Hello, everyone.
I try to install OptiX-SDK on ubuntu 18.04.
In the install process, some errors, shown below, occurred.
please, help me.
[my pc component]
- Intel® Core™ i7-6700K CPU @ 4.00GHz × 8
- RAM 32GB
- GeForce GTX 1060 6GB/PCIe/SSE2
- OS : Ubuntu 18.04.3 LTS
( ^q^) < norepo )
kuwano@kuwano-pc: ~/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK
nvidia-smi
Sun Dec 1 16:11:25 2019
| NVIDIA-SMI 435.21 Driver Version: 435.21 CUDA Version: 10.1 |
| 0 GeForce GTX 106… Off | 00000000:01:00.0 On | N/A |
| 0% 47C P0 31W / 180W | 645MiB / 6075MiB | 4% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1065 G /usr/lib/xorg/Xorg 199MiB |
| 0 1235 G /usr/bin/gnome-shell 142MiB |
| 0 4811 G …quest-channel-token=9948491898371769716 216MiB |
| 0 8832 G gzserver 4MiB |
| 0 8833 G gzclient 79MiB |
( ^q^) < norepo )
nvcc -V
Copyright (c) 2005-2017 NVIDIA Corporation
Built on Fri_Nov__3_21:07:56_CDT_2017
Cuda compilation tools, release 9.1, V9.1.85
( ^q^) < norepo )
mkdir build
( ^q^) < norepo )
cd build/
( ^q^) < norepo )
kuwano@kuwano-pc: ~/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK/build
cmake … -DCMAKE_C_COMPILER=/usr/bin/gcc-6
– The C compiler identification is GNU 6.5.0
– The CXX compiler identification is GNU 8.3.0
– Check for working C compiler: /usr/bin/gcc-6
– Check for working C compiler: /usr/bin/gcc-6 – works
– Detecting C compiler ABI info
– Detecting C compiler ABI info - done
– Detecting C compile features
– Detecting C compile features - done
– Check for working CXX compiler: /usr/bin/c++
– Check for working CXX compiler: /usr/bin/c++ – works
– Detecting CXX compiler ABI info
– Detecting CXX compiler ABI info - done
– Detecting CXX compile features
– Detecting CXX compile features - done
– Performing Test OPTIX_CXX_ACCEPTS_NO_UNUSED_RESULT
– Performing Test OPTIX_CXX_ACCEPTS_NO_UNUSED_RESULT - Success
– Performing Test SSE_41_AVAILABLE
– Performing Test SSE_41_AVAILABLE - Success
– Looking for pthread.h
– Looking for pthread.h - found
– Looking for pthread_create
– Looking for pthread_create - not found
– Looking for pthread_create in pthreads
– Looking for pthread_create in pthreads - not found
– Looking for pthread_create in pthread - found
– Found Threads: TRUE
– Found CUDA: /usr (found suitable version “9.1”, minimum required is “5.0”)
– Found OpenGL: /usr/lib/x86_64-linux-gnu/libOpenGL.so
– Found GLUT: /usr/lib/x86_64-linux-gnu/libglut.so
– Configuring done
– Generating done
– Build files have been written to: /home/kuwano/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK/build
( ^q^) < norepo )
make -j4
Scanning dependencies of target sutil_sdk
[ 3%] Building CXX object sutil/CMakeFiles/sutil_sdk.dir/HDRLoader.cpp.o
[ 3%] Building CXX object sutil/CMakeFiles/sutil_sdk.dir/Arcball.cpp.o
[ 3%] Building C object sutil/CMakeFiles/sutil_sdk.dir/rply-1.01/rply.c.o
[ 4%] Building CXX object sutil/CMakeFiles/sutil_sdk.dir/Mesh.cpp.o
[ 5%] Building CXX object sutil/CMakeFiles/sutil_sdk.dir/OptiXMesh.cpp.o
[ 6%] Building CXX object sutil/CMakeFiles/sutil_sdk.dir/PPMLoader.cpp.o
[ 7%] Building CXX object sutil/CMakeFiles/sutil_sdk.dir/sutil.cpp.o
[ 8%] Building CXX object sutil/CMakeFiles/sutil_sdk.dir/tinyobjloader/tiny_obj_loader.cc.o
[ 10%] Building C object sutil/CMakeFiles/sutil_sdk.dir/glew.c.o
[ 11%] Linking CXX shared library …/lib/libsutil_sdk.so
