Thank you very much for the reply.
The purpose of my project is: to record a game and be able to put the score on top of the game, this video is captured through nvcamera and saved in mp4.
For now I’m trying to pipeline fully with VisionWorks, but I’m having a lot of problems… I have based on the example: /usr/share/visionworks/sources/samples/nvgstcamera_capture
1 - First I get the frame from std::unique_ptr<ovxio::FrameSource>, I have also tried to force RGB instead of RGBX but it has not worked.
2 - I change the color space from RGBX to RGB (vxuColorConvert).
3 - I select the area where I want the marker and I get that part and transform it to OpenCV Mat (VXImageToCVMatMapper).
4 - I paste the png of the marker on top of the clipping.
5 - I write anything.
6 I convert RGB to RGBX again.
Code:
# Copyright (c) 2015-2016, NVIDIA CORPORATION. All rights reserved.
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions
# are met:
# * Redistributions of source code must retain the above copyright
# notice, this list of conditions and the following disclaimer.
# * Redistributions in binary form must reproduce the above copyright
# notice, this list of conditions and the following disclaimer in the
# documentation and/or other materials provided with the distribution.
# * Neither the name of NVIDIA CORPORATION nor the names of its
# contributors may be used to endorse or promote products derived
# from this software without specific prior written permission.
# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS ``AS IS'' AND ANY
# EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
# PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
# CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
# EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
# PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
# PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
# OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
# (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
# OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <iostream>
#include <sstream>
#include <iomanip>
#include <memory>
#include <opencv2/opencv.hpp>
#include <opencv2/freetype.hpp>
#include <VX/vx.h>
#include <NVX/nvx_timer.hpp>
#include "OVX/FrameSourceOVX.hpp"
#include "OVX/RenderOVX.hpp"
#include "NVX/Application.hpp"
#include "OVX/UtilityOVX.hpp"
#include "NVX/nvx_opencv_interop.hpp"
//#include <opencv2/core.hpp>
//#include<opencv2/imgproc.hpp>
//#include <opencv2/highgui.hpp>
struct EventData
EventData(): alive(true), pause(false) {}
bool alive;
bool pause;
static void keyboardEventCallback(void* context, vx_char key, vx_uint32 /*x*/, vx_uint32 /*y*/)
EventData* eventData = static_cast<EventData*>(context);
if (key == 27) // escape
eventData->alive = false;
else if (key == 32)
eventData->pause = !eventData->pause;
static void parseResolution(const std::string & resolution, ovxio::FrameSource::Parameters & config)
std::istringstream stream(resolution);
std::string item;
vx_uint32 * frameParams[] = { &config.frameWidth, &config.frameHeight };
vx_uint32 index = 0;
while (std::getline(stream, item, 'x'))
std::stringstream ss(item);
ss >> *frameParams[index++];
void draw_transparency(
cv::Mat& bg,
cv::Mat counter,
cv::Mat* counter_rgb,
cv::Mat counter_mask
//cv::merge(counter_rgb, 3, counter);
counter.copyTo(bg, counter_mask);
// main - Application entry point
int main(int argc, char** argv)
nvxio::Application &app = nvxio::Application::get();
ovxio::printVersionInfo();
ovxio::FrameSource::Parameters config;
config.frameWidth = 1280;
config.frameHeight = 720;
//config.format = VX_DF_IMAGE_RGB;
// Parse command line arguments
std::string resolution = "1280x720", input = "device:///nvcamera";
app.setDescription("This sample captures frames from NVIDIA GStreamer camera");
app.addOption('r', "resolution", "Input frame resolution", nvxio::OptionHandler::oneOf(&resolution,
{ "2592x1944", "2592x1458", "1280x720", "640x480" }));
app.init(argc, argv);
