I am using 4 IMX390 camera from leopard imaging. When I open 4 cameras, the delay will be like 500 ms and the frame rate will drop to 10 fps.
I use VideoCapture cap0(“nvarguscamerasrc sensor-id=0 maxperf=true ! video/x-raw(memory:NVMM), width=1920, height=1080,format=NV12, framerate=30/1 ! nvvidconv ! queue ! video/x-raw,format=I420 ! appsink”) to open cameras.
Can anyone give me some helps?
Thank you for you reply.
I was in MAXN mode before, but didn’t use jetson_clocks.
I followed your suggestions. The frame rate did improve a little But still, frame rate was about 20 fps, not 30 fps.
And I also try to use egl_display to get video input. The result in console showed I opened the camera, but there was no window pop out.
Thx! I tried to open 4 cameras with xvimagesink using .sh file. All of them can achieve 30 fps.
But I need to grab frames from live stream for further processing, which means I need to use opencv. Can I also do by using xvimagesink, or I can only use appsink?
I tried this pipeline. The performance remained the same. I used maxperf=true in former code.
I also added sync=false at the end. But the frame rate didn’t improve