[ 11%] Built target sutil_sdk
Scanning dependencies of target optixCallablePrograms
Scanning dependencies of target optixBuffersOfBuffers
Scanning dependencies of target optixCompressedTexture
Scanning dependencies of target optixConsole
[ 13%] Building CXX object optixBuffersOfBuffers/CMakeFiles/optixBuffersOfBuffers.dir/optixBuffersOfBuffers.cpp.o
[ 13%] Building CXX object optixCallablePrograms/CMakeFiles/optixCallablePrograms.dir/optixCallablePrograms.cpp.o
[ 14%] Building CXX object optixCompressedTexture/CMakeFiles/optixCompressedTexture.dir/optixCompressedTexture.cpp.o
[ 15%] Building CXX object optixConsole/CMakeFiles/optixConsole.dir/optixConsole.cpp.o
[ 16%] Linking CXX executable …/bin/optixCompressedTexture
[ 16%] Built target optixCompressedTexture
Scanning dependencies of target optixDemandLoadBuffer
[ 17%] Building CXX object optixDemandLoadBuffer/CMakeFiles/optixDemandLoadBuffer.dir/optixDemandLoadBuffer.cpp.o
[ 18%] Linking CXX executable …/bin/optixCallablePrograms
[ 18%] Built target optixCallablePrograms
Scanning dependencies of target optixDemandLoadTexture
[ 20%] Linking CXX executable …/bin/optixConsole
[ 21%] Building CXX object optixDemandLoadTexture/CMakeFiles/optixDemandLoadTexture.dir/optixDemandLoadTexture.cpp.o
[ 22%] Linking CXX executable …/bin/optixBuffersOfBuffers
[ 22%] Built target optixConsole
Scanning dependencies of target optixDenoiser
[ 23%] Building CXX object optixDenoiser/CMakeFiles/optixDenoiser.dir/optixDenoiser.cpp.o
[ 23%] Built target optixBuffersOfBuffers
Scanning dependencies of target optixDeviceQuery
[ 24%] Building CXX object optixDeviceQuery/CMakeFiles/optixDeviceQuery.dir/optixDeviceQuery.cpp.o
[ 25%] Linking CXX executable …/bin/optixDeviceQuery
[ 25%] Built target optixDeviceQuery
Scanning dependencies of target optixDynamicGeometry
[ 26%] Building CXX object optixDynamicGeometry/CMakeFiles/optixDynamicGeometry.dir/optixDynamicGeometry.cpp.o
[ 27%] Linking CXX executable …/bin/optixDemandLoadBuffer
[ 27%] Built target optixDemandLoadBuffer
Scanning dependencies of target optixGeometryTriangles
[ 28%] Building CXX object optixGeometryTriangles/CMakeFiles/optixGeometryTriangles.dir/optixGeometryTriangles.cpp.o
[ 30%] Linking CXX executable …/bin/optixDemandLoadTexture
[ 30%] Built target optixDemandLoadTexture
Scanning dependencies of target optixHello
[ 31%] Building CXX object optixHello/CMakeFiles/optixHello.dir/optixHello.cpp.o
[ 32%] Linking CXX executable …/bin/optixDenoiser
[ 33%] Linking CXX executable …/bin/optixHello
[ 33%] Built target optixDenoiser
[ 33%] Built target optixHello
Scanning dependencies of target optixInstancing
Scanning dependencies of target optixMDLDisplacement
[ 34%] Building CXX object optixInstancing/CMakeFiles/optixInstancing.dir/optixInstancing.cpp.o
[ 35%] Building CXX object optixMDLDisplacement/CMakeFiles/optixMDLDisplacement.dir/optixMDLDisplacement.cpp.o
[ 36%] Linking CXX executable …/bin/optixDynamicGeometry
[ 36%] Built target optixDynamicGeometry
Scanning dependencies of target optixMDLExpressions
[ 37%] Linking CXX executable …/bin/optixGeometryTriangles
[ 38%] Building CXX object optixMDLExpressions/CMakeFiles/optixMDLExpressions.dir/optixMDLExpressions.cpp.o
[ 38%] Built target optixGeometryTriangles
Scanning dependencies of target optixMDLSphere
