How to enable P2P on Amazon EC2 g2.x8large
Hey ,all
First of all, a short introduction of g2.x8large:4 GPU K520, SM30 , CUDA 7.0 , Driver 367.35
My question: It seems everything is fine, but why in simpleP2P, cannot access from GPU 0 to GPU 1?
Following is the configuration :
Copyright (c) 2005-2015 NVIDIA Corporation
Built on Mon_Feb_16_22:59:02_CST_2015
Cuda compilation tools, release 7.0, V7.0.27
I also I notice there is a error:
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
                        RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
                        MaxPayload 128 bytes, MaxReadReq 512 bytes
| NVIDIA-SMI 367.35                 Driver Version: 367.35                    |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  GRID K520           Off  | 0000:00:03.0     Off |                  N/A |
| N/A   36C    P0    43W / 125W |      0MiB /  4036MiB |      0%      Default |
|   1  GRID K520           Off  | 0000:00:04.0     Off |                  N/A |
| N/A   33C    P0    42W / 125W |      0MiB /  4036MiB |      0%      Default |
|   2  GRID K520           Off  | 0000:00:05.0     Off |                  N/A |
| N/A   34C    P0    43W / 125W |      0MiB /  4036MiB |      0%      Default |
|   3  GRID K520           Off  | 0000:00:06.0     Off |                  N/A |
| N/A   30C    P0    39W / 125W |      0MiB /  4036MiB |      0%      Default |
Device Query:
Detected 4 CUDA Capable device(s)
Device 0: "GRID K520"
  CUDA Driver Version / Runtime Version          8.0 / 7.0
  CUDA Capability Major/Minor version number:    3.0
  Total amount of global memory:                 4036 MBytes (4232052736 bytes)
  ( 8) Multiprocessors, (192) CUDA Cores/MP:     1536 CUDA Cores
  GPU Max Clock rate:                            797 MHz (0.80 GHz)
  Memory Clock rate:                             2500 Mhz
  Memory Bus Width:                              256-bit
  L2 Cache Size:                                 524288 bytes
  Maximum Texture Dimension Size (x,y,z)         1D=(65536), 2D=(65536, 65536), 3D=(4096, 4096, 4096)
  Maximum Layered 1D Texture Size, (num) layers  1D=(16384), 2048 layers
  Maximum Layered 2D Texture Size, (num) layers  2D=(16384, 16384), 2048 layers
  Total amount of constant memory:               65536 bytes
  Total amount of shared memory per block:       49152 bytes
  Total number of registers available per block: 65536
  Warp size:                                     32
  Maximum number of threads per multiprocessor:  2048
  Maximum number of threads per block:           1024
  Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
  Max dimension size of a grid size    (x,y,z): (2147483647, 65535, 65535)
  Maximum memory pitch:                          2147483647 bytes
  Texture alignment:                             512 bytes
  Concurrent copy and kernel execution:          Yes with 2 copy engine(s)
  Run time limit on kernels:                     No
  Integrated GPU sharing Host Memory:            No
  Support host page-locked memory mapping:       Yes
  Alignment requirement for Surfaces:            Yes
  Device has ECC support:                        Disabled
  Device supports Unified Addressing (UVA):      Yes
  Device PCI Domain ID / Bus ID / location ID:   0 / 0 / 3
  Compute Mode:
     < Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
Device 1: "GRID K520"
  Warp size:                                     32
  Device PCI Domain ID / Bus ID / location ID:   0 / 0 / 4
  Compute Mode:
Device 2: "GRID K520"
  Warp size:                                     32
  Device PCI Domain ID / Bus ID / location ID:   0 / 0 / 5
  Compute Mode:
Device 3: "GRID K520"
  Warp size:                                     32
  Device PCI Domain ID / Bus ID / location ID:   0 / 0 / 6
  Compute Mode:
> Peer access from GRID K520 (GPU0) -> GRID K520 (GPU1) : No
> Peer access from GRID K520 (GPU0) -> GRID K520 (GPU2) : No
> Peer access from GRID K520 (GPU0) -> GRID K520 (GPU3) : No
> Peer access from GRID K520 (GPU1) -> GRID K520 (GPU1) : No
> Peer access from GRID K520 (GPU1) -> GRID K520 (GPU2) : No
> Peer access from GRID K520 (GPU1) -> GRID K520 (GPU3) : No
> Peer access from GRID K520 (GPU2) -> GRID K520 (GPU1) : No
> Peer access from GRID K520 (GPU2) -> GRID K520 (GPU2) : No
> Peer access from GRID K520 (GPU2) -> GRID K520 (GPU3) : No
> Peer access from GRID K520 (GPU1) -> GRID K520 (GPU0) : No
> Peer access from GRID K520 (GPU2) -> GRID K520 (GPU0) : No
> Peer access from GRID K520 (GPU3) -> GRID K520 (GPU0) : No
> Peer access from GRID K520 (GPU3) -> GRID K520 (GPU1) : No
> Peer access from GRID K520 (GPU3) -> GRID K520 (GPU2) : No
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 8.0, CUDA Runtime Version = 7.0, NumDevs = 4, Device0 = GRID K520, Device1 = GRID K520, Device2 = GRID K520, Device3 = GRID K520
Result = PASS
-[0000:00]-+-00.0
           +-01.0
           +-01.1
           +-01.3
           +-02.0
           +-03.0
           +-04.0
           +-05.0
           +-06.0
           \-1f.0
GPU0    GPU1    GPU2    GPU3    CPU Affinity
GPU0     X      PHB     PHB     PHB     0-31
GPU1    PHB      X      PHB     PHB     0-31
GPU2    PHB     PHB      X      PHB     0-31
GPU3    PHB     PHB     PHB      X      0-31
Legend:
  X   = Self
  SOC  = Connection traversing PCIe as well as the SMP link between CPU sockets(e.g. QPI)
  PHB  = Connection traversing PCIe as well as a PCIe Host Bridge (typically the CPU)
  PXB  = Connection traversing multiple PCIe switches (without traversing the PCIe Host Bridge)
  PIX  = Connection traversing a single PCIe switch
  NV#  = Connection traversing a bonded set of # NVLinks
00:03.0 VGA compatible controller: NVIDIA Corporation GK104GL [GRID K520] (rev a1) (prog-if 00 [VGA controller])
        Subsystem: NVIDIA Corporation Device 1014
        Physical Slot: 3
