I will check further for “tao-deploy should work on Jetson platform”.
Instead, as we sync in How to properly install tao-deploy ? bash: tao-deploy: command not found - #14 by glingk , could you use tao-converter to generate the tensorrt engine? Actually this is the way previously we used.
