How to open CSI Camera which is connected using MIPI connector?
I have aetina board with Jetson TX2 module and currently using Jetpack 3.3. I have 1 CSI camera only and connected using MIPI connector.
This command will show this message :
ls /dev/video*
/dev/video0  /dev/video1  /dev/video2  /dev/video3  /dev/video4  /dev/video5
And this :
v4l2-ctl -d /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
	Index       : 0
	Type        : Video Capture
	Pixel Format: 'RG12'
	Name        : 12-bit Bayer RGRG/GBGB
		Size: Discrete 1948x1096
			Interval: Discrete 0.033s (30.000 fps)
When I tried to open the camera using gstreamer using below command, it produced this message and my monitor turned into green screen for a moment and failed
gst-launch-1.0 nvcamerasrc ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)60/1' ! nvvidconv ! 'video/x-raw(memory:NVMM), format=(string)I420' ! nvoverlaysink -e
Setting pipeline to PAUSED ...
Available Sensor modes :
1948 x 1096 FR=30.000000 CF=0x1009208a10 SensorModeType=4 CSIPixelBitDepth=12 DynPixelBitDepth=12
1948 x 1096 FR=60.000000 CF=0x1009208a10 SensorModeType=4 CSIPixelBitDepth=12 DynPixelBitDepth=12
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
NvCameraSrc: Trying To Set Default Camera Resolution. Selected sensorModeIndex = 1 WxH = 1948x1096 FrameRate = 60.000000 ...
Received error from camera daemon....exiting....
Socket read error. Camera Daemon stopped functioning.....
Got EOS from element "pipeline0".
Execution ended after 0:00:17.080498486
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
Any help? Thanks
Hi ivandi5hj8,
You can refer to below docs.
@vickyy
aetina board has its own driver for IMX290 Camera and I already installed it.
I’ve tried the command written on the doc, but still it produces error and green screen is shown
gst-launch-1.0 nvcamerasrc !  'video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, \
 format=(string)NV12, framerate=(fraction)30/1' !  nvivafilter cuda-process=true  customer-lib-name="libnvsample_cudaprocess.so" ! 'video/x-raw(memory:NVMM), format=(string)NV12' ! nvoverlaysink -e
NvCameraSrc: Trying To Set Default Camera Resolution. Selected sensorModeIndex = 0 WxH = 1948x1096 FrameRate = 30.000000 ...
Execution ended after 0:00:17.514956341
According to the doc, “Legacy nvcamerasrc plugin support is deprecated”.
Could you try with nvarguscamerasrc mentioned in the doc?
@vickyy isn’t nvcamerasrc is deprecated in Jetpack 4.2? I’m using Jetpack 3.3
Anyway using argus will produces this error :
gst-launch-1.0 nvarguscamerasrc !  'video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, \
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 0
   Output Stream W = 1280 H = 720
   seconds to Run    = 0
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
CONSUMER: Done Success
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 214)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 317)
Sorry that not notice you’re using jetpack 3.3.
How about v4l2-ctl? Please clarify from v4l2 first.
@ivandi5hj8
Have a try the v4l2-ctl to make sure the sensors driver/hardware without problem first.
v4l2-ctl --set-fmt-video=width=1948,height=1096,pixelformat=RG12 --stream-mmap --set-ctrl=sensor_mode=0 --stream-count=10
@vickyy @ShaneCCC after I input the commend above, nothing is shown. Does it mean there’s a problem with the driver?
Have a check kernel message and reference to below like to enable the trace to confirm.
Enable the trace then run the v4l2-ctl then cat the cat /sys/kernel/debug/tracing/trace again.
https://elinux.org/Jetson_TX2/28.1_Camera_BringUp
Thank you for all the supports, I finally have found a right pipeline to open my camera using this command :
gst-launch-1.0 nvcamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM), width=640, height=540,format=NV12, framerate=30/1' ! nvoverlaysink -e
