Dear hanbinl,
Could you please check installing via SDK Manager again(https://developer.nvidia.com/DRIVE/secure/files/sdkmanager-0.9.9.2351). Also, please check the ~/nvsdkm/logs folder and ~/nvsdkm/sdkm.log to confirm the status of installation. After the installation is successful, you can notice /usr/local/cuda-9.2/bin/ folder which contains nvcc.
i did check the sdk manager, and it shows install successful. also, i check the logs, i saw some errors but still install accomplished. Also, I found the nvcc file in cuda-9.2 folder. i still dont know in which way to fix it.
thanks for help, and i got the nvcc version info after that, but when i type nvcc -v by using root usr, its still shows “The program ‘nvcc’ is currently not installed. You can install it by typing:
apt install nvidia-cuda-toolkit.” is that matter or not …
Hi hanbinl,
Note that nvcc path should be added to $PATH variable of user. Please check echo $PATH. If you don’t find /usr/local/cuda-9.2/bin in it, update the PATH variable for root(user environment) as Steve suggested
