I am encountering issues with streaming video from an IMX219 camera connected to my NVIDIA Jetson Xavier Development Kit. I am using JetPack SDK version 5.1.3 with Jetson Linux 35.5.0. When I run the v4l2-compliance -d /dev/video0
command, it displays the following results:
Format ioctls (Input 0):
test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS: OK
fail: v4l2-test-formats.cpp(1280): ret && node->has_frmintervals
test VIDIOC_G/S_PARM: FAIL
test VIDIOC_G_FBUF: OK (Not Supported)
test VIDIOC_G_FMT: OK
test VIDIOC_TRY_FMT: OK
test VIDIOC_S_FMT: OK
test VIDIOC_G_SLICED_VBI_CAP: OK (Not Supported)
test Cropping: OK (Not Supported)
test Composing: OK (Not Supported)
test Scaling: OK (Not Supported)
Codec ioctls (Input 0):
test VIDIOC_(TRY_)ENCODER_CMD: OK (Not Supported)
test VIDIOC_G_ENC_INDEX: OK (Not Supported)
test VIDIOC_(TRY_)DECODER_CMD: OK (Not Supported)
Buffer ioctls (Input 0):
fail: v4l2-test-buffers.cpp(715): q.create_bufs(node, 1, &fmt) != EINVAL
test VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF: FAIL
test VIDIOC_EXPBUF: OK
test Requests: OK (Not Supported)
Total for tegra-video device /dev/video0: 45, Succeeded: 43, Failed: 2, Warnings: 0
There are failures in the test results, particularly with VIDIOC_G/S_PARM
and buffer-related ioctls. Could these issues be causing problems with the camera streaming functionality? If so, how can I address these failures and resolve the potential streaming issues?
Thank you
Nope, this known failed doesn’t cause streaming issue.
Check the trace log to check if more clue for streaming failed.
https://elinux.org/Jetson/l4t/Camera_BringUp
I am following up on my previous inquiry regarding the issue I’m encountering when starting streaming. The log messages I receive are as follows:
tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 211.167965] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 211.168124] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=4, csi_port=4
[ 211.168363] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 211.168909] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 213.727398] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 213.727670] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
Could you please provide further assistance in diagnosing these errors and suggest possible solutions?
This log tell capture failed from the sensor. Get the trace log to know more.
trace.txt (53.9 KB)
root@tegra-ubuntu:/home/xavier# echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
root@tegra-ubuntu:/home/xavier# echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
root@tegra-ubuntu:/home/xavier# cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
460800000
root@tegra-ubuntu:/home/xavier# cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
576000000
root@tegra-ubuntu:/home/xavier# cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
314000000
I am also attaching additional trace logs for further analysis.
This is not trace log.
Enable by below command and launch camera then "cat /sys/kernel/debug/tracing/trace
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 2 > /sys/kernel/debug/camrtc/log-level
echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
echo > /sys/kernel/debug/tracing/trace
When I executed the following command:
v4l2-ctl -d /dev/video0 --stream-mmap --stream-count=10 --stream-to=output.raw
trace1.txt (3.1 KB)
From the trace log looks like NVCSI/VI didn’t receive any validate data from the sensor.
Maybe probe the sensor output signal to confirm the MIPI timing.
Thank you for the input.
The 4-lane MIPI camera is functioning correctly with the older SDK version 4.6.2, and streaming is possible. However, the issue arises when I upgrade to SDK version 5.1.3.
Given this information, could you suggest where I might look for potential errors or changes that could have affected the sensor’s data reception or MIPI timing in the new SDK version?
Thanks for your assistance!
The sensor is imx219?
Try enable by jetson-io instead of customized device tree.
We are using the AR1820 sensor. After adding the changes for the AR1820 in the DTSI file tegra194-camera-rbpcv2-imx219.dtsi, when I connect the AR1820 camera, its node is present. However, when I connect the IMX219,some errors are shown, which are given below:
[ 18.313048] nv_imx219: disagrees about the version of symbol tegracam_v4l2subdev_unregister
[ 18.323591] nv_imx219: Unknown symbol tegracam_v4l2subdev_unregister (err -22)
[ 18.323715] nv_imx219: disagrees about the version of symbol tegracam_v4l2subdev_register
[ 18.323726] nv_imx219: Unknown symbol tegracam_v4l2subdev_register (err -22)
[ 18.323734] nv_imx219: disagrees about the version of symbol tegracam_device_unregister
[ 18.323740] nv_imx219: Unknown symbol tegracam_device_unregister (err -22)
[ 18.323760] nv_imx219: disagrees about the version of symbol tegracam_get_privdata
[ 18.323770] nv_imx219: Unknown symbol tegracam_get_privdata (err -22)
[ 18.323791] nv_imx219: disagrees about the version of symbol camera_common_mclk_enable
[ 18.323797] nv_imx219: Unknown symbol camera_common_mclk_enable (err -22)
Do you download the kernel source to build the sensor driver?
I downloaded the source files from the NVIDIA JetPack 5.1.3 page for building the kernel. On the carrier board, I have a 4-lane port for connecting the AR1820 sensor. I am working with SDK 5.1.3. After modifying the DTSI file and making the necessary changes, the IMX219 camera node is no longer visible.
When I connect the AR1820 sensor, the video0
node is present, but there is a streaming issue.
My priority is to get the AR1820 sensor camera to stream properly. Could you assist in identifying and resolving the streaming issue?
Thank you!
If the trace log is the same you may need to probe the sensor output signal to confirm it follow the MIPI spec.