[ 40%] Building CXX object optixMDLSphere/CMakeFiles/optixMDLSphere.dir/optixMDLSphere.cpp.o
[ 41%] Linking CXX executable …/bin/optixInstancing
[ 41%] Built target optixInstancing
Scanning dependencies of target optixMeshViewer
[ 42%] Building CXX object optixMeshViewer/CMakeFiles/optixMeshViewer.dir/optixMeshViewer.cpp.o
[ 43%] Linking CXX executable …/bin/optixMDLDisplacement
[ 43%] Built target optixMDLDisplacement
Scanning dependencies of target optixMotionBlur
[ 44%] Building CXX object optixMotionBlur/CMakeFiles/optixMotionBlur.dir/optixMotionBlur.cpp.o
[ 45%] Linking CXX executable …/bin/optixMDLExpressions
[ 46%] Linking CXX executable …/bin/optixMDLSphere
[ 46%] Built target optixMDLExpressions
Scanning dependencies of target optixParticles
[ 47%] Building CXX object optixParticles/CMakeFiles/optixParticles.dir/optixParticles.cpp.o
[ 47%] Built target optixMDLSphere
Scanning dependencies of target optixPathTracer
[ 48%] Building CXX object optixPathTracer/CMakeFiles/optixPathTracer.dir/optixPathTracer.cpp.o
[ 50%] Linking CXX executable …/bin/optixMeshViewer
[ 50%] Built target optixMeshViewer
Scanning dependencies of target optixPathTracerTiled
[ 51%] Building CXX object optixPathTracerTiled/CMakeFiles/optixPathTracerTiled.dir/optixPathTracerTiled.cpp.o
/home/kuwano/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK/optixPathTracerTiled/optixPathTracerTiled.cpp: In function ‘void setupCudaInterop()’:
/home/kuwano/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK/optixPathTracerTiled/optixPathTracerTiled.cpp:150:17: error: ‘cudaSetDevice’ was not declared in this scope
if( cudaSetDevice( devices[i] ) != 0 )
/home/kuwano/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK/optixPathTracerTiled/optixPathTracerTiled.cpp:150:17: note: suggested alternative: ‘cudaCpuDeviceId’
cudaCpuDeviceId
/home/kuwano/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK/optixPathTracerTiled/optixPathTracerTiled.cpp:155:17: error: ‘cudaMalloc’ was not declared in this scope
if( cudaMalloc( &ptr, worker_count4 ) != 0 )
/home/kuwano/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK/optixPathTracerTiled/optixPathTracerTiled.cpp:155:17: note: suggested alternative: ‘calloc’
calloc
/home/kuwano/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK/optixPathTracerTiled/optixPathTracerTiled.cpp:171:13: error: ‘cudaFreeHost’ was not declared in this scope
cudaFreeHost( hostTileIndexBuffer );
/home/kuwano/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK/optixPathTracerTiled/optixPathTracerTiled.cpp:173:13: error: ‘cudaHostAlloc’ was not declared in this scope
if( cudaHostAlloc( (void**)&hostTileIndexBuffer, hostTileIndexBufferSize, cudaHostAllocPortable ) != 0 )
/home/kuwano/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK/optixPathTracerTiled/optixPathTracerTiled.cpp:173:13: note: suggested alternative: ‘cudaHostAllocMapped’
cudaHostAllocMapped
/home/kuwano/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK/optixPathTracerTiled/optixPathTracerTiled.cpp: In member function ‘void WorkManager::setup()’:
/home/kuwano/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK/optixPathTracerTiled/optixPathTracerTiled.cpp:230:17: error: ‘cudaSetDevice’ was not declared in this scope
if( cudaSetDevice( devices[worker.m_launchDeviceIndex] ) != 0 )
