gcloud auth login
gcloud auth application-default login
mkdir mount
gcloud config set project PROJECT ID
//that line will create a bucket in asia region, I used web interface of GCP instead//
// gsutil mb -c S -l ASIA gs://my_baquet_name
gcsfuse gs://bucket_name /path/to/mount
that will result in 1Pb mount attached
Now I am testing dd from whole disk to gs mount point.
It shows 11 Mb/s for comparison with the initial 11 MB/s dd to nvme pci-e appears to be 3 times faster and displays 32- MB/s
Though it resulted in :
“closing output file” “input/output error”, possibly because there was no free space at the device by the time the task has ended. Will approach adding to jetson NVME PCI then
Though, perhaps I need to flash first the new tegra release to the nvme drive if not using the dd from the existing eMMC
I am just wondering if flash.sh will support the execution below
yup
I did dd if=dev/mmcblk0 of=/dev/nvme0n1
it has created 29 partitions on the latter
and I changed the extlinux.conf to point to /dev/nvme0n1p1 instead of /dev/mmcblk0p1 , and that resulted in that
on boot is shows:
“waiting for root device /dev/nvme0n1p1”
There is a somewhat subtle detail to point out here just for illustration. If you were to format a partition on your media from a PC which has 64-bit ext4 extensions, then you would get the same message because U-Boot itself would be trying to find extlinux.conf on a file system type it doesn’t understand (it is U-Boot which fails to understand 64-bit extensions…Linux itself is good with 64-bit).
Since the file system was copied directly from the Jetson with dd, then you know that this file system on the NVMe is ok so far as ext4 specs go. The NVMe support is almost certainly the issue, but I suspect the place where the support has to exist is in U-Boot instead of in the Linux kernel. There may be other issues as well, and I don’t know what the default U-Boot support is for NVMe, this seems to be the place to start (unfortunately I don’t know of anything analogous to “/proc/config.gz” of Linux for U-Boot).
Perhaps I do not even need a boot from nvme as I can move folders to it and mount folders like / or /home or usr or bin and whatever folders for execution from nvme.
Initial idea was the speed incerase because of use of nvme. But I doubt it will be a significant difference using internal emmc versus nvme ssd.
Upd, it turned out that 1PB cloud storage can be used but by some unknown reason it requires huge amount on a computer disk drive to redirect the dd file been written to the gcsfuse mounted folder, and if computer has limited disk space it will throw input output error, but if a computer has space the transfer will be completed.
Moreover some limitations on execution from the gscfuse mount folder seems to take place.
Local nvme seems more convenient for execution than cloud storage :P
I have never used those services, but I’m thinking perhaps it uses an extraordinarily large block size in the assumption of very large files. If you are curious and have such a device installed as a block device, then you might try “lsblk -t” or “lsblk -t -P” (you can also name the particular device to limit the query to just that device). Most ordinary old tech disk drives use a 512 byte block size, some 4096…most newer solid state drivers would say 4096.
I am just wondering how to inspect and analyse the mount point made by gcsfuse:
gcsfuse archive-1 fuse
Using mount point: /home/user/fuse
Opening GCS connection...
Opening bucket...
Mounting file system...
File system has been successfully mounted.
mount -l
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
archive-1 on /home/user/fuse type fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000,default_permissions)
I couldn’t tell you anything about gcsfuse. All I can do is speculate somewhat about the large amount of disk space used locally for your remote cloud storage. If you list all block devices used for a mount via “df -T” you’ll see file system type and mount points. All of the first column will be block devices, but only the “/dev” ones will be visible as a device special file you can do all of the normal block device commands on. The ones (such as tmpfs or fuse or gvfs) not showing from “/dev” will be virtual block devices. If the device is purely virtual, then there has to be some way of holding metadata other than on the device itself which is being mounted…I am thinking that perhaps all of the metadata of that PB or TB is being copied to the Jetson and that the metadata is itself quite large.
For a long time block size has always been 512 bytes due to physical construction of disks, and there is a certain amount of overhead/metadata for each block. If you have a lot of small files this might be a good size, but if you have larger files, then you are wasting space on metadata. Going to a 4k block size implies less overhead for people with larger average file size. Something similar could be said about ethernet where it normally has a 1500 byte MTU…but where jumbo frames can be used instead. In the case of a block device the metadata is per node. If it turns out that the Jetson is storing metadata for cloud services (meaning the Jetson is probably controlling the storage characteristics locally), then you get metadata building up locally on the Jetson for every node/block. More nodes/blocks, more metadata. Smaller nodes/blocks for the same total storage, more metadata.
If you have an option to control block size from the cloud services, and change it say from 512 bytes to 1048576 bytes (1MiB), then if the above is correct your Jetson could use the same storage with 512/1048576 == 0.00048828125 as much overhead (1MiB would consume 1 metadata unit, and there would be far fewer metadata units).
Does this cloud storage give you options on block size? What is the average size of file you’d be using on this cloud storage system?
thanks, linuxdev,
I have found at their manual that:
“Local storage: Objects that are new or modified will be stored in their entirety in a local temporary file until they are closed or synced. When working with large files, be sure you have enough local storage capacity for temporary copies of the files,”
Therefore I will have to investigate the issue of recording of camera stream to online cloud storage in a live mode further to find if there are ways to record video let say 100 gb to the cloud having let say 16 gb disk drive at the device.
