How to find current device clock frequency from C++ CUDA
I’m currently benchmarking short programs on CUDA and have run into a problem I think is due to the dynamic frequency control on the device (GTX 1060 3GB) according to workload. If I set the number of iterations of the test sufficiently high the throughput rate is much higher. In fact I’m seeing better results for short runs from a 1050 Ti.
I’m pretty sure this is due to dynamic frequency control. How can I read the current clock frequency of the GPU from within my CUDA C++ program?
Thanks as always,
Leigh.
Take a look at the NVML library, which is the basis of the nvidia-smi utility: https://docs.nvidia.com/deploy/nvml-api/index.html
nvmlDeviceGetClock seems to be the API call of interest.
