_many(GST_BIN(pipeline), source, h264parser, decoder, streammux, nvosd,nvvidconv, capsfilter, sink, NULL);
GstPad *sinkpad, *srcpad;
gchar pad_name_sink[16] = "sink_0";
gchar pad_name_src[16] = "src";
sinkpad = gst_element_request_pad_simple(streammux, pad_name_sink);
if (!sinkpad) {
g_printerr("Streammux request sink pad failed. Exiting.\n");
return -1;
srcpad = gst_element_get_static_pad(decoder, pad_name_src);
if (!srcpad) {
g_printerr("Decoder request src pad failed. Exiting.\n");
return -1;
if (gst_pad_link(srcpad, sinkpad) != GST_PAD_LINK_OK) {
g_printerr("Failed to link decoder to stream muxer. Exiting.\n");
return -1;
gst_object_unref(sinkpad);
gst_object_unref(srcpad);
if (!gst_element_link_many(source, h264parser, decoder, NULL)) {
g_printerr("Elements could not be linked: 1. Exiting.\n");
return -1;
// Adjusted pipeline linking order with probe at nvvidconv
if (!gst_element_link_many(streammux, nvosd,nvvidconv, capsfilter, sink, NULL)) {
g_printerr("Elements could not be linked: 2. Exiting.\n");
return -1;
// Add probe to nvvidconv's source pad
nvvidconv_sink_pad = gst_element_get_static_pad(nvvidconv, "src");
if (nvvidconv_sink_pad) {
gst_pad_add_probe(nvvidconv_sink_pad, GST_PAD_PROBE_TYPE_BUFFER, nvvidconv_src_pad_buffer_probe, NULL, NULL);
gst_object_unref(nvvidconv_sink_pad);
gst_element_set_state(pipeline, GST_STATE_PLAYING);
g_main_loop_run(loop);
gst_element_set_state(pipeline, GST_STATE_NULL);
gst_object_unref(GST_OBJECT(pipeline));
g_source_remove(bus_watch_id);
g_main_loop_unref(loop);
return 0;
Output of streaming:
Thank you in advance for your time and support.
Best regards,
Abdul Manaf PV
