How to make application run automatically when power on
Hi ,
How can we make our application running automatically once we on the power of jetson.
can anybody please suggest how to do this , it would be a great help.
Thanks in Advance,
You can use “Startup Applications Preferences” or create a service.
If you can use your desktop GUI, you can add your application command from here :
If you use headless mode or if you want to use this via terminal, look at this example:
In these examples, you should change the running scripts. It should work if you don’t have any file accessing errors.
Regards