/home/kuwano/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK/optixPathTracerTiled/optixPathTracerTiled.cpp:230:17: note: suggested alternative: ‘cudaCpuDeviceId’
cudaCpuDeviceId
/home/kuwano/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK/optixPathTracerTiled/optixPathTracerTiled.cpp:232:13: error: ‘cudaStreamCreate’ was not declared in this scope
cudaStreamCreate( &worker.m_syncStream );
/home/kuwano/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK/optixPathTracerTiled/optixPathTracerTiled.cpp:232:13: note: suggested alternative: ‘cudaStreamLegacy’
cudaStreamLegacy
/home/kuwano/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK/optixPathTracerTiled/optixPathTracerTiled.cpp: In member function ‘void WorkManager::render()’:
/home/kuwano/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK/optixPathTracerTiled/optixPathTracerTiled.cpp:250:21: error: ‘cudaSetDevice’ was not declared in this scope
/home/kuwano/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK/optixPathTracerTiled/optixPathTracerTiled.cpp:250:21: note: suggested alternative: ‘cudaCpuDeviceId’
cudaCpuDeviceId
/home/kuwano/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK/optixPathTracerTiled/optixPathTracerTiled.cpp:256:13: error: ‘cudaMemcpyAsync’ was not declared in this scope
cudaMemcpyAsync( tile_index_devptr, hostTileIndexBuffer + tile_index, 4, cudaMemcpyHostToDevice, worker.m_syncStream );
/home/kuwano/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK/optixPathTracerTiled/optixPathTracerTiled.cpp: In member function ‘void WorkManager::shutdown()’:
/home/kuwano/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK/optixPathTracerTiled/optixPathTracerTiled.cpp:279:13: error: ‘cudaStreamDestroy’ was not declared in this scope
cudaStreamDestroy( worker.m_syncStream );
/home/kuwano/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK/optixPathTracerTiled/optixPathTracerTiled.cpp:279:13: note: suggested alternative: ‘cudaStreamDefault’
cudaStreamDefault
/home/kuwano/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK/optixPathTracerTiled/optixPathTracerTiled.cpp: In function ‘void destroyContext()’:
/home/kuwano/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK/optixPathTracerTiled/optixPathTracerTiled.cpp:311:13: error: ‘cudaFree’ was not declared in this scope
cudaFree( *iter );
/home/kuwano/Downloads/NVIDIA-OptiX-SDK-6.5.0-linux64/SDK/optixPathTracerTiled/optixPathTracerTiled.cpp:312:9: error: ‘cudaFreeHost’ was not declared in this scope
optixPathTracerTiled/CMakeFiles/optixPathTracerTiled.dir/build.make:62: recipe for target ‘optixPathTracerTiled/CMakeFiles/optixPathTracerTiled.dir/optixPathTracerTiled.cpp.o’ failed
make[2]: *** [optixPathTracerTiled/CMakeFiles/optixPathTracerTiled.dir/optixPathTracerTiled.cpp.o] Error 1
CMakeFiles/Makefile2:1130: recipe for target ‘optixPathTracerTiled/CMakeFiles/optixPathTracerTiled.dir/all’ failed
make[1]: *** [optixPathTracerTiled/CMakeFiles/optixPathTracerTiled.dir/all] Error 2
make[1]: *** 未完了のジョブを待っています…
[ 52%] Linking CXX executable …/bin/optixMotionBlur
[ 53%] Linking CXX executable …/bin/optixPathTracer
[ 53%] Built target optixMotionBlur
[ 53%] Built target optixPathTracer
[ 54%] Linking CXX executable …/bin/optixParticles
[ 54%] Built target optixParticles
Makefile:83: recipe for target ‘all’ failed
make: *** [all] Error 2
