glingk
March 17, 2023, 10:03am
1
• Hardware : Orin AGX
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc) : All
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here) TAO Toolkit 4.0
• Training spec file(If have, please share here)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.): Follow official nvidia’s instructions
I followed the instructions below, but when I run
tao-deploy info --verbose
I get the following error:
bash: tao-deploy: command not found
So my question is how to properly install tao-deploy?
TAO Deploy is also distributed as a public wheel file at PyPI. The wheel does not include TensorRT or TensorRT OSS as part of its dependencies. Hence, you must either install these dependencies through the official TensorRT website or invoke TensorRT container available on NGC.
Run the following command to install the nvidia-tao-deploy
wheel in your python environment.
pip install nvidia-tao-deploy
Then, you can run TAO Deploy tasks with the tao-deploy
prefix. For example, the following command will run a detectnet_v2 TensorRT engine generation for FP16.
detectnet_v2 gen_trt_engine -e /path/to/experiment/spec.txt \
-m /path/to/etlt/file \
-k $KEY \
--data_type fp16 \
--engine_file /path/to/engine/file
glingk
March 20, 2023, 3:53am
4
That is what I followed already. Not sure what to do differently? Any suggestions are appreciated.
What is the log when you run above?
glingk
March 20, 2023, 9:17am
6
@Morganh Here’s the log
Collecting nvidia-tao-deploy
Downloading nvidia_tao_deploy-4.0.0.1-py3-none-any.whl (2.5 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 2.5/2.5 MB 26.4 MB/s eta 0:00:00
Requirement already satisfied: PyYAML>=5.1 in /usr/local/lib/python3.8/dist-packages (from nvidia-tao-deploy) (6.0)
Collecting h5py==3.7.0
Downloading h5py-3.7.0-cp38-cp38-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (8.6 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 8.6/8.6 MB 69.6 MB/s eta 0:00:00
Collecting Pillow<9.0.0,>=8.1.0
Downloading Pillow-8.4.0-cp38-cp38-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (3.0 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 3.0/3.0 MB 81.8 MB/s eta 0:00:00
Collecting onnxruntime
Downloading onnxruntime-1.14.1-cp38-cp38-manylinux_2_27_aarch64.whl (4.7 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 4.7/4.7 MB 84.4 MB/s eta 0:00:00
Collecting seaborn==0.7.1
Downloading seaborn-0.7.1.tar.gz (158 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 158.1/158.1 kB 37.6 MB/s eta 0:00:00
Preparing metadata (setup.py): started
Preparing metadata (setup.py): finished with status 'done'
Collecting scikit-learn==0.24.2
Downloading scikit_learn-0.24.2-cp38-cp38-manylinux2014_aarch64.whl (26.5 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 26.5/26.5 MB 67.6 MB/s eta 0:00:00
Collecting pynvml==11.0.0
Downloading pynvml-11.0.0-py3-none-any.whl (46 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 46.1/46.1 kB 12.4 MB/s eta 0:00:00
Collecting protobuf==3.20.1
Downloading protobuf-3.20.1-cp38-cp38-manylinux2014_aarch64.whl (918 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 918.1/918.1 kB 69.9 MB/s eta 0:00:00
Collecting scipy==1.5.4
Downloading scipy-1.5.4-cp38-cp38-manylinux2014_aarch64.whl (24.5 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 24.5/24.5 MB 69.3 MB/s eta 0:00:00
Collecting absl-py>=0.7.1
Downloading absl_py-1.4.0-py3-none-any.whl (126 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 126.5/126.5 kB 32.3 MB/s eta 0:00:00
Requirement already satisfied: onnx in /usr/local/lib/python3.8/dist-packages (from nvidia-tao-deploy) (1.13.0)
Collecting opencv-python
Downloading opencv_python-4.7.0.72-cp37-abi3-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (40.4 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 40.4/40.4 MB 56.4 MB/s eta 0:00:00