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Interrupt: pin A routed to IRQ 28
        Region 0: Memory at ea000000 (32-bit, non-prefetchable)
        Region 1: Memory at c0000000 (64-bit, prefetchable)
        Region 3: Memory at e2000000 (64-bit, prefetchable)
        Region 5: I/O ports at c100
        Expansion ROM at ef000000 [disabled]
        Capabilities: [60] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
                Address: 00000000fee00000  Data: 4300
        Capabilities: [78] Express (v2) Endpoint, MSI 00
                DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 <64us
                        ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
                [b]DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
                        MaxPayload 128 bytes, MaxReadReq 512 bytes[/b]
                DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
                LnkCap: Port #8, Speed 8GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
                        ClockPM+ Surprise- LLActRep- BwNot-
                LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
                        ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
                LnkSta: Speed 2.5GT/s, Width x16, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
                DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR-, OBFF Not Supported
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
                LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+, EqualizationPhase1+
                         EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest+
        Capabilities: [b4] Vendor Specific Information: Len=14 <?>
        Kernel driver in use: nvidia
00:04.0 VGA compatible controller: NVIDIA Corporation GK104GL [GRID K520] (rev a1) (prog-if 00 [VGA controller])
        Physical Slot: 4
        Latency: 0
        Interrupt: pin A routed to IRQ 32
        Region 0: Memory at eb000000 (32-bit, non-prefetchable)
        Region 1: Memory at c8000000 (64-bit, prefetchable)
        Region 3: Memory at e4000000 (64-bit, prefetchable)
        Region 5: I/O ports at c180
        Expansion ROM at ef080000 [disabled]
                LnkCap: Port #16, Speed 8GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
00:05.0 VGA compatible controller: NVIDIA Corporation GK104GL [GRID K520] (rev a1) (prog-if 00 [VGA controller])
        Physical Slot: 5
        Latency: 0
        Interrupt: pin A routed to IRQ 36
        Region 0: Memory at ec000000 (32-bit, non-prefetchable)
        Region 1: Memory at d0000000 (64-bit, prefetchable)
        Region 3: Memory at e6000000 (64-bit, prefetchable)
        Region 5: I/O ports at c200
        Expansion ROM at ef100000 [disabled]
               [b] DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
00:06.0 VGA compatible controller: NVIDIA Corporation GK104GL [GRID K520] (rev a1) (prog-if 00 [VGA controller])
        Physical Slot: 6
        Latency: 0
        Interrupt: pin A routed to IRQ 40
        Region 0: Memory at ed000000 (32-bit, non-prefetchable)
        Region 1: Memory at d8000000 (64-bit, prefetchable)
        Region 3: Memory at e8000000 (64-bit, prefetchable)
        Region 5: I/O ports at c280
        Expansion ROM at ef180000 [disabled]
I agree that it appears that it should be supported. The GPU Driver uses a heuristic to determine platform support for P2P, which is not fully published. The portion indicated by the nvidia-smi topo -m output suggests that it should be supported, but there are other details. In particular I wouldn’t be surprised if the driver disables P2P support when it detects that it is operating in a virtualized environment, which is the case for EC2 GPU instances.
You may wish to file a bug, but its quite possible that this would be considered expected behavior.
I think it is more likely that the virtualization used does not emulate the hardware the driver wants to talk to closely enough, causing the driver to diagnose some sort of hardware issue or limitation and as a consequence disabling functionality affected by that hardware component.
With perfect virtualization, a driver would never know or be able to find out that it is not talking to actual hardware. For performance reasons, most virtualization environments do not even attempt such perfection and many use para-virtualization techniques by design.
Based on this working hypothesis it seems worthwhile to discuss the limitations encountered with the technical support of the virtualization platform provider. Maybe there are configuration settings for the virtualization software that increase the fidelity of the emulation (vs real physical hardware), possibly at the cost of additional overhead.
You are all right! Amazon ec2 g2.8xlarge do not support P2P, thus it means it cannot be a good choice for build deep learning network on it, caused by there is no enough memory could be located at one time.
If Nvidia could provide some GPU cloud in the future, that would be excellent!!
Just CC the reply from Amazon Tech help:
[i]I have attempted to test this setup for you by
  1. Creating a g2.8xlarge
  2. updating to the latest nVidia Drivers
  3. Installing the CUDA Toolkit
  4. Running simpleP2P and p2pBandwidthLatencyTest
Digging deeper, I can confirm for now that Peer-to-Peer access for GRID computing between the quad K520 is not supported at this time. I will associate this case with our current feature request, but at this time, I cannot provide any ETA on when this feature may be available.
If you have any additional questions, please let me know.
Amazon Web Services[/i]
Maybe the new Microsoft Azure GPU instances (with Tesla K80 / M60) provide P2P access.
http://www.azureman.com/infrastructure/test-drive-azure-n-series-vms-with-gpu-yourself/
