I used pbo in openGL to improve efficiency.
glReadBuffer(GL_FRONT);
if(pboUsed) // with PBO
// read framebuffer ///////////////////////////////
t1.start();
// copy pixels from framebuffer to PBO
// Use offset instead of ponter.
// OpenGL should perform asynch DMA transfer, so glReadPixels() will return immediately.
glBindBufferARB(GL_PIXEL_PACK_BUFFER_ARB, pboIds[index]);
glReadPixels(0, 0, SCREEN_WIDTH, SCREEN_HEIGHT, PIXEL_FORMAT, GL_UNSIGNED_BYTE, 0);
// measure the time reading framebuffer
t1.stop();
readTime = t1.getElapsedTimeInMilliSec();
// process pixel data /////////////////////////////
t1.start();
// map the PBO that contain framebuffer pixels before processing it
glBindBufferARB(GL_PIXEL_PACK_BUFFER_ARB, pboIds[nextIndex]);
GLubyte* src = (GLubyte*)glMapBufferARB(GL_PIXEL_PACK_BUFFER_ARB, GL_READ_ONLY_ARB);
if(src)
// change brightness
add(src, SCREEN_WIDTH, SCREEN_HEIGHT, shift, colorBuffer);
glUnmapBufferARB(GL_PIXEL_PACK_BUFFER_ARB); // release pointer to the mapped buffer
t1.stop();
processTime = t1.getElapsedTimeInMilliSec();
glBindBufferARB(GL_PIXEL_PACK_BUFFER_ARB, 0);
else // without PBO
t1.start();
glReadPixels(0, 0, SCREEN_WIDTH, SCREEN_HEIGHT, PIXEL_FORMAT, GL_UNSIGNED_BYTE, colorBuffer);
t1.stop();
// covert to greyscale ////////////////////////////
t1.start();
add(colorBuffer, SCREEN_WIDTH, SCREEN_HEIGHT, shift, colorBuffer);
t1.stop();
The source code is uploaded in the compressed package below.
PBO ON:
x86:0.079ms to readpixels , 1.9ms to process.
59fps,(GeForce GTX750 Ti)
Tegra:0.125ms to readpixels , 30.063ms to process.
30fps,(tx1)
PBO OFF:
x86:15.346ms to readpixels , 0.565ms to process.
Tegra:0.365ms to readpixels , 2.102ms to process.
245fps,(tx1)
It is slower when I use fpo to send datas on Tegra.
How to improve the efficiency of readpixels on Tegra?
pboPack.zip (610 KB)
