it is work to use nvgstcapture-1.0 to get video stream from the Original camera board,
then , use imx185-mipi(leopard) replace the Original camera board,
do nvgstcapture-1.0 ,it report Message :
Inside NvxLiteH264DecoderLowLatencyInitNvxLiteH264DecoderLowLatencyInit set DPB and MjstreamingInside NvxLiteH265DecoderLowLatencyInitNvxLiteH265DecoderLowLatencyInit set DPB and MjstreamingSocket read error. Camera Daemon stopped functioning…
gst_nvcamera_open() failed ret=0
** (nvgstcapture-1.0:7743): CRITICAL **: <create_capture_pipeline:4407> can’t set camera to playing
** (nvgstcapture-1.0:7743): CRITICAL **: main:5195 Capture Pipeline creation failed
** Message: main:5202 Capture completed
** Message: main:5252 Camera application will now exit
Did you configure the sensor within the device tree file for the board? I think the driver comes already enabled by default in the kernel configuration however it would be good to check.
Also what does your boot log (or dmesg) output says in regards to the driver? Is it correctly registered?
In regards to libargus documentation you can find some into the tegra_multimedia_api package that is downloaded into the jetpack_download directory.
Can you run dmesg command on your TX1 and post it here? There you should be able to see the sensor being registered if the driver/device tree were set correctly.
File uploads only work after you post…basically you can look at the upper right corner of your post and there are some icons, one for edit (looks like a pencil), one attaches files (looks like a paper clip). Not all file types are accepted, but most logs like you have can be “.txt” extension. You can also surround your existing log text with the code quote icon ("</>" symbol) and it’ll get scroll bars if it is too long.
For Nvidia Jetson TX2 DevKit, the default driver of Jetpack 3.1 (or R28.1) support our IMX185 camera directly, but it only support one camera. We are working on the driver for multiple IMX185 cameras.