Collecting hydra-core==1.2.0
Downloading hydra_core-1.2.0-py3-none-any.whl (151 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 151.1/151.1 kB 21.7 MB/s eta 0:00:00
Collecting matplotlib>=3.0.3
Downloading matplotlib-3.7.1-cp38-cp38-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (11.4 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 11.4/11.4 MB 89.3 MB/s eta 0:00:00
Collecting tqdm==4.64.0
Downloading tqdm-4.64.0-py2.py3-none-any.whl (78 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 78.4/78.4 kB 20.1 MB/s eta 0:00:00
Requirement already satisfied: six>=1.12.0 in /usr/local/lib/python3.8/dist-packages (from nvidia-tao-deploy) (1.16.0)
Collecting omegaconf==2.2.2
Downloading omegaconf-2.2.2-py3-none-any.whl (79 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 79.1/79.1 kB 22.0 MB/s eta 0:00:00
Collecting mpi4py>=3.0.3
Downloading mpi4py-3.1.4.tar.gz (2.5 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 2.5/2.5 MB 77.2 MB/s eta 0:00:00
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status 'done'
Preparing metadata (pyproject.toml): started
Preparing metadata (pyproject.toml): finished with status 'done'
Collecting scikit-image==0.17.2
Downloading scikit-image-0.17.2.tar.gz (29.8 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 29.8/29.8 MB 66.3 MB/s eta 0:00:00
Collecting pycocotools-fix
Downloading pycocotools-fix-2.0.0.9.tar.gz (124 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 124.0/124.0 kB 12.8 MB/s eta 0:00:00
Requirement already satisfied: numpy>=1.14.5 in /usr/local/lib/python3.8/dist-packages (from h5py==3.7.0->nvidia-tao-deploy) (1.24.1)
Requirement already satisfied: importlib-resources in /usr/local/lib/python3.8/dist-packages (from hydra-core==1.2.0->nvidia-tao-deploy) (5.12.0)
Requirement already satisfied: packaging in /usr/local/lib/python3.8/dist-packages (from hydra-core==1.2.0->nvidia-tao-deploy) (23.0)
Collecting antlr4-python3-runtime==4.9.*
Downloading antlr4-python3-runtime-4.9.3.tar.gz (117 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 117.0/117.0 kB 25.8 MB/s eta 0:00:00
Collecting PyWavelets>=1.1.1
Downloading PyWavelets-1.4.1-cp38-cp38-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (6.9 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 6.9/6.9 MB 88.3 MB/s eta 0:00:00
Collecting imageio>=2.3.0
Downloading imageio-2.26.1-py3-none-any.whl (3.4 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 3.4/3.4 MB 84.9 MB/s eta 0:00:00
Collecting networkx>=2.0
Downloading networkx-3.0-py3-none-any.whl (2.0 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 2.0/2.0 MB 80.4 MB/s eta 0:00:00
Collecting tifffile>=2019.7.26
Downloading tifffile-2023.3.15-py3-none-any.whl (218 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 218.6/218.6 kB 45.3 MB/s eta 0:00:00
Collecting threadpoolctl>=2.0.0
Downloading threadpoolctl-3.1.0-py3-none-any.whl (14 kB)
Collecting joblib>=0.11
Downloading joblib-1.2.0-py3-none-any.whl (297 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 298.0/298.0 kB 54.5 MB/s eta 0:00:00
Collecting pandas
Downloading pandas-1.5.3-cp38-cp38-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (11.5 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 11.5/11.5 MB 93.4 MB/s eta 0:00:00
Collecting cycler>=0.10
Using cached cycler-0.11.0-py3-none-any.whl (6.4 kB)
Collecting kiwisolver>=1.0.1
Using cached kiwisolver-1.4.4-cp38-cp38-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (1.4 MB)
Collecting contourpy>=1.0.1
Using cached contourpy-1.0.7-cp38-cp38-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (283 kB)
Requirement already satisfied: python-dateutil>=2.7 in /usr/local/lib/python3.8/dist-packages (from matplotlib>=3.0.3->nvidia-tao-deploy) (2.8.2)
Collecting fonttools>=4.22.0
