I Pass from Cuda 4.2 to 10.1
I have the Error:
nvcc fatal : Unsupported gpu architecture ‘compute_13’
What is the Macro for Comput_xx et sm_xx ?
I have the Error:
you’re specifying it in the compile command somewhere. So change it.
I’m in Visual Studio 2019 :
Where is the Macro commande ?
I change It and it’s make alwais the same error,
but I’have put:
cumpu_53,sm_53
compute_35,sm_35 was put If I changer Visual Studio 219
But the Message compute_13 Error was Alwais send !
I don’t use GCC !
I don’t know what you mean by macro command.
In Visual Studio, you set the compute target here:
You need to edit the section to the right of “Code Generation”. Remove any unwanted targets. For a complex project, its possible that this is specified on a per-file basis. So if you remove compute_13,sm_13 and are still getting that error, it is specified (still) for one of the files in your project. You then have to right-click on that file in the project explorer, and adjust the properties there.
Thank’s,
I have put the Macro commande:
and it’s work’s (more simply then use the macro)