parseResolution(resolution, config);
// Create OpenVX context
ovxio::ContextGuard context;
// Messages generated by the OpenVX framework will be processed by ovxio::stdoutLogCallback
vxRegisterLogCallback(context, &ovxio::stdoutLogCallback, vx_false_e);
// Create a Frame Source
std::unique_ptr<ovxio::FrameSource> source(ovxio::createDefaultFrameSource(context, input));
if (!source)
std::cout << "Error: cannot open source!" << std::endl;
return nvxio::Application::APP_EXIT_CODE_NO_RESOURCE;
if (!source->setConfiguration(config))
std::cout << "Error: cannot setup configuration the framesource!" << std::endl;
return nvxio::Application::APP_EXIT_CODE_INVALID_VALUE;
if (!source->open())
config = source->getConfiguration();
// Create a Render
//std::unique_ptr<ovxio::Render> render(ovxio::createVideoRender(context, "~/test.avi", config.frameWidth, config.frameHeight));
std::unique_ptr<ovxio::Render> render(ovxio::createDefaultRender(
context, "NVIDIA GStreamer Camera Capture Sample", config.frameWidth, config.frameHeight));
if (!render)
std::cout << "Error: Cannot open default render!" << std::endl;
return nvxio::Application::APP_EXIT_CODE_NO_RENDER;
EventData eventData;
render->setOnKeyboardEventCallback(keyboardEventCallback, &eventData);
vx_image frame = vxCreateImage(context, config.frameWidth,
config.frameHeight, config.format);
//nvx_cv::VXImageToCVMatMapper to_cv(frame);
NVXIO_CHECK_REFERENCE(frame);
nvx::Timer totalTimer;
totalTimer.tic();
SCOREBOARD
cv::Mat counter_orig = cv::imread("/home/totolia/nvgstcamera_capture/paddle_scoreboard.png", cv::IMREAD_UNCHANGED);
cv::Mat counter;
cv::cvtColor(counter_orig, counter, cv::COLOR_BGRA2RGBA); counter_orig.release();
cv::split(counter, counter_layers);
std::vector<cv::Mat> counter_rgb_list = {
counter_layers[0],
counter_layers[1],
counter_layers[2]
cv::Mat counter_rgb;
cv::merge(counter_rgb_list, counter_rgb); counter_rgb_list.release();
cv::Mat counter_mask = counter_layers[3]; counter_layers.release();
FONT
cv::Ptr<cv::freetype::FreeType2> ft_bold;
ft_bold = cv::freetype::createFreeType2();
ft_bold->loadFontData("/home/totolia/nvgstcamera_capture/fonts/Roboto-Bold.ttf", 0);
cv::Ptr<cv::freetype::FreeType2> ft_light;
ft_light = cv::freetype::createFreeType2();
ft_light->loadFontData("/home/totolia/nvgstcamera_capture/fonts/Roboto-Light.ttf", 0);
cv::Ptr<cv::freetype::FreeType2> ft_thin;
ft_thin = cv::freetype::createFreeType2();
ft_thin->loadFontData("/home/totolia/nvgstcamera_capture/fonts/Roboto-Thin.ttf", 0);
cv::Ptr<cv::freetype::FreeType2> ft_medium;
ft_medium = cv::freetype::createFreeType2();
ft_medium->loadFontData("/home/totolia/nvgstcamera_capture/fonts/Roboto-Medium.ttf", 0);
// tmp
vx_image frame_cpy = vxCreateImage(context, config.frameWidth, config.frameHeight, VX_DF_IMAGE_RGB);
while (eventData.alive)
ovxio::FrameSource::FrameStatus status = ovxio::FrameSource::OK;
if (!eventData.pause)
status = source->fetch(frame);
switch(status)
case ovxio::FrameSource::OK:
// RGBX -> RGB
vxuColorConvert(context, frame, frame_cpy);
// Compute ROI
int aux_w1 = ((int)config.frameWidth / 2) - ((int)counter.cols / 2);
int aux_w2 = aux_w1 + counter.cols;
vx_rectangle_t rect = {aux_w1, 0, aux_w2, counter.rows};
nvx_cv::VXImageToCVMatMapper to_cv(frame_cpy, 0, &rect, VX_READ_AND_WRITE, VX_MEMORY_TYPE_HOST);
// Paste counter -> ROI
cv::Mat draw_counter = to_cv.getMat();
counter_rgb.copyTo(draw_counter, counter_mask);
// Draw on ROI
ft_medium->putText(
draw_counter,
"1 - 1",
cv::Point(100, 150),
5,
cv::Scalar(0, 255, 0, 255),
-1,
8,
false
vxuColorConvert(context, frame_cpy, frame);
render->putImage(frame);
if (!render->flush())
eventData.alive = false;
break;
case ovxio::FrameSource::TIMEOUT:
// Do nothing
break;
case ovxio::FrameSource::CLOSED:
break;
// Release all objects
vxReleaseImage(&frame);
return nvxio::Application::APP_EXIT_CODE_SUCCESS;
I have also had to make some changes in the Makefile to incorporate the opencv library and the freetype (new version).