Using cached fonttools-4.39.2-py3-none-any.whl (1.0 MB)
Requirement already satisfied: pyparsing>=2.3.1 in /usr/local/lib/python3.8/dist-packages (from matplotlib>=3.0.3->nvidia-tao-deploy) (3.0.9)
Requirement already satisfied: typing-extensions>=3.6.2.1 in /usr/local/lib/python3.8/dist-packages (from onnx->nvidia-tao-deploy) (4.4.0)
Collecting onnx
Downloading onnx-1.13.1-cp38-cp38-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (13.8 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 13.8/13.8 MB 87.0 MB/s eta 0:00:00
Downloading onnx-1.12.0-cp38-cp38-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (13.0 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 13.0/13.0 MB 71.9 MB/s eta 0:00:00
Collecting flatbuffers
Downloading flatbuffers-23.3.3-py2.py3-none-any.whl (26 kB)
Collecting sympy
Downloading sympy-1.11.1-py3-none-any.whl (6.5 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 6.5/6.5 MB 77.6 MB/s eta 0:00:00
Collecting coloredlogs
Downloading coloredlogs-15.0.1-py2.py3-none-any.whl (46 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 46.0/46.0 kB 12.4 MB/s eta 0:00:00
Collecting cython>=0.27.3
Using cached Cython-0.29.33-cp38-cp38-manylinux_2_17_aarch64.manylinux2014_aarch64.manylinux_2_24_aarch64.whl (1.8 MB)
Requirement already satisfied: setuptools>=18.0 in /usr/lib/python3/dist-packages (from pycocotools-fix->nvidia-tao-deploy) (45.2.0)
Requirement already satisfied: zipp>=3.1.0 in /usr/local/lib/python3.8/dist-packages (from importlib-resources->hydra-core==1.2.0->nvidia-tao-deploy) (3.15.0)
Collecting humanfriendly>=9.1
Downloading humanfriendly-10.0-py2.py3-none-any.whl (86 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 86.8/86.8 kB 24.6 MB/s eta 0:00:00
Collecting pytz>=2020.1
Downloading pytz-2022.7.1-py2.py3-none-any.whl (499 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 499.4/499.4 kB 62.4 MB/s eta 0:00:00
Collecting mpmath>=0.19
Downloading mpmath-1.3.0-py3-none-any.whl (536 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 536.2/536.2 kB 66.2 MB/s eta 0:00:00
Building wheels for collected packages: scikit-image, seaborn, antlr4-python3-runtime, mpi4py, pycocotools-fix
Building wheel for scikit-image (setup.py): started
Building wheel for scikit-image (setup.py): still running...
Building wheel for scikit-image (setup.py): finished with status 'done'
Created wheel for scikit-image: filename=scikit_image-0.17.2-cp38-cp38-linux_aarch64.whl size=34471460 sha256=c2d9e564a56c4de7acfed7e7e1cccf971941815c7a9820e62f9cdc27c1696323
Stored in directory: /root/.cache/pip/wheels/d9/db/c4/f79b4fbcc275680296a2ea558e621fb0bee48ae9a0363f4cd0
Building wheel for seaborn (setup.py): started
Building wheel for seaborn (setup.py): finished with status 'done'
Created wheel for seaborn: filename=seaborn-0.7.1-py3-none-any.whl size=165935 sha256=c020d462596f127b003d5c33b60dd94141b24ea0f83898b7a9971cc2450f2101
Stored in directory: /root/.cache/pip/wheels/e4/5e/0b/65d26eed3baa276f2965271668fb2e2a0a3141b6fabb9c9563
Building wheel for antlr4-python3-runtime (setup.py): started
Building wheel for antlr4-python3-runtime (setup.py): finished with status 'done'
Created wheel for antlr4-python3-runtime: filename=antlr4_python3_runtime-4.9.3-py3-none-any.whl size=144573 sha256=47761672b49128978d05f9ff497731dd9e447e2fe0ebb1a78c4193ab449b22a4
Stored in directory: /root/.cache/pip/wheels/11/20/e3/33bfd201db65084a9bb7ec0fd4040c2a7b59bb155698396a7c
Building wheel for mpi4py (pyproject.toml): started
Building wheel for mpi4py (pyproject.toml): finished with status 'error'
error: subprocess-exited-with-error
× Building wheel for mpi4py (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [148 lines of output]
running bdist_wheel
running build
running build_src
running build_py
creating build
creating build/lib.linux-aarch64-cpython-38
