I have two servers with CX-5 card, tx and rx. There have switchs between the servers. PFC disabled on switchs.
I am using pktgen to generate packets on tx server and PFC enabled on rx. All packets received on rx_prio0. Rx server have rx_out_of_buffer counter, but it didn’t generate tx PFC pause packets.
My question is, must PFC be enabled for directly connected switch in order for rx server to generate PFC pause packets. If not, how should I configure to generate PFC pause packets.
root@POD65-CLU01-GPU02:~#
root@POD65-CLU01-GPU02:~# ethtool -S enp94s0f0np0 | grep rx_out_of_buffer
rx_out_of_buffer: 28152779
root@POD65-CLU01-GPU02:~# ethtool -S enp94s0f0np0 | grep rx_prio0
rx_prio0_bytes: 11367274808
rx_prio0_packets: 132018633
rx_prio0_discards: 0
rx_prio0_pause: 0
rx_prio0_pause_duration: 0
rx_prio0_pause_transition: 0
root@POD65-CLU01-GPU02:~# mlnx_qos -i enp94s0f0np0
DCBX mode: OS controlled
Priority trust state: pcp
default priority:
Receive buffer size (bytes): 130944,130944,0,0,0,0,0,0,max_buffer_size=262016
Cable len: 7
PFC configuration:
priority 0 1 2 3 4 5 6 7
enabled 1 1 0 0 0 0 1 0
buffer 1 1 0 0 0 0 1 0
tc: 0 ratelimit: unlimited, tsa: strict
priority: 0
priority: 1
priority: 2
priority: 3
priority: 4
priority: 5
priority: 6
priority: 7
root@POD65-CLU01-GPU02:~# ethtool -S enp94s0f0np0 | grep pause
rx_pause_ctrl_phy: 0
tx_pause_ctrl_phy: 0
rx_prio0_pause: 0
tx_prio0_pause: 0
tx_prio0_pause_duration: 0
rx_prio1_pause: 0
rx_prio1_pause_duration: 0
tx_prio1_pause: 0
tx_prio1_pause_duration: 0
rx_prio1_pause_transition: 0
rx_prio6_pause: 0
rx_prio6_pause_duration: 0
tx_prio6_pause: 0
tx_prio6_pause_duration: 0
rx_prio6_pause_transition: 0
tx_pause_storm_warning_events: 0
tx_pause_storm_error_events: 0
