How to generate .engine and how to use it in Deepstream config file?
To generate a .engine file need what .txts(e.g. labelfile-path=… is need?) are necessary?
And when use it what .txts need in config file?
Hey, please share your setup with us.
For how to generate an engine, it depends on which model type are u using, what issue are you meeting?
You can start with the deepstream sample apps and refer the Gst-nvinfer — DeepStream 6.1.1 Release documentation
