How to properly debug this memory issue
Hi all,
I’m still rather new to cuda and I’m struggling with an issue I can’ seem to debug.
I’m working on a Windows system with a Quadro P620 GPU.
For some reason I cannot seem to get the profilers working properly like I used to have on a Linux system, so I’m flying half blind.
I hope someby can give me a push in the right direction for this.
Below is some sample code for my problem.
This code will generate two vectors, one float* and one complex*.
A function will copy a part of the floats to the real part of the complex
In the second part some small vectors are made and send to the GPU. Without altering them they are copied back and printed out. The expectation is to get two times the same value being printed out.
For N = 16 I correctly get:
5
5
For N =32 I get:
5
-4.31602e+08
include “cuda_runtime.h”
include “device_launch_parameters.h”
include <stdio.h>
include “iostream”
typedef float2 Complex;
global void copyImageToReal(float*, Complex*);
int main()
int N = 32;
int height = 2160; // define height
int width = 4096; // define width
Complex* d_target;
cudaMalloc((void**)&d_target, sizeof(Complex)* height* width * N); // assign device memory
cudaMemset((void**)&d_target, 0, sizeof(Complex)* height* width * N); // assign 0 to all elements
float* d_source;
cudaMalloc((void**)&d_source, sizeof(float) * height * width); // assign device memory
cudaMemset((void**)&d_source, 1, sizeof(float)* height* width); // assign 1 to all elements
//copyImageToReal <<< 8640, 1024 >>>(d_source, d_target); // put source data to real part of the target // Target needs to be larger than source
cudaDeviceSynchronize();
// Some random code that has two numbers going to the GPU and back
float* d_Polar;
float* h_Polar = (float*)malloc(sizeof(float) * 2);
float* h_target = (float*)malloc(sizeof(float) * 2);
h_target[0] = 5;
h_target[1] = 7;
std::cout << h_target[0] << std::endl;
cudaMalloc((void**)&d_Polar, sizeof(float) * 2); // assign device memory
cudaMemcpy(d_Polar, h_target, sizeof(float) * 2, cudaMemcpyHostToDevice); // copy data
cudaMemcpy(h_Polar, d_Polar, sizeof(float) * 2, cudaMemcpyDeviceToHost); // copy data
std::cout << h_Polar[0] << std::endl;
cudaFree(d_target);
cudaFree(d_source);
cudaFree(d_Polar);
cudaDeviceReset();
return 0;
global void copyImageToReal(float* src, Complex* dst) {
int idx = threadIdx.x + blockIdx.x * blockDim.x;
dst[idx].x = src[idx];
This is probably overflowing for N=32. Add (size_t) in front of height or width.
Starting a size computation with sizeof(Type) represents a safe idiom. sizeof returns the size as a size_t (or to be more precise, std::size_t), and since further evaluation proceeds left to right according to C++ rules, the entire expression should be evaluated using type size_t.
What is not safe (danger of overflow in intermediate computation) is the other idiom one sees frequently: [int-expression]*sizeof(Type).
I would suggest adding error checking for all CUDA API calls and kernel launches. Alternatively, try running the executable with cuda-memcheck. You will likely discover that the cudaMalloc allocation failed, as more memory is requested than is available. Also, this is most certainly incorrect:
You want to pass a pointer, not the address of a pointer.
