Hi
Our product is very hot when running. There are some issue can relate to shutdown due to overheating. But i don’t know how to check it on log file (/var/log).
So, Do anyone know how to check overheating from log or where do i need add log for debug?
Thank you
hi @ThangNguyen115 Can you redirect to “var/log/kern.log” to get the log which you require and also as you are facing heating issue, can you please also refer Tegra Linux Driver , Thermal management for additional details
thank you
