I want to use VisionWorks for my application to process video from an IP-camera.
I can get the video stream with gstreamer, the pipeline is:
rtspsrc–>rtph264depay–>h264parse–>omxh264dec–>[nvvidconv]–>appsink
So, I create my GStreamerFrameSourceImpl in nvxio, but it doesn’t work.
IS there some advice?
the code is :
#ifdef USE_RTSPCAMERA
#include <memory>
#include <map>
#include <gst/gst.h>
#include <NVX/Application.hpp>
#include "GStreamerRtspFrameSourceImpl.hpp"
#include <cuda_runtime_api.h>
#include <sstream>
namespace nvidiaio
struct NvRtspCameraConfigs
vx_uint32 frameWidth, frameHeight, fps;
static const NvRtspCameraConfigs configs[6] =
{ vx_uint32(1920), vx_uint32(1080), vx_uint32(25) }, // 0
{ vx_uint32(1280), vx_uint32(720), vx_uint32(25) }, // 1
{ vx_uint32(704), vx_uint32(576) , vx_uint32(25) }, // 2
{ vx_uint32(1920), vx_uint32(1080), vx_uint32(50) }, // 3
{ vx_uint32(1280), vx_uint32(720), vx_uint32(50) }, // 4
{ vx_uint32(704), vx_uint32(576), vx_uint32(50) } // 5
GStreamerRtspFrameSourceImpl::GStreamerRtspFrameSourceImpl(const std::string & path) :
GStreamerEGLStreamSinkFrameSourceImpl(nvxio::FrameSource::CAMERA_SOURCE, "GStreamerRtspFrameSource", false),
rtspLinkAddress(path)
void GStreamerRtspFrameSourceImpl::RtspSrcPadAdded(GstElement *src,GstPad *pad,gpointer *data)
GstElement *depay = (GstElement *)data;
std::unique_ptr<GstPad, GStreamerObjectDeleter> sinkpad(gst_element_get_static_pad(depay, "sink"));
if(!sinkpad)
std::cout<<"Cannot get sinkpad(rtspdepay)!"<<std::endl;
else
std::cout<<"The sinkpad name is:"<<gst_pad_get_name(sinkpad.get())<<std::endl;
if(pad)
std::cout<<"The new pad name is:"<<gst_pad_get_name(pad)<<std::endl;
if(!gst_pad_is_linked(sinkpad.get()))
GstPadLinkReturn ret = gst_pad_link(pad,sinkpad.get());
if(ret == GST_PAD_LINK_OK)
std::cout<<std::endl<<"Link rtspsrc pad succeed!"<<std::endl;
else
switch(ret)
case GST_PAD_LINK_OK:
std::cout<<std::endl<<"GST_PAD_LINK_OK"<<std::endl;
break;
case GST_PAD_LINK_WRONG_HIERARCHY:
std::cout<<std::endl<<"GST_PAD_LINK_WRONG_HIERARCHY"<<std::endl;
break;
case GST_PAD_LINK_WAS_LINKED:
std::cout<<std::endl<<"GST_PAD_LINK_WAS_LINKED"<<std::endl;
break;
case GST_PAD_LINK_WRONG_DIRECTION:
std::cout<<std::endl<<"GST_PAD_LINK_WRONG_DIRECTION"<<std::endl;
break;
case GST_PAD_LINK_NOFORMAT:
std::cout<<std::endl<<"GST_PAD_LINK_NOFORMAT"<<std::endl;
break;
case GST_PAD_LINK_NOSCHED:
std::cout<<std::endl<<"GST_PAD_LINK_NOSCHED"<<std::endl;
break;
case GST_PAD_LINK_REFUSED:
std::cout<<std::endl<<"GST_PAD_LINK_REFUSED"<<std::endl;
break;
default:
std::cout<<std::endl<<"GST_PAD_LINK_UNKNOW_REASON"<<std::endl;
break;
std::cout<<std::endl<<"Link rtspsrc pad failed!"<<std::endl;
else
std::cout<<std::endl<<"rtspsrc pad has been linked!"<<std::endl;
bool GStreamerRtspFrameSourceImpl::setConfiguration(const FrameSource::Parameters& params)
NVXIO_ASSERT(end);
configuration.frameHeight = params.frameHeight;
configuration.frameWidth = params.frameWidth;
configuration.fps = params.fps;
NVXIO_ASSERT((params.format == NVXCU_DF_IMAGE_NV12) ||
(params.format == NVXCU_DF_IMAGE_U8) ||
(params.format == NVXCU_DF_IMAGE_RGB) ||
(params.format == NVXCU_DF_IMAGE_RGBX)||
(params.format == NVXCU_DF_IMAGE_NONE));
configuration.format = params.format;
return true;
bool GStreamerRtspFrameSourceImpl::InitializeGstPipeLine()
//default configration 1920*1080/25fps
NvRtspCameraConfigs rtspcameraconfig = configs[2];
if ((configuration.frameWidth != (vx_uint32)-1)&&
(configuration.frameHeight != (vx_uint32)-1))
rtspcameraconfig.frameWidth = configuration.frameWidth;