creating build/lib.linux-aarch64-cpython-38/mpi4py
copying src/mpi4py/run.py -> build/lib.linux-aarch64-cpython-38/mpi4py
copying src/mpi4py/__main__.py -> build/lib.linux-aarch64-cpython-38/mpi4py
copying src/mpi4py/__init__.py -> build/lib.linux-aarch64-cpython-38/mpi4py
copying src/mpi4py/bench.py -> build/lib.linux-aarch64-cpython-38/mpi4py
creating build/lib.linux-aarch64-cpython-38/mpi4py/futures
copying src/mpi4py/futures/server.py -> build/lib.linux-aarch64-cpython-38/mpi4py/futures
copying src/mpi4py/futures/_lib.py -> build/lib.linux-aarch64-cpython-38/mpi4py/futures
copying src/mpi4py/futures/__main__.py -> build/lib.linux-aarch64-cpython-38/mpi4py/futures
copying src/mpi4py/futures/_core.py -> build/lib.linux-aarch64-cpython-38/mpi4py/futures
copying src/mpi4py/futures/__init__.py -> build/lib.linux-aarch64-cpython-38/mpi4py/futures
copying src/mpi4py/futures/pool.py -> build/lib.linux-aarch64-cpython-38/mpi4py/futures
copying src/mpi4py/futures/aplus.py -> build/lib.linux-aarch64-cpython-38/mpi4py/futures
copying src/mpi4py/futures/_base.py -> build/lib.linux-aarch64-cpython-38/mpi4py/futures
creating build/lib.linux-aarch64-cpython-38/mpi4py/util
copying src/mpi4py/util/__init__.py -> build/lib.linux-aarch64-cpython-38/mpi4py/util
copying src/mpi4py/util/pkl5.py -> build/lib.linux-aarch64-cpython-38/mpi4py/util
copying src/mpi4py/util/dtlib.py -> build/lib.linux-aarch64-cpython-38/mpi4py/util
copying src/mpi4py/py.typed -> build/lib.linux-aarch64-cpython-38/mpi4py
copying src/mpi4py/__main__.pyi -> build/lib.linux-aarch64-cpython-38/mpi4py
copying src/mpi4py/bench.pyi -> build/lib.linux-aarch64-cpython-38/mpi4py
copying src/mpi4py/MPI.pyi -> build/lib.linux-aarch64-cpython-38/mpi4py
copying src/mpi4py/run.pyi -> build/lib.linux-aarch64-cpython-38/mpi4py
copying src/mpi4py/__init__.pyi -> build/lib.linux-aarch64-cpython-38/mpi4py
copying src/mpi4py/dl.pyi -> build/lib.linux-aarch64-cpython-38/mpi4py
copying src/mpi4py/__init__.pxd -> build/lib.linux-aarch64-cpython-38/mpi4py
copying src/mpi4py/MPI.pxd -> build/lib.linux-aarch64-cpython-38/mpi4py
copying src/mpi4py/libmpi.pxd -> build/lib.linux-aarch64-cpython-38/mpi4py
creating build/lib.linux-aarch64-cpython-38/mpi4py/include
creating build/lib.linux-aarch64-cpython-38/mpi4py/include/mpi4py
copying src/mpi4py/include/mpi4py/mpi4py.MPI_api.h -> build/lib.linux-aarch64-cpython-38/mpi4py/include/mpi4py
copying src/mpi4py/include/mpi4py/mpi4py.h -> build/lib.linux-aarch64-cpython-38/mpi4py/include/mpi4py
copying src/mpi4py/include/mpi4py/mpi4py.MPI.h -> build/lib.linux-aarch64-cpython-38/mpi4py/include/mpi4py
copying src/mpi4py/include/mpi4py/mpi4py.i -> build/lib.linux-aarch64-cpython-38/mpi4py/include/mpi4py
copying src/mpi4py/include/mpi4py/mpi.pxi -> build/lib.linux-aarch64-cpython-38/mpi4py/include/mpi4py
copying src/mpi4py/futures/aplus.pyi -> build/lib.linux-aarch64-cpython-38/mpi4py/futures
copying src/mpi4py/futures/_core.pyi -> build/lib.linux-aarch64-cpython-38/mpi4py/futures
copying src/mpi4py/futures/server.pyi -> build/lib.linux-aarch64-cpython-38/mpi4py/futures
copying src/mpi4py/futures/__main__.pyi -> build/lib.linux-aarch64-cpython-38/mpi4py/futures
copying src/mpi4py/futures/pool.pyi -> build/lib.linux-aarch64-cpython-38/mpi4py/futures
copying src/mpi4py/futures/__init__.pyi -> build/lib.linux-aarch64-cpython-38/mpi4py/futures
copying src/mpi4py/futures/_lib.pyi -> build/lib.linux-aarch64-cpython-38/mpi4py/futures
copying src/mpi4py/util/dtlib.pyi -> build/lib.linux-aarch64-cpython-38/mpi4py/util
copying src/mpi4py/util/__init__.pyi -> build/lib.linux-aarch64-cpython-38/mpi4py/util
copying src/mpi4py/util/pkl5.pyi -> build/lib.linux-aarch64-cpython-38/mpi4py/util
running build_clib
MPI configuration: [mpi] from 'mpi.cfg'
checking for library 'lmpe' ...