Code:
# Copyright (c) 2014-2016, NVIDIA CORPORATION. All rights reserved.
# are met:
# OS info
OSLOWER := $(shell uname -s 2>/dev/null | tr "[:upper:]" "[:lower:]")
OS_ARCH := $(shell uname -m | sed -e "s/i386/i686/")
# Take command line flags that override any of these settings
ifeq ($(i386),1)
OS_ARCH := i686
endif
ifeq ($(x86_64),1)
OS_ARCH := x86_64
endif
ifeq ($(ARMv7),1)
OS_ARCH := armv7l
endif
ifeq ($(ARMv8),1)
OS_ARCH := aarch64
endif
CXXFLAGS += -std=c++0x $(shell pkg-config --cflags opencv4)
CXXFLAGS += -DCUDA_API_PER_THREAD_DEFAULT_STREAM -DUSE_GUI=1 -DUSE_GLFW=1 -DUSE_GLES=1 -DUSE_GSTREAMER=1 -DUSE_NVGSTCAMERA=1 -DUSE_GSTREAMER_OMX=1
ifneq ($(VIBRANTE_TOOLCHAIN_SYSROOT),)
CCFLAGS += --sysroot="$(VIBRANTE_TOOLCHAIN_SYSROOT)"
endif
# Configuration-specific build flags
ifeq ($(dbg),1)
CCFLAGS += -g
TARGET := debug
else
CCFLAGS += -O3 -DNDEBUG
TARGET := release
endif
# check visionworks availability
VISION_WORKS_EXISTS := $(shell pkg-config --exists visionworks && echo "1" || echo "0")
ifeq ($(VISION_WORKS_EXISTS), 0)
$(error You must put directory containing visionworks.pc to the PKG_CONFIG_PATH environment variable)
endif
EXTERNAL_CFLAGS :=
EXTERNAL_LIBS :=
EXTERNAL_CFLAGS += $(shell pkg-config --cflags cudart-10.2)
EXTERNAL_LIBS += $(shell pkg-config --libs cudart-10.2)
EXTERNAL_CFLAGS += $(shell pkg-config --cflags visionworks)
EXTERNAL_LIBS += $(shell pkg-config --libs visionworks)
EXTERNAL_CFLAGS += $(shell pkg-config --cflags opencv4)
EXTERNAL_LIBS += $(shell pkg-config --libs opencv4)
EXTERNAL_CFLAGS += $(shell pkg-config --cflags freetype2)
EXTERNAL_LIBS += $(shell pkg-config --libs freetype2)
EIGEN_CFLAGS := -I../../3rdparty/eigen
NVXIO_CFLAGS := -I../../nvxio/include -I../../nvxio/src/ -I../../nvxio/src/NVX/
OVXIO_LIBS := ../../libs/$(OS_ARCH)/$(OSLOWER)/$(TARGET)$(if $(abi),/$(abi))/libovx.a
INCLUDES := $(EXTERNAL_CFLAGS)
INCLUDES +=
INCLUDES += $(NVXIO_CFLAGS)
INCLUDES += -I../../3rdparty/opengl -I../../3rdparty/glfw3/include #-I../../3rdparty/freetype/include
INCLUDES += $(EIGEN_CFLAGS)
