How to lower Latency on NVENC H265
Hello
I built a pipeline in C++ that is designed for the lowest possible latency. I capture directly into a dmabuf buffer pool via v4l2. The capture format is UYVY. I capture the left and right halves of a 3840x2160@60 stream via two separate video devices. When the left and right buffers are ready, I use CUDA to convert the format to NV12 and stitch the left and right halves of the image together, then write it directly to a dequeued buffer of the encoder. So zerocopy. This all works very well. Then it is encoded and I measure the latency after the dequeue on the capture side of the encoder. However, I find that the latency of the encoder for H265 encoding is still quite high. I get the following latencies on average:
Start of Frame to Capture right time Δ avg: 16.362506 ms
Start of Frame to Capture left time Δ avg: 16.366713 ms
Start of Frame to Stitch/Conversion time Δ avg: 19.269282 ms
Start of Frame to dequeue on Capture plane of Enc time Δ avg: 42.263388 ms
This means that NVenc takes approximately 23 ms for a 4K frame at 60 fps. I would like to reduce this value. I read my encoder parameters via a YAML file. I have attached my current parameters below.
I also wonder why my NVENC is not running at the maximum possible clock frequency. In my application, it clocks between 500 and 560 MHz even though I have max_perf enabled. However, the maximum clock frequency of the NVENC is 793 MHz. I have run jeston_clocks and my Jetson is running in MAXN_SUPER mode. My L4T version is 36.4.3 and my jetpack version is 6.2.1.
How can i reduce my Latency?
# Set encoding Format [Default = "H265"]
# ["H264", "H265", "VP8", "VP9", "AV1"]
encoder_pixfmt: "H265"
# Enable External RPS [Default = false]
externalRPS: false
# Enable RPS Three Layer SVC [Default = false]
RPS_threeLayerSvc: false
# Enable maximum Performance [Default = false]
max_perf: true
# Enable GDR [Default = false]
enableGDR: false
# Enable Gaps in FrameNum [Default = false]
bGapsInFrameNumAllowed: false
# H264 FrameNum bits [Default = 0]
nH264FrameNumBits: 0
# H265 poc lsb bits [Default = 0]
nH265PocLsbBits: 0
# No I-frames [Default = false]
bnoIframe: false
# Enable External picture RC [Default = false]
externalRCHints: false
# Max QP per session when external picture RC enabled (needs to be >0)
sMaxQp: 51
# Bitrate [Default = 4194304] (needs to be >0)
bitrate: 6250000
# Peak bitrate [Default = 1.2*bitrate] (needs to be >0)
peak_bitrate: 7500000
# I-frame Interval [Default = 30]
iframe_interval: 30
# IDR Interval [Default = 256]
idr_interval: 256
# Insert SPS PPS at every IDR [Default = false]
insert_sps_pps_at_idr: true
# Slice level encode output [Default = false]
enable_slice_level_encode: false
# CABAC Disable for H264 [Default = false]
disable_cabac: false
# Insert VUI [Default = false]
insert_vui: false
# Set Extended ColorFormat (Only works with insert-vui) [Default = false]
enable_extended_colorformat: false
# Insert AUD [Default = false]
insert_aud: false
# Enable all I-frame encoding [Default = false]
alliframes: false
# Encoding Level [Default set by the library] (Only for H264 and H265)
# H264: ["1.0", "1b", "1.1", "1.2", "1.3", "2.0", "2.1", "2.2", "3.0", "3.1", "3.2", "4.0", "4.1", "4.2", "5.0", "5.1"]
# H265: ["main1.0", "high1.0", "main2.0", "high2.0", "main2.1", "high2.1", "main3.0", "high3.0", "main3.1", "high3.1",
#        "main4.0", "high4.0", "main4.1", "high4.1", "main5.0", "high5.0", "main5.1", "high5.1", "main5.2", "high5.2",
#        "main6.0", "high6.0", "main6.1", "high6.1", "main6.2", "high6.2"]
level: "main6.2"
# Ratecontrol mode [Default = cbr]
# ["cbr", "vbr"]
ratecontrol: "cbr"
# Enable Lossless encoding [Default = false] (Option applicable only with YUV444 input)
enableLossless: false
# Disable Aysmmetric Motion Partition. Applicable only for H.265 Xavier [Default = false]
disable_amp: false
# Enable use of gold crc [Default = false]
use_gold_crc: false
# GOLD CRC [String]
gold_crc: ""
# Encoding Profile [Default = baseline]
# H264: ["baseline", "constrained-baseline", "main", "high", "constrained-high", "high444"]
# H265: ["main", "main10"]
profile: "main"
# Temporal Tradeoff level [Default = 0]
# [0, 1, 2, 3, 4]
# 0: Do not drop any buffers
# 1: Drop 1 in every 5 buffers
# 2: Drop 1 in every 3 buffers
# 3: Drop 1 in every 2 buffers
# 4: Drop 2 in every 3 buffers
temporal_tradeoff_level: 0
# Slice length type [Default = 1]
# [1, 2]
# 1: Number of MBs
# 2: Bytes
slice_length_type: 1
# HW preset type
# 0: Disable
# 1: ultrafast
# 2: fast
# 3: medium
# 4: slow
hw_preset_type: 1
# Slice length [Default = 0]
# 0:  Default
# >0: Slice Length
slice_length: 0
# Virtual buffer size [Default = 0]
# 0:  Default
# >0: vbv
virtual_buffer_size: 1560000
# Number of B frames [Default = 4294967295]
# -1:   Not set
# >=0:  num b frames
num_b_frames: -1
