How to get multiple outputs for multiple streams
• Hardware Platform (Jetson / GPU) GPU Nvidia RTX 2060
• DeepStream Version 5.0
• TensorRT Version 7.0,0
• NVIDIA GPU Driver Version (valid for GPU only) 460
• Issue Type( questions, new requirements, bugs) new requirements
I am using deepstream sample source code for C++, deepstream-test3 application.
In this the output video for multiple streams is obtained on a single tiled frame/window.
I want to run the output on multiple windows with parallel processing. How can I achieve the same?
I am assuming it has something to do with nvmultistreamtiler or tiler.
Please guide me through the same.
My system hardware and software configuration is mentioned above.
If you don’t want tiled streams, you can write your own pipeline(you need to change the code) to remove nvmultistreamtiler and add nvstreamdemux. There are some sample pipelines in the document Gst-nvstreamdemux — DeepStream 6.1.1 Release documentation
You can also find the sample code in deepstream-app sample. You can find related code in /opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-app/deepstream_app.c. DeepStream Reference Application - deepstream-app — DeepStream 6.1.1 Release documentation
