You may have to register clients and manage ressources for each.
So far I assume the same thread is running calls to gpu_process for each running instance, so checking there can help.
I’ve quickly tried, the following is far from clean code but it seems working as a starting point just running 2 pipelines. Not tried what if dynamically creating/destroying pipelines, nor evaluated the overhead and limitations. You may improve and share.
rotation_filter.cu
* Copyright (c) 2016, NVIDIA CORPORATION. All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of NVIDIA CORPORATION nor the names of its
* contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS ``AS IS'' AND ANY
* EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
* PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
* OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <sys/types.h>
#include <unistd.h>
#include <sys/syscall.h>
#include <map>
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include <vpi/Context.h>
#include <vpi/Image.h>
#include <vpi/Status.h>
#include <vpi/Stream.h>
#include <vpi/algo/ConvertImageFormat.h>
#include <vpi/WarpMap.h>
#include <vpi/algo/Remap.h>
#include <vpi/EGLInterop.h>
#include "cudaEGL.h"
#define CHECK_VPI_STATUS(STMT) do { \
VPIStatus status = (STMT); \
if (status != VPI_SUCCESS) \
char buffer[VPI_MAX_STATUS_MESSAGE_LENGTH]; \
vpiGetLastStatusMessage(buffer, sizeof(buffer)); \
printf ("Error: %s in %s at line %d (%s)\n", \
vpiStatusGetName(status), __FILE__, __LINE__, buffer); \
} while (0);
extern "C" void Handle_EGLImage (EGLImageKHR image);
extern "C" {
typedef enum {
COLOR_FORMAT_Y8 = 0,
COLOR_FORMAT_U8_V8,
COLOR_FORMAT_RGBA,
COLOR_FORMAT_NONE
} ColorFormat;
typedef struct {
* cuda-process API
* @param image : EGL Image to process
* @param userPtr : point to user alloc data, should be free by user
void (*fGPUProcess) (EGLImageKHR image, void ** userPtr);
void (*fPreProcess)(void **sBaseAddr, unsigned int *smemsize, unsigned int *swidth, unsigned int *sheight, unsigned int *spitch, ColorFormat *sformat, unsigned int nsurfcount, void ** userPtr);
void (*fPostProcess)(void **sBaseAddr, unsigned int *smemsize, unsigned int *swidth, unsigned int *sheight, unsigned int *spitch, ColorFormat *sformat, unsigned int nsurfcount, void ** userPtr);
} CustomerFunction;
void init (CustomerFunction * pFuncs);
void deinit ();
typedef struct {
VPIImage vpi_image;
VPIImage inter_img;
VPIStream vpi_stream;
VPIWarpMap map;
VPIPayload warp;
} clientData;
static std::map<pid_t,clientData*> clientsMap;
clientData *
init_resources() {
int width = 1280;
int height = 720;
clientData *c = new clientData();
/* Create an identity map with a single dense region of size 1280x720. */
memset(&c->map, 0, sizeof(c->map));
c->map.grid.numHorizRegions = 1;
c->map.grid.numVertRegions = 1;
c->map.grid.regionWidth[0] = width;
c->map.grid.regionHeight[0] = height;
c->map.grid.horizInterval[0] = 1;
c->map.grid.vertInterval[0] = 1;
CHECK_VPI_STATUS(vpiWarpMapAllocData(&c->map));
CHECK_VPI_STATUS(vpiWarpMapGenerateIdentity(&c->map));
for (int i = 0; i < c->map.numVertPoints; ++i)
VPIKeypoint *row = (VPIKeypoint *)((uint8_t *)c->map.keypoints + c->map.pitchBytes * i);
for (int j = 0; j < c->map.numHorizPoints; ++j)
const float x = j - width / 2.0f;
const float y = i - height / 2.0f;
const float angle = M_PI / 3.0f;
row[j].x = x * cos(angle) - y * sin(angle) + width / 2.0f;
row[j].y = x * sin(angle) + y * cos(angle) + height / 2.0f;
CHECK_VPI_STATUS(vpiStreamCreate(VPI_BACKEND_CUDA, &c->vpi_stream));
CHECK_VPI_STATUS(vpiCreateRemap(VPI_BACKEND_CUDA, &c->map, &c->warp));
CHECK_VPI_STATUS(vpiImageCreate(width, height, VPI_IMAGE_FORMAT_NV12, 0, &c->inter_img));
printf("#### VPIImageImpl inter_img address: %p ####\n", c->inter_img);
return c;
* Performs CUDA Operations on egl image.
* @param image : EGL image
void
gpu_process (EGLImageKHR image, void ** usrptr)
pid_t tid = syscall(__NR_gettid);
clientData *c = clientsMap[tid];
if (!c) {
c = init_resources();
clientsMap[tid] = c;
//printf("Created ressources at %p for client %d\n", clientsMap[tid], tid);
//printf("Got client data at %p for thread %d\n", c, tid);
if (!c->vpi_image) {
//printf("Creating EGL Image wrapper\n");fflush(stdout);
vpiImageCreateEGLImageWrapper (image, NULL, VPI_BACKEND_CUDA, &c->vpi_image);
else {
//printf("Wrapping EGL Image\n");fflush(stdout);
vpiImageSetWrappedEGLImage (c->vpi_image, image);
CHECK_VPI_STATUS(vpiSubmitRemap(c->vpi_stream, 0, c->warp, c->vpi_image, c->inter_img, VPI_INTERP_LINEAR, VPI_BORDER_ZERO, 0));
CHECK_VPI_STATUS(vpiSubmitConvertImageFormat(c->vpi_stream, VPI_BACKEND_CUDA, c->inter_img, c->vpi_image, NULL));
CHECK_VPI_STATUS(vpiStreamSync(c->vpi_stream));
extern "C" void
pFuncs->fGPUProcess = gpu_process;
extern "C" void
deinit ()
std::map<pid_t,clientData*>::const_iterator it = clientsMap.begin();
while (it != clientsMap.end()) {
// pid_t tid = it->first;
clientData *c = it->second;
if (c->vpi_stream) {
vpiStreamDestroy (c->vpi_stream);
c->vpi_stream = NULL;
if (c->warp) {
vpiPayloadDestroy (c->warp);
c->warp = NULL;
if (c->inter_img) {
vpiImageDestroy (c->inter_img);
c->inter_img = NULL;
vpiWarpMapFreeData (&c->map);
delete c;
++it;
clientsMap.clear();
Otherwise, you may get the public source code of nvvidconv plugin that has similar implementation as nvivafilter, so you would be able to further customize the plugin for your processing.
