How to go over an image more than once?
I’m trying to write a small program that goes over an image, and manipulates it by using iterations, means - each manipulation is dependent on the previous one.
As a start, I’m just trying to keep the original image after a few iterations, without manipulating it, just to make sure I can handle the image correctly.
I’m trying to base my code on the porvided simpleTexture, but I got a weird problem that I cannot manage to solve: the image is getting blurred and shifted. The more iterations I run, the worst it gets.
This is my simple kernel:
__global__ void
transformKernel( float* g_odata, int width, int height)
    // calculate normalized texture coordinates
    unsigned int x = blockIdx.x*blockDim.x + threadIdx.x;
    unsigned int y = blockIdx.y*blockDim.y + threadIdx.y;
   float u = x / (float) width;
    float v = y / (float) height;
     // read from texture and write to global memory
    g_odata[y*width + x] = (tex2D(tex,u,v));
And this is the code the calls the kernel:
void
runTest( int argc, char** argv)
	CUT_DEVICE_INIT();
	// load image from disk
	float* h_data = NULL;
	unsigned int width, height;
	char* image_path = cutFindFilePath(image_filename, argv[0]);
	if (image_path == 0)
  exit(EXIT_FAILURE);
	CUT_SAFE_CALL( cutLoadPGMf(image_path, &h_data, &width, &height));
	unsigned int size = width * height * sizeof(float);
	printf("Loaded '%s', %d x %d pixels\n", image_filename, width, height);
	// allocate device memory for result
	float* d_data = NULL;
	CUDA_SAFE_CALL( cudaMalloc( (void**) &d_data, size));
	// allocate array and copy image data
	cudaChannelFormatDesc channelDesc = cudaCreateChannelDesc(32, 0, 0, 0, cudaChannelFormatKindFloat);
	cudaArray* cu_array;
	CUDA_SAFE_CALL( cudaMallocArray( &cu_array, &channelDesc, width, height ));
	CUDA_SAFE_CALL( cudaMemcpyToArray( cu_array, 0, 0, h_data, size, cudaMemcpyHostToDevice));
	// set texture parameters
	tex.addressMode[0] = cudaAddressModeWrap;
	tex.addressMode[1] = cudaAddressModeWrap;
	tex.filterMode = cudaFilterModeLinear;
	tex.normalized = true;    // access with normalized texture coordinates
	// Bind the array to the texture
	CUDA_SAFE_CALL( cudaBindTextureToArray( tex, cu_array, channelDesc));
	dim3 dimBlock(8, 8, 1);
	dim3 dimGrid(width / dimBlock.x, height / dimBlock.y, 1);
	for(int i=0;i<100;i++){
  CUDA_SAFE_CALL( cudaThreadSynchronize() );
  unsigned int timer = 0;
  CUT_SAFE_CALL( cutCreateTimer( &timer));
  CUT_SAFE_CALL( cutStartTimer( timer));
 // execute the kernel
  transformKernel<<< dimGrid, dimBlock, 0 >>>( d_data, width, height);
  CUDA_SAFE_CALL(cudaMemcpyToArray(cu_array, 0, 0, d_data, size, cudaMemcpyDeviceToDevice));
 // check if kernel execution generated an error
  CUT_CHECK_ERROR("Kernel execution failed");
  CUT_SAFE_CALL( cutStopTimer( timer));
  printf("Processing time: %f (ms)\n", cutGetTimerValue( timer));
  printf("%.2f Mpixels/sec\n", (width*height / (cutGetTimerValue( timer) / 1000.0f)) / 1e6);
  CUT_SAFE_CALL( cutDeleteTimer( timer));
	// allocate mem for the result on host side
	float* h_odata = (float*) malloc( size);
	// copy result from device to host
	CUDA_SAFE_CALL( cudaMemcpy( h_odata, d_data, size, cudaMemcpyDeviceToHost) );
	// write result to file
	char output_filename[1024];
	strcpy(output_filename, image_path);
	strcpy(output_filename + strlen(image_path) - 4, "_out.pgm");
	CUT_SAFE_CALL( cutSavePGMf( output_filename, h_odata, width, height));
	printf("Wrote '%s'\n", output_filename);
	// write regression file if necessary
	if( cutCheckCmdLineFlag( argc, (const char**) argv, "regression"))
  // write file for regression test
  CUT_SAFE_CALL( cutWriteFilef( "./data/regression.dat", h_odata, width*height, 0.0));
	// cleanup memory
	CUDA_SAFE_CALL(cudaFree(d_data));
	CUDA_SAFE_CALL(cudaFreeArray(cu_array));
	free(h_data);
	free(h_odata);
	cutFree(image_path);
The code is based on the simpleTexture project, I only added the loop and the update of the texture on the device so changes of each iteration will have an affect.
I attached the blurred pgm file I get as a result of the above code.
If anyone has any clue on why do I get such weird results, or how to run over an image which is stored in a float texutre, I’ll be grateful, since I havn’t got any lead…
I had this problem. It turns out that when your filtering mode is linear, you need to use
float u = x / (float) width + 0.5f;
float v = y / (float) height + 0.5f;
instead of
or change the filtering mode to cudaFilterModePoint.
Check out Appendix F in the programming guide.
Thanks a lot for your help!
Changing the filtering mode to cudaFilterModePoint did seem to solve the problem.
The weird part is that adding 0.5f to u and v while in linear mode didn’t change anything. Any idea why?
BTW - I didn’t understand from the guide, in which cases should I prefer using linear mode filter rather than cudaFilterModePoint?
Thanks again…
cudaFilterModePoint doesn’t filter. If you specify a u,v of (1.1,34.9) the floats will be rounded to integers, and you get the actual pixel value.
cudaFilterModeLinear with say, (x+0.5f, y+0.5f), gives you the average of the four nearest pixels.
If I understand correctly (looking at F.2 in the programming guide), when you use linear filtering, when your address (using un-normalized addressing) is an integer x, you are actually getting the interpolation of x-1 and x, i.e. you are actually looking at x - 0.5. In order to get x actual you need to add 0.5. Probably when you are using normalized textures, you have to add in the half before you divide. I don’t use normalized texture addressing, so I don’t know if this holds true in your case. So I should have said to try:
float u = (x + 0.5f) / (float) width;
It is true that filterModePoint is nearest neighbour, so is not a filter.
It seems that (x, y) gives you the average of four pixels, x-0.5, x+0.5, y-0.5, y+0.5.
