I’m trying to modify the dsexample code to perform out-of-place buffering but I’m getting segmentation faults when accessing the surface derived from the output buffer in my transform function.
Below is a graphic of my pipeline:
Full pipeline:
"filesrc location=input.mp4 ! qtdemux ! h264parse ! nvv4l2decoder ! "
“m.sink_0 nvstreammux name=m batch-size=1 width=1920 height=1080 enable-padding=0 ! tee name=t ! queue ! nvinfer "
“config-file-path= config_infer_primary_yoloV4.txt ! nvvideoconvert ! nvdsosd ! nvvideoconvert ! nvv4l2h264enc ! h264parse ! mp4mux ! filesink location=result_1.mp4”
" t. ! queue ! pertransform ! nvinfer config-file-path= config_infer_primary_deeplab.txt ! nvvideoconvert ! nvdsosd ! nvvideoconvert ! nvv4l2h264enc ! h264parse ! mp4mux ! filesink location=result_2.mp4”
My intention is to perform some transformation operations in the pertransform element and output in a new buffer as the transformation is only used by my segmentation model and not my object detection model.
I think I’m missing some steps related to performing this task but as there is no dsexample for out-of-place buffering I’m lost. Here is my transform function:
static GstFlowReturn
gst_pertransform_transform (GstBaseTransform * btrans, GstBuffer * inbuf, GstBuffer * outbuf)
GstPerTransform *pertransform = GST_PERTRANSFORM (btrans);
GstMapInfo in_map_info;
GstMapInfo out_map_info;
GstFlowReturn flow_ret = GST_FLOW_ERROR;
PerTransformOutput *output;
NvBufSurface *surface = NULL;
NvBufSurface *dest_surface = NULL;
NvDsBatchMeta *batch_meta = NULL;
NvDsFrameMeta *frame_meta = NULL;
NvDsMetaList * l_frame = NULL;
pertransform->frame_num++;
CHECK_CUDA_STATUS (cudaSetDevice (pertransform->gpu_id),
"Unable to set cuda device");memset (&in_map_info, 0, sizeof (in_map_info));
if (!gst_buffer_map (inbuf, &in_map_info, GST_MAP_READ)) {
g_print ("Error: Failed to map input gst buffer\n"); goto error;}
memset (&out_map_info, 0, sizeof (out_map_info));
if (!gst_buffer_map (outbuf, &out_map_info, GST_MAP_WRITE )) {
g_print ("Error: Failed to map output gst buffer\n"); goto error;}
dest_surface = (NvBufSurface *)out_map_info.data;
gst_buffer_unmap (outbuf, &out_map_info);
if (!gst_buffer_copy_into (outbuf, inbuf, GST_BUFFER_COPY_META , 0, -1)) {
g_print ("Error: Buffer metadata copy failed \n");}
nvds_set_input_system_timestamp (inbuf, GST_ELEMENT_NAME (pertransform));
surface = (NvBufSurface *) in_map_info.data;
GST_DEBUG_OBJECT (pertransform,
"Processing Frame %" G_GUINT64_FORMAT " Surface %p\n", pertransform->frame_num, surface);if (CHECK_NVDS_MEMORY_AND_GPUID (pertransform, surface))
goto error;batch_meta = gst_buffer_get_nvds_batch_meta (inbuf);
if (batch_meta == nullptr) {
GST_ELEMENT_ERROR (pertransform, STREAM, FAILED, ("NvDsBatchMeta not found for input buffer."), (NULL)); return GST_FLOW_ERROR;}
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next) { frame_meta = (NvDsFrameMeta *) (l_frame->data); cv::Mat in_mat ; GST_DEBUG("mvo tick 1"); /* Map the buffer so that it can be accessed by CPU */ if (surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[0] == NULL){ if (NvBufSurfaceMap (surface, frame_meta->batch_id, 0, NVBUF_MAP_READ_WRITE) != 0){ GST_ELEMENT_ERROR (pertransform, STREAM, FAILED, ("%s:buffer map to be accessed by CPU failed", __func__), (NULL)); return GST_FLOW_ERROR; } } /* Map the output buffer so that it can be accessed by CPU */ if (dest_surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[0] == NULL){ if (NvBufSurfaceMap (dest_surface, frame_meta->batch_id, 0, NVBUF_MAP_READ_WRITE) != 0){ GST_ELEMENT_ERROR (pertransform, STREAM, FAILED, ("%s:dest_buffer map to be accessed by CPU failed", __func__), (NULL)); return GST_FLOW_ERROR; } } /* Cache the mapped data for CPU access */ NvBufSurfaceSyncForCpu (surface, frame_meta->batch_id, 0); NvBufSurfaceSyncForCpu (dest_surface, frame_meta->batch_id, 0); in_mat = cv::Mat (surface->surfaceList[frame_meta->batch_id].planeParams.height[0], surface->surfaceList[frame_meta->batch_id].planeParams.width[0], CV_8UC4, surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[0], surface->surfaceList[frame_meta->batch_id].planeParams.pitch[0]); /* gaussian blur the frame using opencv */ if (blur_frame (pertransform, frame_meta->batch_id, in_mat) != GST_FLOW_OK) { /* Error in blurring, skip processing on object. */ GST_ELEMENT_ERROR (pertransform, STREAM, FAILED, ("blurring the object failed"), (NULL)); if (NvBufSurfaceUnMap (surface, frame_meta->batch_id, 0)){ GST_ELEMENT_ERROR (pertransform, STREAM, FAILED, ("%s:buffer unmap to be accessed by CPU failed", __func__), (NULL)); } return GST_FLOW_ERROR; } }NvBufSurfaceUnMap (surface, -1, -1);
NvBufSurfaceUnMap (dest_surface, -1, -1);
flow_ret = GST_FLOW_OK;
error:
nvds_set_output_system_timestamp (inbuf, GST_ELEMENT_NAME (pertransform));
gst_buffer_unmap (inbuf, &in_map_info);
return flow_ret;
The segmentation fault occurs when trying to access dest_surface->surfaceList.
I’m not sure which other functions of GstBaseTransform need to be implemented (I implemented prepare_output_buffer).
Some extension of the dsexample code showing how to perform non in-place buffering would be great but until then.. could you give me some clues on the steps needed to perform my goal? I can send the full plugin code if required.
Environment
TensorRT Version : 7.1.3
GPU Type : agx xavier
CUDA Version : 10.2
CUDNN Version : 8.0
Operating System + Version : Ubuntu 18.04
Baremetal or Container (if container which image + tag) : baremetal