# to ensure correct linkage with NVIDIA GLES if MESA version is installed
LIBRARIES += -L"$(PKG_CONFIG_SYSROOT_DIR)/usr/lib"
LIBRARIES += -L"$(VIBRANTE_TOOLCHAIN_SYSROOT)/usr/lib"
endif
LIBRARIES += $(OVXIO_LIBS)
#../../3rdparty/freetype/libs/libfreetype.a
LIBRARIES += ../../3rdparty/glfw3/libs/libglfw3.a /usr/lib/aarch64-linux-gnu/tegra-egl/libGLESv2_nvidia.so.2 -L/usr/lib/aarch64-linux-gnu -lEGL $(shell pkg-config --libs xrandr xi xxf86vm x11)
LIBRARIES += $(shell pkg-config --libs gstreamer-base-1.0 gstreamer-pbutils-1.0 gstreamer-app-1.0)
LIBRARIES += /usr/lib/aarch64-linux-gnu/tegra/libcuda.so
LIBRARIES += $(EXTERNAL_LIBS)
LIBRARIES +=
LDFLAGS += -Wl,--allow-shlib-undefined -pthread
ifneq ($(PKG_CONFIG_SYSROOT_DIR),)
ifeq ($(ARMv7),1)
LDFLAGS += -Wl,-rpath-link="$(PKG_CONFIG_SYSROOT_DIR)/lib/arm-linux-gnueabihf"
LDFLAGS += -Wl,-rpath-link="$(PKG_CONFIG_SYSROOT_DIR)/usr/lib"
LDFLAGS += -Wl,-rpath-link="$(PKG_CONFIG_SYSROOT_DIR)/usr/lib/arm-linux-gnueabihf"
endif
endif
# show libraries used by linker in debug mode
ifeq ($(dbg),1)
LDFLAGS += -Wl,--trace
endif
CUDA_LIB_PATH := $(subst -L$(PKG_CONFIG_SYSROOT_DIR),,$(shell pkg-config --libs-only-L cudart-10.2))
LDFLAGS += -Wl,-rpath=$(CUDA_LIB_PATH)
CPP_FILES := $(wildcard *.cpp)
OBJ_DIR := obj/$(TARGET)
OBJ_FILES_CPP := $(addprefix $(OBJ_DIR)/,$(notdir $(CPP_FILES:.cpp=.o)))
OUTPUT_DIR := ../../bin/$(OS_ARCH)/$(OSLOWER)/$(TARGET)$(if $(abi),/$(abi))
# Target rules
all: build
build: $(OUTPUT_DIR)/nvx_sample_nvgstcamera_capture
$(OBJ_DIR):
mkdir -p $(OBJ_DIR)
$(OBJ_DIR)/%.o: %.cpp | $(OBJ_DIR)
$(CXX) $(INCLUDES) $(CCFLAGS) $(CXXFLAGS) -o $@ -c $<
$(OUTPUT_DIR):
mkdir -p $(OUTPUT_DIR)
$(OUTPUT_DIR)/nvx_sample_nvgstcamera_capture: $(OBJ_FILES_CPP) $(OVXIO_LIBS) | $(OUTPUT_DIR)
$(CXX) $(LDFLAGS) $(CCFLAGS) $(CXXFLAGS) -o $@ $^ $(LIBRARIES)
run: build
./$(OUTPUT_DIR)/nvx_sample_nvgstcamera_capture
clean:
rm -f $(OBJ_FILES_CPP)
rm -f $(OUTPUT_DIR)/nvx_sample_nvgstcamera_capture
$(OVXIO_LIBS):
+@$(MAKE) -C ../../nvxio
Is it the proper way to do it? For now I only get errors or messages similar to: an image can be accesed only once at a time.
Many thanks, Adrià
