INFO: memcpy-only_commsize64Mto13G_2GPU_outplace_inplace.nsys-rep: Exporting [‘GPU_METRICS’, ‘TARGET_INFO_GPU_METRICS’, ‘CUPTI_ACTIVITY_KIND_KERNEL’, ‘StringIds’] to memcpy-only_commsize64Mto13G_2GPU_outplace_inplace_pqtdir…
concurrent.futures.process._RemoteTraceback:
File “/usr/lib64/python3.9/concurrent/futures/process.py”, line 243, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File “/usr/lib64/python3.9/concurrent/futures/process.py”, line 202, in _process_chunk
return [fn(*args) for args in chunk]
File “/opt/nvidia/nsight-systems/2024.5.1/target-linux-x64/python/packages/nsys_recipe/recipes/gpu_metric_util_sum/gpu_metric_util_sum.py”, line 170, in _mapper_func
stats_df = GpuMetricUtilSum.calculate_stats(range_df, gpu_metrics_df)
File “/opt/nvidia/nsight-systems/2024.5.1/target-linux-x64/python/packages/nsys_recipe/recipes/gpu_metric_util_sum/gpu_metric_util_sum.py”, line 107, in calculate_stats
means = overlap_df[
File “/data/node07/zao.yao/envs/alpaca/lib64/python3.9/site-packages/pandas/core/frame.py”, line 4108, in getitem
indexer = self.columns._get_indexer_strict(key, “columns”)[1]
File “/data/node07/zao.yao/envs/alpaca/lib64/python3.9/site-packages/pandas/core/indexes/base.py”, line 6200, in _get_indexer_strict
self._raise_if_missing(keyarr, indexer, axis_name)
File “/data/node07/zao.yao/envs/alpaca/lib64/python3.9/site-packages/pandas/core/indexes/base.py”, line 6249, in _raise_if_missing
raise KeyError(f"None of [{key}] are in the [{axis_name}]“)
KeyError: “None of [Index([‘DRAM Read Bandwidth’, ‘DRAM Write Bandwidth’], dtype=‘object’)] are in the [columns]”
The above exception was the direct cause of the following exception:
File “/usr/lib64/python3.9/runpy.py”, line 197, in _run_module_as_main
return _run_code(code, main_globals, None,
File “/usr/lib64/python3.9/runpy.py”, line 87, in _run_code
exec(code, run_globals)
File “/opt/nvidia/nsight-systems/2024.5.1/target-linux-x64/python/packages/nsys_recipe/main.py”, line 133, in
main()
File “/opt/nvidia/nsight-systems/2024.5.1/target-linux-x64/python/packages/nsys_recipe/main.py”, line 121, in main
recipe, exit_code = run_recipe(remaining_args[0], remaining_args[1:])
File “/opt/nvidia/nsight-systems/2024.5.1/target-linux-x64/python/packages/nsys_recipe/log.py”, line 47, in wrapper
return func(*args, **kwargs)
File “/opt/nvidia/nsight-systems/2024.5.1/target-linux-x64/python/packages/nsys_recipe/main.py”, line 57, in run_recipe
recipe.run(context)
File “/opt/nvidia/nsight-systems/2024.5.1/target-linux-x64/python/packages/nsys_recipe/recipes/gpu_metric_util_sum/gpu_metric_util_sum.py”, line 218, in run
mapper_res = self.mapper_func(context)
File “/opt/nvidia/nsight-systems/2024.5.1/target-linux-x64/python/packages/nsys_recipe/recipes/gpu_metric_util_sum/gpu_metric_util_sum.py”, line 183, in mapper_func
context.map(
File “/opt/nvidia/nsight-systems/2024.5.1/target-linux-x64/python/packages/nsys_recipe/lib/recipe.py”, line 237, in map
return [*self._executor.map(partial_func, *iterables)]
File “/usr/lib64/python3.9/concurrent/futures/process.py”, line 559, in _chain_from_iterable_of_lists
for element in iterable:
File “/usr/lib64/python3.9/concurrent/futures/_base.py”, line 600, in result_iterator
yield fs.pop().result()
File “/usr/lib64/python3.9/concurrent/futures/_base.py”, line 440, in result
return self.__get_result()
File “/usr/lib64/python3.9/concurrent/futures/_base.py”, line 389, in __get_result
raise self._exception
