I’m porting a mini-rootfs (without GUI) to the Jetson Xavier NX device.
The kernel version is “4.9.140-tegra” and the rootfs can work.
But when I run graphs demo “eglstreamcube”, I got a message “X failed to open display.”
How can I open the display without lightdm?
PS:
the hdmi can work
You may try:
/usr/bin/startx
Those egl applications require a egldisplay. Which are mostly based on X server. Thus, you should follow above suggestion to open a startx first.
Lightdm will also run X server in the background.
