I’m probably being really stupid, so please bear with me while I try to understand this.
I have modified your example slightly so it now reads:
#include <stdlib.h>
#include <stdio.h>
// Macro to catch CUDA errors in CUDA runtime calls
#define CUDA_SAFE_CALL(call) \
do { \
cudaError_t err = call; \
if (cudaSuccess != err) { \
fprintf (stderr, "Cuda error in file '%s' in line %i : %s.\n",\
__FILE__, __LINE__, cudaGetErrorString(err) ); \
exit(EXIT_FAILURE); \
} while (0)
// Macro to catch CUDA errors in kernel launches
#define CHECK_LAUNCH_ERROR() \
do { \
/* Check synchronous errors, i.e. pre-launch */ \
cudaError_t err = cudaGetLastError(); \
/* Check asynchronous errors, i.e. kernel failed (ULF) */ \
err = cudaThreadSynchronize(); \
__FILE__, __LINE__, cudaGetErrorString( err) ); \
} while (0)
texture<unsigned char, 2, cudaReadModeNormalizedFloat> tex;
__global__ void kernel (int m, int n, float shift_x, float shift_y)
float val;
for (int row = 0; row < m; row++) {
for (int col = 0; col < n; col++) {
val = tex2D (tex, col+0.5f+shift_x, row+0.5f+shift_y);
printf ("%.3f ", val*255.0f);
printf ("\n");
int main (void)
int m = 4; // height = #rows
int n = 3; // width = #columns
size_t pitch, tex_ofs;
unsigned char arr[4][3]= {{11,12,13},{21,22,23},{31,32,33},{251,252,253}};
unsigned char *arr_d = 0;
CUDA_SAFE_CALL(cudaMallocPitch((void**)&arr_d,&pitch,n*sizeof(*arr_d),m));
CUDA_SAFE_CALL(cudaMemcpy2D(arr_d, pitch, arr, n*sizeof(arr[0][0]),
n*sizeof(arr[0][0]),m,cudaMemcpyHostToDevice));
tex.normalized = false;
tex.filterMode = cudaFilterModeLinear;
CUDA_SAFE_CALL (cudaBindTexture2D (&tex_ofs, &tex, arr_d, &tex.channelDesc,
n, m, pitch));
if (tex_ofs !=0) {
printf ("tex_ofs = %zu\n", tex_ofs);
return EXIT_FAILURE;
printf ("reading array straight\n");
kernel<<<1,1>>>(m, n, 0.0f, 0.0f);
CHECK_LAUNCH_ERROR();
CUDA_SAFE_CALL (cudaDeviceSynchronize());
printf ("reading array shifted in x-direction\n");
kernel<<<1,1>>>(m, n, 0.5f, 0.0f);
printf ("reading array shifted in y-direction\n");
kernel<<<1,1>>>(m, n, 0.0f, 0.5f);
CUDA_SAFE_CALL (cudaFree (arr_d));
return EXIT_SUCCESS;
and outputs:
11.000 12.000 13.000
21.000 22.000 23.000
31.000 32.000 33.000
251.000 252.000 253.000
11.502 12.502 13.000
21.502 22.502 23.000
31.502 32.502 33.000
251.502 252.502 253.000
16.000 17.000 18.000
26.000 27.000 28.000
141.000 142.000 143.000
This is as I would expect.