rtspcameraconfig.frameHeight = configuration.frameHeight;
rtspcameraconfig.fps = 25;
// select FPS default for the specified config
for (vx_size i = 0; i < ovxio::dimOf(configs); ++i)
if ((rtspcameraconfig.frameWidth == configs[i].frameWidth) &&
(rtspcameraconfig.frameHeight == configs[i].frameHeight))
rtspcameraconfig.fps = configs[i].fps;
break;
if (configuration.fps == (vx_uint32)-1)
configuration.fps = rtspcameraconfig.fps;
end = true;
//init gst pipeline
GstStateChangeReturn status;
pipeline = GST_PIPELINE(gst_pipeline_new(nullptr));
if (!pipeline)
NVXIO_PRINT("Cannot create Gstreamer pipeline");
return false;
bus = gst_pipeline_get_bus(GST_PIPELINE (pipeline));
GstElement *m_rtspsrc = gst_element_factory_make("rtspsrc","rtspsrc");
GstElement *m_rtspdepay = gst_element_factory_make("rtph264depay","rtspdepay");
GstElement *m_h264parse = gst_element_factory_make("h264parse",nullptr);
GstElement *m_h264dec = gst_element_factory_make("omxh264dec",nullptr);
GstElement *m_videoconvert = gst_element_factory_make("nvvidconv",nullptr);
GstElement *m_nvvideosink = gst_element_factory_make("nvvideosink", nullptr);
if(!m_rtspsrc || !m_rtspdepay || !m_h264parse || ! m_h264dec || !m_videoconvert || !m_nvvideosink)
std::cout<<"Cannot create Gstreamer Elements"<<std::endl;
FinalizeGstPipeLine();
return false;
//add elements to pipeline
gst_bin_add_many(GST_BIN(pipeline),m_rtspsrc,m_rtspdepay,m_h264parse,m_h264dec,m_videoconvert,m_nvvideosink,NULL);
//Config rtspsrc elements
g_object_set(G_OBJECT(m_rtspsrc),"location","rtsp://192.168.99.202:554/Streaming/Channels/102",
"latency",100,
"user-id","admin",
"user-pw","admin12345",
nullptr);
//Config nvvideosink element
std::ostringstream stream;
stream.str(std::string());
stream << "video/x-raw(memory:NVMM), width=(int)" << rtspcameraconfig.frameWidth << ", "
"height=(int)" << rtspcameraconfig.frameHeight << ", format=(string){I420}, "
"framerate=(fraction)" << rtspcameraconfig.fps << "/1;";
std::unique_ptr<GstCaps, GStreamerObjectDeleter> caps_nvvidconv(
gst_caps_from_string(stream.str().c_str()));
if (!caps_nvvidconv)
std::cout<<"Failed to create caps"<<std::endl;
return false;
std::cout<< std::endl <<"The filter caps is:"<<gst_caps_to_string(caps_nvvidconv.get())<<std::endl;
gboolean ret = gst_element_link_filtered(m_videoconvert,m_nvvideosink,caps_nvvidconv.get());
if(!ret)
std::cout<<"hello,link filtered error!"<<std::endl;
return false;
g_object_set(G_OBJECT(m_nvvideosink),
"display", context.display,
"stream", context.stream,
"fifo", fifoMode,
"max-lateness", G_GINT64_CONSTANT(-1),
"throttle-time", G_GUINT64_CONSTANT(0),
"render-delay", G_GUINT64_CONSTANT(0),
"qos", FALSE,
"sync", FALSE,
"async",TRUE,
nullptr);
g_object_set(G_OBJECT(m_nvvideosink),"outcaps",caps_nvvidconv.get(),nullptr);
// link elements
if (!gst_element_link_many(m_rtspdepay,m_h264parse,m_h264dec,m_videoconvert,NULL))
std::cout<<"GStreamer: cannot link color -> sink"<<std::endl;
return false;
//link pad-added singnal for rtspsrc-->rtph264depay
g_signal_connect(m_rtspsrc,"pad-added",G_CALLBACK(GStreamerRtspFrameSourceImpl::RtspSrcPadAdded),m_rtspdepay);
// Force pipeline to play video as fast as possible, ignoring system clock
gst_pipeline_use_clock(pipeline, nullptr);
status = gst_element_set_state((GstElement*)pipeline, GST_STATE_PLAYING);
handleGStreamerMessages();
if (status == GST_STATE_CHANGE_ASYNC)
std::cout<<"The pipeline will start async!"<<std::endl;
//wait for status update
status = gst_element_get_state((GstElement*)pipeline, nullptr, nullptr, GST_CLOCK_TIME_NONE);
if (status == GST_STATE_CHANGE_FAILURE)
