I tried to generate a cubin file from a cu file but failed.
Specifically, I tried to generate a cubin file from /opt/cuBB/cuPHY/src/cuphy/error_correction/ldpc2_reg_index_fp_desc_dyn_row_dep.cu and executed the following command and error message.
nvcc /opt/cuBB/cuPHY/src/cuphy/error_correction/ldpc2_reg_index_fp_desc_dyn_row_dep.cu -o ldpc2_reg_index_fp_desc_dyn_row_dep.cubin - arch=sm90
/usr/bin/ld: /lib/aarch64-linux-gnu/crt1.o: in function `__wrap_main’:
(.text+0x38): undefined reference to `main’
/usr/bin/ld: /tmp/tmpxft_00003358_00000000-11_ldpc2_reg_index_fp_desc_dyn_row_dep.o: in function `ldpc2::BG_desc<1> const* ldpc2::get_BG_desc<__half, 1>(int)':
This may be a rudimentary question, but thank you in advance.