# Specify colorspace [Default = 1]
# 0: Default colorspace, i.e. let the driver figure it out
# 1: SMPTE 170M: used for broadcast NTSC/PAL SDTV
# 2: Obsolete pre-1998 SMPTE 240M HDTV standard, superseded by Rec 709
# 3: Rec.709: used for HDTV
color_space: 1
# Slice intrarefresh interval [Default = 0]
# 0:  Default
# >0: Slice intrarefresh interval
slice_intrarefresh_interval: 0
# Specify minimum Qp Value for I frame [Default = 4294967295]
# -1:          Not set
# >=0 && <=51: minimum/maximum Qp Value
nMinQpI: -1   # I-Frames
nMaxQpI: -1   # I-Frames
nMinQpP: -1   # P-Frames
nMaxQpP: -1   # P-Frames
nMinQpB: -1   # B-Frames
nMaxQpB: -1   # B-Frames
# Reconstructed surface CRC [Default = false]
bReconCrc: false
# Reconstructed surface Left cordinate [Default = 0] (only considered if bReconCrc == true)
rl: 0
# Reconstructed surface Top cordinate [Default = 0] (only considered if bReconCrc == true)
rt: 0
# Reconstructed surface width [Default = 5] (only considered if bReconCrc == true)
# Has to be >0
rw: 5
# Reconstructed surface height [Default = 5] (only considered if bReconCrc == true)
# Has to be >0
rh: 5
# Sample Aspect Ratio parameters [Default = 0 0]
# 0:  Default SAR
# >0: SAR value
sar_width:  0
sar_height: 0
# Print encoder output metadata [Default = false]
report_metadata: false
# Enable encoder input metadata [Default = false]
input_metadata: false
# Dump encoded motion vectors [Default = false]
dump_mv: false
# Disable Constant QP, enable rate control [Default = true]
enable_ratecontrol: true
# Enable Init QP Values for I, P and B frames
enable_initQP: false
# Init QP Values [Default = 0] (Has to be >=0) (only considered if enable_ratecontrol == true)
IinitQP: 0
PinitQP: 0
BinitQP: 0
# Enable preprocessing enhancements (PPE) [Default = false]
enable_ppe: false
# Specify the PPE wait time for encoder, in milliseconds [Default = infinite wait] (only considered if enable_ppe == true)
# -1:           Wait infinite
# >=0 && <=90:  max number of milliseconds that the encoder should wait for each frame processing
wait_time_ms: -1
# Enable profiler for PPE [Default = false] (only considered if enable_ppe == true)
enable_profiler: false
# Enable PPE Temporal AQ feature [Default = false] (only considered if enable_ppe == true)
ppe_taq: true
# Enable PPE Spatial AQ feature [Default = false] (only considered if enable_ppe == true)
ppe_saq: false
# Specify the max QP delta strength for TAQ and SAQ [Default = 5] (only considered if enable_ppe == true)
# Range: >=1 && <=10
taq_max_qp_delta: 5
saq_max_qp_delta: 5
# Enable B-frame support for PPE TAQ [Default = true] (only considered if enable_ppe == true)
taq_b_frame_mode: true
# AV1 specific. Enable multi-tile encoding. [Default = false] (only considered if encoder_pixfmt == "AV1")
enable_av1tile: false
# AV1 specific. Specify Log2 rows and cols for Tile
# Values need to be >=0
log2_num_av1rows: 0
log2_num_av1cols: 0
# AV1 specific. Enable and set Ssim RDO [Default = -1, set by encoder]
# -1:   Disabled, set by encoder
# >=0:  Enable Ssim RDO with this value
enable_av1ssimrdo: -1
# Enable and set CDF Update [Default=-1, set by encoder]
# >=0:  Enable and set CDF Update with this value
disable_av1cdfupdate: -1
# AV1 specific. Error Resilient Mode [Default = true, set by encoder]
# ATTENTION: true: Disables Control, set by encoder
#            false: Enables Control
av1erresmode: true
# AV1 specific. Enable frameID present flag. [Default = false]
enable_av1frameidflag: false
# Specify Picture Order Control Type type [Default = 0]
# value has to be >0
poc_type: 0
# Enable two pass CBR for H264/H265 during encode [Default = false]
enable_two_pass_cbr: false
Please execute $ sudo jetson_clocks and enable the options in 01_video_encode sample:
// enable maximum performance mode
        --max-perf            Enable maximum Performance
// set POC type to 2
        -poc <type>           Specify POC type [Default = 0]
As I already wrote, I am running jetson_clocks and max_perf is also enabled, as can be seen in the parameter list. I created my own software based on the 01_video_encode example. I tried to set POC type to 2 but the latency stays the same.
Any news on this?
All related properties are set, so the system is in maximum throughput. One strange thing is we can achieve 793MHz on developer kit. You may check why the frequency is lower on the system.
Wouldn’t encoder slicing also allow me to reduce latency? I’ve also noticed that when I switch to H264 (NVENC can’t do more than 60fps with H265) and give the encoder a higher frame rate than it actually gets at the output plane, the clock frequency also goes up. Does that make any sense?
There is a known issue in enabling hardware encoder at maximum performance mode. Please try this:
Stopping gdm increases Latency on NVENC - #19 by DaneLLL
