Trying to perform camera undistortion using VPI with VIC backend in gstreamer combining two examples, /opt/nvidia/vpi2/samples/11-fisheye and nvsample_cudaprocess. In the nvsample_cudaprocess.cu gpu_process function using vpiSubmitRemap similar to 11-fisheye/main.cpp main function, but first attempting to convert EGLImageKHR to VPIImage using vpiImageCreateEGLImageWrapper. Following snippet part of nvsample_cudaprocess.cu gpu_process used to work with vpi1
vpiImageCreateEGLImageWrapper(image, NULL, VPI_BACKEND_CUDA, &vimg);
vpiSubmitConvertImageFormat(stream, VPI_BACKEND_CUDA, vimg, tmpIn, NULL);
vpiSubmitRemap(stream, VPI_BACKEND_CUDA, remap, tmpIn, tmpOut, VPI_INTERP_CATMULL_ROM, VPI_BORDER_ZERO, 0);
vpiSubmitConvertImageFormat(stream, VPI_BACKEND_CUDA, tmpOut, vimg, NULL);
vpiStreamSync(stream);
using
gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1’ ! nvivafilter cuda-process=true customer-lib-name=“libnvsample_cudaprocess.so” ! ‘video/x-raw(memory:NVMM), format=(string)NV12’ ! nvoverlaysink display-id=0 -e
Problem is that vpi/EGLInterop.h is missing in vpi2 so it doesn’t work, is there a substitute for or sample of equivalent vpiImageCreateEGLImageWrapper in vpi2? There is a similar topic VPI in a GStreamer pipeline but likely using vpi1.
Side issue with Remap is that 1080p NV12 latency using CUDA backend is favorable to VIC but it doesn’t compare percentage of GPU utilized?