std::cout<<"Can not change to PLAY state!"<<std::endl;
NVXIO_PRINT("GStreamer: unable to start playback");
return false;
vx_uint32 initialFPS = configuration.fps;
if (!updateConfiguration(m_nvvideosink, m_videoconvert, configuration))
return false;
// if initialFPS is specified, we should use this, because
// retrieved via the updateConfiguration function FPS corresponds
// to camera config FPS
std::cout<<" init success!!!!"<<std::endl;
if (initialFPS != (vx_uint32)-1)
configuration.fps = initialFPS;
end = false;
return true;
} // namespace nvidiaio
#endif // defined USE_RTSPCAMERA
In order to use my “GStreamerRtspFrameSourceImpl”,i modified some code in GStreamerEGLStreamSinkFrameSourceImpl.hpp and GStreamerEGLStreamSinkFrameSourceImpl.cpp
#if defined USE_GSTREAMER_OMX && defined USE_GLES || defined USE_GSTREAMER_NVMEDIA || defined USE_NVGSTCAMERA || defined USE_RTSPCAMERA
FrameSource.cpp and FrameSourceOVX.cpp
# ifdef USE_RTSPCAMERA
# include "FrameSource/GStreamer/GStreamerRtspFrameSourceImpl.hpp"
# endif
and in function: std::unique_ptr createDefaultFrameSource(const std::string& uri), i create “GStreamerRtspFrameSourceImpl”
if (path == "rtsp")
std::cout<<"Make UP RTSP IMPL!"<<std::endl;
return makeUP<GStreamerRtspFrameSourceImpl>("hello");
#endif
and add -DUSE_RTSPCAMERA=1 -DUSE_GLES=1 to MakeFile, then make…
I recompile the sample nvx_sample_player (add “LIBRARIES += -lEGL -lcuda” to its makefile) and run:
./nvx_sample_player --source=device:///rtsp?rtspsrc=xxx
the GStreamerRtspFrameSourceImpl can be created,but the gstreamer pipeline can’t change to PLAY state.
the output message is below
nvidia@tegra-ubuntu:/media/nvidia/hcdisk/visionworks/sources/bin/aarch64/linux/release$ ./nvx_sample_player --source=device:///rtsp?rtspsrc=xxx
VisionWorks library info:
VisionWorks version : 1.6.0
OpenVX Standard version : 1.1.0
Make UP RTSP IMPL!
The filter caps is:video/x-raw(memory:NVMM), width=(int)704, height=(int)576, format=(string)I420, framerate=(fraction)25/1
Linking rtspsrc pad!
The source name is:rtspsrc
The dest name is:rtspdepay
The sinkpad name is:sink
The new pad name is:recv_rtp_src_0_710463277_96
NvMMLiteOpen : Block : BlockType = 261
TVMR: NvMMLiteTVMRDecBlockOpen: 7907: NvMMLiteBlockOpen
NvMMLiteBlockCreate : Block : BlockType = 261
TVMR: cbBeginSequence: 1223: BeginSequence 704x576, bVPR = 0
TVMR: LowCorner Frequency = 100000
TVMR: cbBeginSequence: 1622: DecodeBuffers = 6, pnvsi->eCodec = 4, codec = 0
TVMR: cbBeginSequence: 1693: Display Resolution : (704x576)
TVMR: cbBeginSequence: 1694: Display Aspect Ratio : (704x576)
TVMR: cbBeginSequence: 1762: ColorFormat : 5
TVMR: cbBeginSequence:1767 ColorSpace = NvColorSpace_YCbCr709_ER
TVMR: cbBeginSequence: 1904: SurfaceLayout = 3
TVMR: cbBeginSequence: 2005: NumOfSurfaces = 13, InteraceStream = 0, InterlaceEnabled = 0, bSecure = 0, MVC = 0 Semiplanar = 1, bReinit = 1, BitDepthForSurface = 8 LumaBitDepth = 8, ChromaBitDepth = 8, ChromaFormat = 5
TVMR: cbBeginSequence: 2007: BeginSequence ColorPrimaries = 1, TransferCharacteristics = 1, MatrixCoefficients = 1
Allocating new output: 704x576 (x 13), ThumbnailMode = 0
OPENMAX: HandleNewStreamFormat: 3464: Send OMX_EventPortSettingsChanged : nFrameWidth = 704, nFrameHeight = 576
TVMR: TVMRFrameStatusReporting: 6369: Closing TVMR Frame Status Thread -------------
TVMR: TVMRVPRFloorSizeSettingThread: 6179: Closing TVMRVPRFloorSizeSettingThread -------------
TVMR: TVMRFrameDelivery: 6219: Closing TVMR Frame Delivery Thread -------------
TVMR: NvMMLiteTVMRDecBlockClose: 8105: Done
Error: Can’t open source URI device:///rtsp?rtspsrc=xxx
