I’m working on a project using the Jetson Nano 4GB (running JetPack 4.x), and I need to install the ZED SDK (ZED Stereo Camera) in a setup that works well with both OpenCV and TensorRT.
Could someone please guide me on:
The correct version of the ZED SDK that is compatible with the Jetson Nano 4GB?
Any prerequisites or dependencies I need to install beforehand?
Steps to ensure compatibility with OpenCV (ideally the JetPack pre-installed version)?
How to enable or verify TensorRT integration with ZED SDK?
I cannot install CUDA-compatible TensorRT and OpenCV due to low memory issues even after creating a swap file. Are there any easy ways or alternatives to install OpenCV and TensorRT on Nano? Which should be compatible with CUDA