aarch64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -fPIC -c _configtest.c -o _configtest.o
aarch64-linux-gnu-gcc -pthread _configtest.o -llmpe -o _configtest
/usr/bin/ld: cannot find -llmpe
collect2: error: ld returned 1 exit status
failure.
removing: _configtest.c _configtest.o
building 'mpe' dylib library
creating build/temp.linux-aarch64-cpython-38
creating build/temp.linux-aarch64-cpython-38/src
creating build/temp.linux-aarch64-cpython-38/src/lib-pmpi
aarch64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -fPIC -c src/lib-pmpi/mpe.c -o build/temp.linux-aarch64-cpython-38/src/lib-pmpi/mpe.o
creating build/lib.linux-aarch64-cpython-38/mpi4py/lib-pmpi
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fwrapv -O2 -Wl,--no-as-needed build/temp.linux-aarch64-cpython-38/src/lib-pmpi/mpe.o -o build/lib.linux-aarch64-cpython-38/mpi4py/lib-pmpi/libmpe.so
checking for library 'vt-mpi' ...
aarch64-linux-gnu-gcc -pthread _configtest.o -lvt-mpi -o _configtest
/usr/bin/ld: cannot find -lvt-mpi
failure.
checking for library 'vt.mpi' ...
aarch64-linux-gnu-gcc -pthread _configtest.o -lvt.mpi -o _configtest
/usr/bin/ld: cannot find -lvt.mpi
failure.
building 'vt' dylib library
aarch64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -fPIC -c src/lib-pmpi/vt.c -o build/temp.linux-aarch64-cpython-38/src/lib-pmpi/vt.o
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fwrapv -O2 -Wl,--no-as-needed build/temp.linux-aarch64-cpython-38/src/lib-pmpi/vt.o -o build/lib.linux-aarch64-cpython-38/mpi4py/lib-pmpi/libvt.so
failure.
failure.
building 'vt-mpi' dylib library
aarch64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -fPIC -c src/lib-pmpi/vt-mpi.c -o build/temp.linux-aarch64-cpython-38/src/lib-pmpi/vt-mpi.o
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fwrapv -O2 -Wl,--no-as-needed build/temp.linux-aarch64-cpython-38/src/lib-pmpi/vt-mpi.o -o build/lib.linux-aarch64-cpython-38/mpi4py/lib-pmpi/libvt-mpi.so
checking for library 'vt-hyb' ...
aarch64-linux-gnu-gcc -pthread _configtest.o -lvt-hyb -o _configtest
/usr/bin/ld: cannot find -lvt-hyb
failure.
checking for library 'vt.ompi' ...
aarch64-linux-gnu-gcc -pthread _configtest.o -lvt.ompi -o _configtest
/usr/bin/ld: cannot find -lvt.ompi
failure.
building 'vt-hyb' dylib library
aarch64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -fPIC -c src/lib-pmpi/vt-hyb.c -o build/temp.linux-aarch64-cpython-38/src/lib-pmpi/vt-hyb.o
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fwrapv -O2 -Wl,--no-as-needed build/temp.linux-aarch64-cpython-38/src/lib-pmpi/vt-hyb.o -o build/lib.linux-aarch64-cpython-38/mpi4py/lib-pmpi/libvt-hyb.so
running build_ext
checking for dlopen() availability ...
checking for header 'dlfcn.h' ...
aarch64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -fPIC -I/usr/include/python3.8 -c _configtest.c -o _configtest.o
success!
success!
checking for library 'dl' ...
aarch64-linux-gnu-gcc -pthread _configtest.o -Lbuild/temp.linux-aarch64-cpython-38 -ldl -o _configtest
success!
removing: _configtest.c _configtest.o _configtest
checking for function 'dlopen' ...
success!
building 'mpi4py.dl' extension
aarch64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -fPIC -DHAVE_DLFCN_H=1 -DHAVE_DLOPEN=1 -I/usr/include/python3.8 -c src/dynload.c -o build/temp.linux-aarch64-cpython-38/src/dynload.o
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fwrapv -O2 build/temp.linux-aarch64-cpython-38/src/dynload.o -Lbuild/temp.linux-aarch64-cpython-38 -ldl -o build/lib.linux-aarch64-cpython-38/mpi4py/dl.cpython-38-aarch64-linux-gnu.so
checking for MPI compile and link ...
