Hello there, in order to use external screens on my laptop without lag I need to use the Nvidia card as the primary X.org GPU however that makes my laptop heat up a lot (24w power consumption just for moving windows on my desktop).
Is there a way to limit the Nvidia card from reaching high power levels?
I have tried setting options nvidia NVreg_RegistryDwords="OverrideMaxPerf=0x1"
parameter for the nvidia
kernel module without success.
System information:
Machine:
Type: Laptop System: Acer product: Predator G3-571 v: V1.22
serial: <superuser required>
Mobo: KBL model: Sienta_KLS v: V1.22 serial: <superuser required>
UEFI: Insyde v: 1.22 date: 03/15/2019
CPU: Info: Quad Core model: Intel Core i7-7700HQ bits: 64 type: MT MCP cache: L2: 1024 KiB
Speed: 3552 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 3552 2: 3516 3: 3047 4: 3605 5: 3207 6: 3697 7: 3756
8: 3530
Graphics:
Device-1: Intel HD Graphics 630 driver: i915 v: kernel
Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] driver: nvidia v: 495.46
Device-3: Chicony HD WebCam type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.14 driver: loaded: modesetting,nvidia
resolution: 1: 1920x1080 2: 1920x1080~60Hz
OpenGL: renderer: NVIDIA GeForce GTX 1060/PCIe/SSE2 v: 4.6.0 NVIDIA 495.46
Distro: Fedora Workstation 35 (Gnome)
nvidia-smi:
Fri Jan 7 20:55:19 2022
| NVIDIA-SMI 495.46 Driver Version: 495.46 CUDA Version: 11.5 |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 On | N/A |
| N/A 57C P0 25W / N/A | 398MiB / 6078MiB | 3% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 2407 G /usr/libexec/Xorg 216MiB |
| 0 N/A N/A 2554 G /usr/bin/gnome-shell 67MiB |
| 0 N/A N/A 3322 G ...AAAAAAAAA= --shared-files 111MiB |