_configtest.c:2:10: fatal error: mpi.h: No such file or directory
2 | #include <mpi.h>
compilation terminated.
failure.
error: Cannot compile MPI programs. Check your configuration!!!
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for mpi4py
Building wheel for pycocotools-fix (setup.py): started
Building wheel for pycocotools-fix (setup.py): finished with status 'done'
Created wheel for pycocotools-fix: filename=pycocotools_fix-2.0.0.9-cp38-cp38-linux_aarch64.whl size=406522 sha256=8816bc724c724f1681e528605fc70d9a52b0c27c6cf2a4747bf8b358cf6289ef
Stored in directory: /root/.cache/pip/wheels/49/87/16/79cbbe2d1603a1d8063b97cf9bf604d55d4bd0b61c691dd10a
Successfully built scikit-image seaborn antlr4-python3-runtime pycocotools-fix
Failed to build mpi4py
ERROR: Could not build wheels for mpi4py, which is required to install pyproject.toml-based projects
[notice] A new release of pip available: 22.3.1 -> 23.0.1
[notice] To update, run: python -m pip install --upgrade pip
The command '/bin/sh -c pip install nvidia-tao-deploy' returned a non-zero code: 1
Try another way.
Please pull the tao deploy docker and login it to run commands.
From TAO Toolkit | NVIDIA NGC , you can
$ docker pull nvcr.io/nvidia/tao/tao-toolkit:4.0.0-deploy
Then, login this docker,
$ docker run --runtime=nvidia -it --rm nvcr.io/nvidia/tao/tao-toolkit:4.0.0-deploy /bin/bash
Then, run something like
-k $KEY \
--data_type fp16 \
glingk
March 21, 2023, 4:43am
8
@Morganh I got the following error message:
developer@orin-lab:~$ docker run --runtime=nvidia -it --rm nvcr.io/nvidia/tao/tao-toolkit:4.0.0-deploy /bin/bash
WARNING: The requested image's platform (linux/amd64) does not match the detected host platform (linux/arm64/v8) and no specific platform was requested
exec /opt/nvidia/nvidia_entrypoint.sh: exec format error
FYI, I’m trying to get an engine/plan that will run on Orin AGX
glingk
March 21, 2023, 6:02am
10
@Morganh
I finally successfully install pip install nvidia-tao-deploy
according to Installing TAO Deploy through wheel , but now when I try to run the sample command:
-k $KEY \
--data_type fp16 \
I get this error instead:
/usr/local/lib/python3.8/dist-packages/pytransform_vax_001219/_pytransform_vax_001219.so: cannot open shared object file: No such file or directory
I tried adding that path to LD_LIBRARY_PATH, but I’m still getting the same error…
How should I fix this error?
May I know that if you follow below?
Installing TAO Deploy on a Jetson Platform
You can download the nvidia-tao-deploy wheel to a jetson platform using the same commands as the x86 platform installation. We recommend using the NVIDIA TensorRT Docker container that already includes the TensorRT installation. Due to memory issues, you should first run the gen_trt_engine
subtask on the x86 platform to generate the engine; you can then use the generated engine to run inference or evaluation on the Jetson platform and with the target dataset.
glingk
March 21, 2023, 6:18am
12
@Morganh Yes, I used the pip install approach according to the docs.
May I know that which TRT docker you are using?
glingk
March 21, 2023, 6:33am
14
@Morganh
Here’s the content of the dockerfile I used for the environment:
FROM nvcr.io/nvidia/l4t-tensorrt:r8.5.2.2-devel
RUN apt update
RUN apt --fix-broken install
RUN apt install -y mpich
RUN pip install mpi4py
RUN pip install torchinfo
RUN pip install clearml
RUN pip install segmentation-models-pytorch
RUN pip install transformers
RUN pip install nvidia-tao-deploy
For workaround, can you use tao-converter to generate tensorrt engine using .etlt file?
glingk
March 21, 2023, 8:16am
16
@Morganh will that work with a model train on TAO 4.0 ?
Or would I need to retrain the model with TAO 3 ?
It can work. Not needed to retrain.
system
Closed
April 11, 2023, 5:53am
20
